Verilog questions re variable cog ram size
Here is what I have in my cog_ram.v module.
While the use of COGID works for generating VGA, what I have here is always giving the larger cog ram.
Can you see my problem???
module cog_ram #( parameter integer COGID = 0 // Receive COGID(0..7) from cog.v/dig.v ) ( input clk, input ena, input w, input [8:0] a, input a9, // 10bits input [31:0] d, output reg [31:0] q ); // COG 0 has 4KB, others have usual 2KB generate if (cogID == 0) begin // 1K x 32 ram reg [1023:0] [31:0] r; // 4KB (10bits) always @(posedge clk) begin if (ena && w) r[{a9,a}] <= d; // 10bits if (ena) q <= r[{a9,a}]; // 10bits end end else // if (COGID != 0) begin // 512 x 32 ram reg [511:0] [31:0] r; // 2KB (9bits) always @(posedge clk) begin if (ena && w) r[a] <= d; // 9bits if (ena) q <= r[a]; // 9bits end end endgenerate endmodule License GPL3
maybe this ?
Verilog is case-sensitive
But these are the warnings (multiple of same)
Warning (10222): Verilog HDL Parameter Declaration warning at cog.v(198): Parameter Declaration in module "cog" behaves as a Local Parameter Declaration because the module has a Module Parameter Port List
http://quartushelp.altera.com/12.1/mergedProjects/msgs/msgs/wvrfx_veri_param_decl_behaves_as_local.htm
Change the lines in cog.v 198+ to read localparam rather than parameter. That will get rid of the warnings but I doubt it will change the cog ram sizing issue.
Where in Quartus are you seeing that all the cogs end up with 1K ram? What happens if you change the if COGID == 0 to if COGID == 7, or make it if COGID != 0 and swap the if/else parts?
May not get time today, but I will try if I can.
I now also need to pass the current executing cog down to cog_alu. I will give this a try in my own and see if I can do it.
