P1V barrel shifter problem — Parallax Forums
pik33pik33 Posts: 2,414
edited 2014-09-29 11:00 in Propeller 1
It seems the barrel shifter (shl, shr instruction) cannot work properly even at 120 MHz (with DE2-115 board). I have random errors when my program does "deep" (28..30 bits) shl/shr. These errors disappeared when I slowed the Propeller to 100 MHz
Can you check this in your projects?
Time to learn how to write these .sdc files....
  • pik33pik33 Posts: 2,414
    edited 2014-09-29 10:03
    It seems this was not barrel shifter, or not only barrel shifter. Maybe something is too slow here:
    wire [31:0] sx        = i[im]                    ? {23'b0, i[sh:sl]}
                        : i[sh:sl] == 9'h1F0    ? {16'b0, ptr[27:14], 2'b0}
                        : i[sh:sl] == 9'h1F1    ? cnt
                        : i[sh:sl] == 9'h1F2    ? pin_in
                        : i[sh:sl] == 9'h1F3    ? pinb_in
                        : i[sh:sl] == 9'h1FC    ? phsa[31:0]
                        : i[sh:sl] == 9'h1FD    ? phsb[31:0]
                                                : sy;
    I registered port b input:
    reg[31:0]pinb2;
    always @(posedge clk_cog)
      pinb2<=pinb_in;
    : i[sh:sl] == 9'h1F3    ? pinb2
    It helped somehow but the only working solution was to return to 80 MHz. :(
  • SeairthSeairth Posts: 2,474
    pik33 wrote: »
                                                : sy;
    reg[31:0]pinb2;
      pinb2<=pinb_in;
    Well, by adding the pinb_in, you did make a deeper mux. Maybe that pushed it over a limit. Try the following:
    if (m[1])
        sy <= i[im]                 ? {23'b0, i[sh:sl]}
                                    : ram_q;
    wire [31:0] sx      = i[sh:sl] == 9'h1F2    ? pin_in
                                                : sy;
    Since "s" is effectively set over two clock cycles, this just attempts to split the mux into two smaller/shallower ones.
