P1V over-clocking experiment
rjo__
I have been working on a Nano-P1V variant (4 Cogs). Nice compile time (7 minutes), works excellent at 80MHz.
The only wrinkle is that even at 100Mhz, serial is corrupted.
So, then I went back to the reference design (8-11-14) and tried to over-clock at 100MHz (4/1)... from pik33's thread on the subject...
In top.tdf
And then in the spin file
same corrupt result with FullDuplexSerial.
In top.tdf
variable pll : altpll with ( pll_type = "enhanced", operation_mode = "normal", inclk0_input_frequency = 20000, -- 20000ps = 50MHz clk0_multiply_by = 4, clk0_divide_by = 1);
CON _clkmode = xtal1+pll16x _clkfreq = 100_000_000
Then, if it cannot work @ 100 MHz.. try 120.
===Jac
I am running fine at 3M baud on a 120MHz clocked P1V with my Tachyon system I use clk0_divide = 5 and multiply by 24. FullDuplexSerial has too much jitter and asymmetries especially noticable at higher baud rates.
What is your 'stutter threshold ' - ie at what CLK speed does it start failing tests ?
What does the timing report - IIRC Chip commented a while back about no multi-path settings yet ?
