Techniques for reverse engineering data stream — Parallax Forums
Mag748Mag748 Posts: 269
edited 2014-08-07 10:19 in General Discussion
Hello,
I have a device that pulses a signal to an IR LED to be recognized by a camera. The pattern of pulses can be selected from 0 to 255, i.e. you can have 256 individual trackable LED beacons. I've analyzed the LED pulse pattern for one of the beacons set to #0 and #255 using a digital oscilloscope. The patterns are below after being decoded from what I think is Manchester encoding. I can not figure out any pattern and wanted to know if anyone has any advice to figure this out. I don't want to have to analyze every single signal from 0-255 although I guess that is an option. The end goal is to be able to reproduce the LED signal using the propeller chip.
#0:    ...1111110000011111000...
#256:  ...00000010101010110001111110101010100111...
The ellipse (...) means the code repeats the pattern from there
It appears that the bit pattern is 19 bits long, but its weird that its inverted on the first one but not the other. See the two attached images of the waveform for your reference. The long pulses are 40mS and the short pulses are 20mS.
Marcus
  • Mark_TMark_T Posts: 1,981
    edited 2014-08-05 11:20
    Differential analysis.
    Compare the results of encoding bit patterns than differ by only one bit, see if there's a pattern between the output
    changes compared to the input bit difference.
    For instance compare 0 to 1, 0 to 2, 0 to 4, 0 to 8, etc.
  • Mag748Mag748 Posts: 269
    edited 2014-08-05 12:36
    I've gather some more data. I'm still not seeing an obvious pattern. Does anyone have any ideas as to the pattern that may be hidden here?
    Unfortunately, there is no option to set the ID tracker to an ID of zero. Only 1 through 255.
    Marcus
    1024 x 183 - 48K
    edited 2014-08-05 12:50
    Those tables, is the first transmitted bit to the left?
    edited 2014-08-05 12:57
    Gadgetman wrote: »
    The data is a constant stream, there are no special "start" or "stop" patterns, so the data in that table could be rotated in either direction. Does that make sense?
    Marcus
    edited 2014-08-05 12:58
    Gadgetman wrote: »
    And it is read from left to right.
    edited 2014-08-05 13:15
    Looking at your waveforms, the coding might also be FM0 instead of Manchester. In FM0, a zero is represented by a transition in the middle of the bit cell; a one, by no transition.
    edited 2014-08-05 13:18
    Jon MacPhalen (JonnyMac) has some code to send out to WS2812 RGB LEDs. I don't know how many can be addressed but I am using a panel with 64 LEDs. The only reason I bring this up is I recognized
    the waveform you posted it looks very similar to when I am driving my panel. Good luck reverse engineering!
  • tonyp12tonyp12 Posts: 1,951
    edited 2014-08-05 13:37
    Why so cryptic?
    1: what is the device
    2: what brand is the camera
    With that info, Googling may turn up IRDA encoding used etc
    edited 2014-08-07 06:31
    This is a good tip, I will try and decode the waveform using this method today.
    tonyp12 wrote: »
    Why so cryptic?
    1: ID Tags by coolux Media Systems, http://www.coolux.de/cooluxsupport/tech-blog/blog/detail/real-time-tracking-id-tags/
    2: Prime 13 by Optitrack, https://www.naturalpoint.com/optitrack/products/prime-13/
    Success!
    Phil, your idea was spot on. I found the pattern using FM0 and it isn't complicated at all. Not even any checksum or error checking involved :)
    Here is the updated spreadsheet with values for your enjoyment.
    Thanks for everyone's help,
    Marcus
    812 x 393 - 20K
