Quickie IQ Test
Kinda fun, several patterns and sequence questions. My score attached, so clearly it's off by 40 points or so...
https://memorado.com/iqtest?r=130
Tim
C.W.
It doesn't tell you what you missed!!!
(ten char)
'Didn't even look at the questions; 'just rolled for an answer until it was less than or equal to the maximum choice. 'Got 120! Woohoo! Yay, lucky (and smart) die!
Maybe I got points just for having opposable thumbs. I should let my cat try it on the tablet.
I suck at the number series.
I knew I wasn't stupid, just a bit idiotic...
Being one standard deviation above the norm is not too significant. But if you were three standard deviations from the norm, you would really be something.
Just maybe the 134 represents a bit over two standard deviations. It all depends on which IQ scale the 134 represents.
http://www.sigmasociety.com/old/Lloyd_Petri.html
I am a bit disappointed that Phil (PhiPi) rolled his die rather than provide a real score. He (along with a few others) seems way ahead of me. Even if his IQ is not significantly higher, his EQ certainly is along with precision.
To be honest it was only 43, but I gave myself 10 extra points for getting my name right.
-Tommay
Yes, Tommay!
You did a good job. The score isn't important. The fact that you participated and tried *YOUR* best is all that really matters!
-Tormmy
This is the video for very special celebrations.
https://www.youtube.com/watch?v=HTuYd1jhP5Y
98 seems to be the worst I can do.
A video with a BASIC STAMP and a gasoline can. Yup.. Had to watch...
And I was convinced that it would be Cliff Richards singing "Congratulations" again...
