Custom USB Human Interface Device
Duane Degn
I've been considering making some sort of custom HID for a while. I was mainly thinking about making some sort of a mouse but it may be advantageous to include some common keyboard actions into the custom device.
I plan to use this thread to track my progress and to keep links to similar projects.
This first post will mainly be a table of contents to the rest of the thread.
#1 Table of Contents
#2 Latest state of the project
#3 More information (code etc) on project.
#4 Videos of device
#5 Another reserved post
#6 List of links to HID related material
#7+ Discussion about project
Please wait until I've made 7 posts before replying.
#4 Videos of device
BradC's "California Dreaming" demo. I believe the latest code is attached to post #108.
Discussion about USB HID in General Discussion forum.
Post about using a webcam as a mouse. (Also mentioned by NWCCTV in my index thread.)
DIY Sip n Puff mouse article at SparkFun. This project used a Teensy 2.0.
AdaFruit's Trinket with bit banged USB 1.1.
As I mentioned in my reply, my wife has carpal tunnel syndrome and I've been thinking about ways of making a custom mouse.
I had originally intended to post a reply in this thread but decided I wanted to start a new thread to document my efforts.
My first step in this project will be to list the various sites where information on this topic may be found. This list will be made in post #6.
It would be really nice if we could get the functionality of the V-USB library to run in a single cog on the Propeller and then the other cogs could be used to monitor sensors. I haven't looked closely at either the code for V-USB or BradC's USB code. BradC may have already done most of the work.
If attempting to make a HID with an Arduino, I think the Arduino needs to be a 5V version so the clock speed is fast enough to generate the USB signals.
I used to have problems with my wrist when using the computer but I have used the Evoluent Vertical Mouse for many years - it took care of my wrist problems.
http://www.evoluent.com/
Thanks Ron. I'll probably have my wife try one.
As I read more about the Trinket I see there's nothing special about it in particular other than it's low price. I think a board with a more powerful controller and more I/O pins would be a better match for this application.
I thought the V-USB library didn't require one to load a driver onto the PC?
http://forums.parallax.com/showthread.php/152956-PC-IR-Remote-Best-5-Gadget-of-2014
At one point I looked into the possibility of making a mouse/keyboard combination by having four push buttons for the fingers and a four position switch for the thumb on top of a standard mouse x/y position sensor. I built a simple prototype that permitted sending up to 64 codes in addition to the mouse position data to my protoboard. Not quite enough to send all the key codes a standard keyboard can produce, but two such devices could do that and more. I can provide a bit more info if you are interested.
At $13, it's roughly twice the price of the "Trinket", but runs up to 25MHz, 128KB Flash, 8KB RAM, 12 bit 16 channel ADC, 4 16 bit timers, USB MAC and PHY built in. Out of box firmware emulates a small file system and HID keyboard.
... or maybe the similarly priced TM4C123G: ARM M4F @ 80 MHz, 256K FLASH/ 32KB RAM, supports USB HOST/DEVICE/OTG.
Either could serve as a bridge between a Prop and a PC, and provide some data acquisition and pre-processing capabilities, and with some creative trickery emulate the serial communications and EEPROM the Prop needs for programming and program storage space.
@Gordon, I am interested in the 3D mouse Idea. As we've discussed a bit before, I think a combination of IMU and magnetometer would work. Hopefully I can make enough sense of BradC's USB Toys to adapt it for the project.
@Kwinn, You input device sounds like an uber cording keyboard. I've often wondered if something similar would allow one to make a very portable keyboard.
@abecedarian, I agree something more powerful than the "Trinket" would be a good idea. I'm pretty sure I have a TI Tiva board. I may try using it if I can't get this to work in the Prop by itself.
@erco, Those IR keyboard/pads are interesting. I'll probably get a couple to hack (curse you).
I started the project thread a bit prematurely. I'm not ready to work on this project much just now but I wanted a place to put some of the information I had found. I thought listing these resources in a project thread made more sense than replying in test forum index thread.
If there are prospects for fame and fortune by completing this project soon, I'll move this project to a front burner. For now I need to get my robot ready for Halloween. I'll save the world later.
