How to "hack" a CRC? — Parallax Forums
ManAtWorkManAtWork Posts: 2,364
edited 2014-10-10 07:57 in Propeller 1
I'm just about to find out how to talk to an encoder of a Misubishi servo motor with a propeller. This is an optical absolute encoder with 17 bits resolution (single turn) and an RS485 interafce. If I send a command byte of $02 to it it answers with a sequence of 9 bytes. Each byte starts with a start bit of 0 and a stop bit of 1. Lowest significant bit is transmited first. A data frame looks like this:
  • Byte #1: always $02
  • Byte #2: always $31
  • Byte #3: position bits 0..7
  • Byte #4: position bits 8..15
  • Byte #5: position bit 16
  • Byte #6: always $C0
  • Byte #7: always $00
  • Byte #8: always $C0
  • Byte #9: CRC
I found this out by turning the shaft and watching the scope. Now the question: Is it possible to find out how the CRC is calculated? It would be nice if I could verify if the transmission is error-free. I think this could be done with brute force (trying out all possible cases). What are the variables?
  • CRC polynomial, Wiki lists only 5 possibilies of common CRC-8 polynomials
  • different starting values ($00 or $FF are common)
  • data is inverted or not (I can't tell because I don't know the sign/direction of rotation)
Here is a list of some data frame samples:
Data: 02 31 57 8F 01 C0 00 C0 EA
Data: 02 31 8F 97 01 C0 00 C0 2A
Data: 02 31 35 A5 01 C0 00 C0 A2
Data: 02 31 0D AC 01 C0 00 C0 93
Data: 02 31 1A B3 01 C0 00 C0 9B
Data: 02 31 6A B7 01 C0 00 C0 EF
Data: 02 31 C8 C7 01 C0 00 C0 3D
Data: 02 31 97 CD 01 C0 00 C0 68
Data: 02 31 96 D7 01 C0 00 C0 73
Data: 02 31 44 CE 01 C0 00 C0 B8
Data: 02 31 C9 CD 01 C0 00 C0 36
Data: 02 31 E2 D0 01 C0 00 C0 00
Data: 02 31 EC E5 01 C0 00 C0 3B
Data: 02 31 22 EB 01 C0 00 C0 FB
Data: 02 31 EE EE 01 C0 00 C0 32
Data: 02 31 51 F3 01 C0 00 C0 90
Data: 02 31 79 FD 01 C0 00 C0 B6
Data: 02 31 79 0A 00 C0 00 C0 40
Data: 02 31 6F 18 00 C0 00 C0 44
Data: 02 31 B0 28 00 C0 00 C0 AB
Data: 02 31 C4 31 00 C0 00 C0 C6
Data: 02 31 71 46 00 C0 00 C0 04
Data: 02 31 35 55 00 C0 00 C0 53
Data: 02 31 F8 6C 00 C0 00 C0 A7
Data: 02 31 E3 78 00 C0 00 C0 A8
Data: 02 31 5F 8D 00 C0 00 C0 E1
Data: 02 31 0F 90 00 C0 00 C0 AC
Data: 02 31 67 8D 00 C0 00 C0 D9
Data: 02 31 81 8D 00 C0 00 C0 3F
Has anybody done this before or can give me some hints?
    edited 2014-10-10 07:36
    First clue is that the check sum is only one byte so it is probably not any CRC which are usually 16 bits.
    So what about a simple sum of all the bytes?
    Sure enough the first example is 0x02 + 0x31 + 0x57 + 0x8F + 0x01 + 0xC0 + 0x00 + 0xC0 + 0xea = 0x384
    Throw away the overflow out of 8 bits and you have 00.
    So the you have it. Adding up all the bytes of the message including the check sum byte must give zero to be a correct message.
    Edit: Opps. Not so fast that sum is wrong. Changed it now in red.
    edited 2014-10-10 07:40
    Write a program that computes 8-bit CRCs that allows for changing the polynomial, starting value, polarity and shift direction. With 5 polynomials, 2 starting values, 2 polarities and 2 shift directions there will be 40 possibilities. It's most likely one of those combinations. Run your program until you find a matching combination.
    EDIT: Heater, I get 0x384 when I add up the bytes. How did you get 0x900?
  • TorTor Posts: 2,010
    edited 2014-10-10 07:44
    As far as I can tell it's not a CRC, it's an XOR checksum. You XOR the first 8 bytes, and the 9th byte should be the same value.
    -Tor
  • ManAtWorkManAtWork Posts: 2,364
    edited 2014-10-10 07:45
    You made my day! This is another example that often, we just worry too much and expect things to be more complex that they actually are. Yes, it's really a simple checksum, not cyclic/shift/xor/whatever. I thought it was a CRC because a similar encoder from SanyoDenki which also has 17 bits resolution and RS485 uses a CRC (yes, CRC-8 by the way).
    18 x 18 - 898B
    edited 2014-10-10 07:53
    Yes, Tor is correct. It is an XOR checksum. I tried it on a couple of rows and got zero both times.
    No. It's doing a check sum by simply exclusive ORing the bytes together. So we have two examples in the data:
    0x02 ^ 0x31 ^ 0x57 ^ 0x8F ^ 0x01 ^ 0xC0 ^ 0x00 ^ 0xC0 ^ 0xEA = 0x00
    and
    0x02 ^ 0x31 ^ 0x22 ^ 0xEB ^ 0x01 ^ 0xC0 ^ 0x00 ^ 0xC0 ^ 0xFB = 0x00
    edited 2014-10-10 07:56
    Dave,
    Yes I notice the error in my arithmetic and then corrected.
    Correction... Tor is right. The sum of $300 I got or $900 from Heater were lucky speacial cases. But if we use XOR instead it works for all cases. I just tried out. Thank you very much.
