P1V barrel shifter problem
pik33
It seems the barrel shifter (shl, shr instruction) cannot work properly even at 120 MHz (with DE2-115 board). I have random errors when my program does "deep" (28..30 bits) shl/shr. These errors disappeared when I slowed the Propeller to 100 MHz
Can you check this in your projects?
Time to learn how to write these .sdc files....
wire [31:0] sx = i[im] ? {23'b0, i[sh:sl]} : i[sh:sl] == 9'h1F0 ? {16'b0, ptr[27:14], 2'b0} : i[sh:sl] == 9'h1F1 ? cnt : i[sh:sl] == 9'h1F2 ? pin_in : i[sh:sl] == 9'h1F3 ? pinb_in : i[sh:sl] == 9'h1FC ? phsa[31:0] : i[sh:sl] == 9'h1FD ? phsb[31:0] : sy;I registered port b input:
It helped somehow but the only working solution was to return to 80 MHz.
Well, by adding the pinb_in, you did make a deeper mux. Maybe that pushed it over a limit. Try the following:
always @(posedge clk_cog) if (m[1]) sy <= i[im] ? {23'b0, i[sh:sl]} : i[sh:sl] == 9'h1F0 ? {16'b0, ptr[27:14], 2'b0} : i[sh:sl] == 9'h1F1 ? cnt : ram_q; wire [31:0] sx = i[sh:sl] == 9'h1F2 ? pin_in : i[sh:sl] == 9'h1F3 ? pinb_in : i[sh:sl] == 9'h1FC ? phsa[31:0] : i[sh:sl] == 9'h1FD ? phsb[31:0] : sy;Since "s" is effectively set over two clock cycles, this just attempts to split the mux into two smaller/shallower ones.
