P1V over-clocking experiment — Parallax Forums
rjo__rjo__ Posts: 2,114
edited 2014-08-25 16:55 in Propeller 1
I have been working on a Nano-P1V variant (4 Cogs). Nice compile time (7 minutes), works excellent at 80MHz.
The only wrinkle is that even at 100Mhz, serial is corrupted.
So, then I went back to the reference design (8-11-14) and tried to over-clock at 100MHz (4/1)... from pik33's thread on the subject...
In top.tdf
variable
	pll				: altpll with (
						pll_type = "enhanced",
						operation_mode = "normal",
						inclk0_input_frequency = 20000,		-- 20000ps = 50MHz
						clk0_multiply_by = 4,
						clk0_divide_by = 1);
And then in the spin file
CON
_clkmode = xtal1+pll16x
_clkfreq = 100_000_000
same corrupt result with FullDuplexSerial.
  • pik33pik33 Posts: 2,394
    edited 2014-08-25 08:40
    Try setting pll divide by 5, multiply by 20. In my current environment I keep this 5 in the divider (I changed this only in my last VGA where I wanted 106.5 MHz)
    Then, if it cannot work @ 100 MHz.. try 120.
  • rjo__rjo__ Posts: 2,114
    edited 2014-08-25 08:53
    another cup of coffee:)
    edited 2014-08-25 09:12
    nope... out of time this morning. Will try 120 later.
  • jac_goudsmitjac_goudsmit Posts: 418
    edited 2014-08-25 16:08
    I think the P1V (as compiled with the original 2014-08-11 code) either runs at 80MHz or thinks that's what it's doing. My project generates serial output just fine at 115200 bps when I set the mode to xtal1+pll16x and _xinfreq to 5MHz.
    ===Jac
    edited 2014-08-25 16:43
    rjo__ wrote: »
    I am running fine at 3M baud on a 120MHz clocked P1V with my Tachyon system I use clk0_divide = 5 and multiply by 24. FullDuplexSerial has too much jitter and asymmetries especially noticable at higher baud rates.
  • jmgjmg Posts: 15,183
    What is your 'stutter threshold ' - ie at what CLK speed does it start failing tests ?
    What does the timing report - IIRC Chip commented a while back about no multi-path settings yet ?
