Easy Bluetooth Repair
NWCCTV
Does anyone know where I can have my Easy Bluetooth Module repaired? I am not sure what happened. The last time I used it about a year ago I packed it in a static free bag and put it in it's own storage bin. I just pulled it out today and when I hooked it up I get no LED and it is not found when trying to run a discovery on it. Really a bummer because I really liked this unit and Parallax no longer sells them. If I could get it repaired at a reasonable cost I would rather do that than to have to splurge and buy an RN-42 Module.
I haven't used these myself but hopefully someone will chime in with some good examples.
I haven't used these myself but hopefully someone will chime in with some good examples./QUOTE
http://www.ebay.com/itm/JY-MCU-HC-06-V1-03-Bluetooth-Transeiver-RF-Module-Wireless-Serial-4p-Port-line-/261053366958
http://propellerpowered.com/shop/?page_id=1748
Are you sure you have it connected correctly?
http://www.parallax.com/sites/default/files/downloads/30085-Easy-Bluetooth-Documentation-v1.3.pdf
Did you check your batteries?
Not using batteries. Boe Board is powered via an 8V Wall Wart.
EDIT: I think I found the problem. It looks like I "got some solderin" to do. The black header that attaches the bottom piece to the top piece has some how come unsoldered. Hopefully that is what the issue is.
When it was stored did you have anything on top of it?
Congratulations on getting it working again.
Yes, There's a guy in the north west who does CCTV installation who also has had success repairing Easy Bluetooth Modules.
That's where I'm going to be sending all my Easy Bluetooth Modules for repairs from now on.
It's good to hear you got it working Andy.
Duane, what keeps happening to the Easy Bluetooth Module that causes it to go bad other than the problem that Andy had? Is it a design flaw?
Genetix, I know very little about the Easy Bluetooth Modules. I was just pointing out to Andy the answer to his original question was himself. I'm pretty sure Andy's forum name is based on his work of installing CCTV systems in the north west (NWCCTV). My post about "a guy in the north west" was supposed to be a friendly tease. I don't have any Easy Bluetooth Modules.
