P1V barrel shifter problem
pik33
It seems the barrel shifter (shl, shr instruction) cannot work properly even at 120 MHz (with DE2-115 board). I have random errors when my program does "deep" (28..30 bits) shl/shr. These errors disappeared when I slowed the Propeller to 100 MHz
Can you check this in your projects?
Time to learn how to write these .sdc files....
I registered port b input:
It helped somehow but the only working solution was to return to 80 MHz.
Well, by adding the pinb_in, you did make a deeper mux. Maybe that pushed it over a limit. Try the following:
Since "s" is effectively set over two clock cycles, this just attempts to split the mux into two smaller/shallower ones.
