Small V-Prop: 2 Cog's, 4 KB ROM, 4KB Hub RAM — Parallax Forums
nutsonnutson Posts: 242
edited 2014-08-16 09:22 in Propeller 1
To accomodate some older (and smaller) FPGA boards (Cyclone 2C5) I made a small but usable V-Prop with 2 COG's in less than 5000 LE's and 12KB RAM (4KB HUB, 4KB ROM 4KB COG registers. It is running the attached SPIN program on the DE0-nano now. The oscilloscope shows two pins toggling. Thanks Cluso for the unscrambled ROM files. If there is interest, I will post the design files later, too exited now. Need more testing to see if there are unidentified aliasing problems.
  • Willy EkerslykeWilly Ekerslyke Posts: 29
    edited 2014-08-16 06:35
    Excellent! I'm in the process of doing something similar, making it parameterised so the number of cogs is variable.
    Imagine your 2-cog version with reduced I/O pins as a tiny 16-pin chip - it would be a great little peripheral controller :)
    edited 2014-08-16 07:31
    Very interesting. Did you remove the vga from one of the cogs? That saves some logic too - I posted the files for this.
    I have a 40KB Hub RAM with 4KB ROM/RAM and 4 cogs of 4KB. I don't have anything running in the upper 2KB of cog yet.
  • pik33pik33 Posts: 2,417
    edited 2014-08-16 08:00
    Cluso99 wrote: »
    Make a logic which can load upper cog ram from the hub while the cog is running, then switch low ram with high ram... then again... then you will have something like a hubexec enabled cog.
    edited 2014-08-16 09:10
    Cool!
    I have a couple of 2C5 "Ebay specials" in my lab...
    nutson wrote: »
    edited 2014-08-16 09:20
    pik33 wrote: »
    Wouldn't that be more like a COG that supports overlays? In fact, you can already do that with P1 although you have to use code to load the upper COG memory. I guess you're proposing to use the same mechanism used by coginit. The main complexity I can see with that is that unless it is a synchronous operation you'll have to arbitrate between the code running on the COG wanting to access the hub and the overlay loader trying to access the hub.
  • nutsonnutson Posts: 242
    After commenting out the counters and videogenerator I am down to 2350LE's!!! That's what I had in mind a few years ago when I started out with a Verilog soft Cog. Thanks, Parallax.
    Another experiment: when there are just a few COG's, the hub can rotate faster, I modified lines 68-72 in dig.v to rotate over 4 Cog's. The speedup can be seen for a simple testprogram that just does a series of RDLONG's.
    1024 x 497 - 53K
    1024 x 498 - 56K
