Wire Wrapping — Parallax Forums
Wire Wrapping
WhitWhit Posts: 4,191
edited 2015-06-09 19:03 in General Discussion
Hey All,
I was just reading up on Wire Wrapping for prototyping - the tools, materials, etc...
Do any of you use wire wrapping for your projects? If you do, what are your thoughts on modified (that is wrapping with a couple of turns of insulated wire) vs. regular wire wrapping (i.e., wrapping only the stripped wire). I understand that the modified method is for situation where there is vibration.
I didn't know if the amount of vibration in robotics applications would be enough to warrant the modified method.
Any advice from those who are more experienced would be appreciated.
«13
    edited 2014-07-05 19:34
    Hello Whit,
    I wire wrap the majority of my projects if the conditions allow (i.e. never for 120V AC or multi-amp stuff).
    Modified vs regular? Never gave it any thought. When I learned how to W/W in the early '70s, the wire wrapping tool was always set up for modified. A nice benefit for modified is if you goof and wire to an incorrect adjacent pin, there is probably enough un-wrapped wire to re-wrap on the new pin.
    Advice? The only thing I'd caution against is making the wires too tight. It may look pretty, but they are a bugger to troubleshoot. Being able to tug on one end of a wire to see movement through the rats nest really helps tracking the connections.
    448 x 299 - 30K
  • SapphireSapphire Posts: 497
    edited 2014-07-05 20:44
    I too use wire-wrap for some projects, especially those too complex for a breadboard or one-off productions that don't justify a PCB. I've always used the regular wrap, mainly to leave room on the post for more connections. Sometimes as many as 3 are needed so the shorter regular wrap height helps. Try to use a lot of different color wires to keep their functions easy to identify. Aries DIP headers are great for small components because you can't wire-wrap to their round leads, and you can change the components without unwrapping the wires.
    edited 2014-07-06 03:36
    Whit,
    Wire wrapping is great. I did a lot of it back in the early 1980's. When you want to prototype a ten inch by ten inch board with some 40 pin DIP microprocessor, some RAM and ROM, some UARTS and timers and a bunch of DIP TTL, you can pull up you schematic or net list and settle down to "stitching". You have to get into the "zone" because it's going to take a working week.
    I was surprised to find there are traffic light controllers around that still have wire wrapped back-planes for their processor cards. They are still working well after being out in the heat and cold for thirty years!
    I would still use wire wrapping for some prototypes. Preferably simpler circuits. But there are many down sides to wire wrapping in this modern world.
    Those wire wrap sockets are expensive, as are the tools and the wires and the boards.
    Most interesting devices now a days don't come in DIP packages.
    All in all this leads to the fact that it's simpler and quicker to design a PCB layout and get one made. Now a days that is very quick and cheap which was not the case in the hey day of wire wrap.
    Notice how AdaFruit, SparkFun, even Parallax and other places basically make a business out of providing easy to use break out boards for tiny surface mount parts: micro-controllers, sensors etc. Those things can be connected using a couple of jumpers or solder connections for I2C, SPI and PWM etc. The need for wire wrap is not there. The wire wrap sockets would cost more than the brake out boards.
    Bottom line for me is that if the thing you want to prototype is complex it's easier quicker and cheaper to get a board made than set about wire wrapping it. If you just want to stitch together a couple of DIP parts, go for it. Although a good old strip board solution is normally what I end up with.
    edited 2014-07-06 04:45
    I've been a little quiet on robotics projects because I've been doing retro computing projects instead. Among that crowd wire wrapping is still used for prototyping, but they often do what Heater suggests and design a pcb instead. I was all set to wire wrap a board when someone else ordered a bunch of PCB's that did exactly what I wanted. So I dodge the bullet and ended up with a PCB instead.
    Now I'm probably not out of the woods because I made a parallel eepom programmer that is a rats nets of wires on my breadboard. So I'm going to need to transfer it to a more permanent home. I also want to build an add on card for interfacing with the physical world. So I may yet wire wrap something.
    Eventually the retro computing and robots will converge because I plan to interface the retro computer with sensors and servos. Basically I'm doing a nostalgia project.
  • w4fejw4fej Posts: 264
    edited 2014-07-06 04:54
    Wire wrapping controls the world !!
    I do all my prototyping with WW. When I was in the Navy (20 years worth) wire wrapping was the ONLY mil-spec method of back plane wiring for main frame computers. I've never heard of the so called modified method of WW, I have always used the standard method of a turn or two to mechanically anchor the wire to the pin.
    I used a program back in the day called "Wire Master" (a DOS program) that would take as input a text file listing all the connections in a network (ie: all the connections to say pin 1 of IC23) and generate several lists. There would be a wiring list telling you which pins to wire and in what order, a wrap count list to show you if there were the correct number of turns on each pin. (NEVER more than 2 wraps per pin!) a continuity list for the individual networks and last but not least, an "unwrap list" to make changes to your design.
    If you passed all the check lists, assuming your design was valid, it WILL work. I built MANY S100 buss computers and cards for customers using Wire Master and they all worked as advertised.
    Go forth young man and fear not the Wire Wrap tool for it is your friend...
    Mike B.
    edited 2014-07-06 05:11
    Yep. Wire wrap back planes were very common. Horrible noise and crosstalk ridden things. I once had to replace a lot of address and data connections on a back plane with a ribbon cable with dozens of twisted pair connections just to get the signals around in good condition and get the machine to work.
    Stangely I had never heard of this "normal" and "modified" styles. We just did what was appropriate at the time, never knew these things had names.
    Martin,
    We'd love to hear about your retro-robot controller efforts.
  • Mark_TMark_T Posts: 1,981
    edited 2014-07-06 05:34
    Vibration here means severe vibration for decades I suspect, which mil-spec stuff is expected
    to handle. For ordinary robotics I wouldn't worry, wire-wrap is a strong technique especially as
    the wires tend to hold each other down.
    Have done a little in the dim and distance past and hated it, staring at hundreds of metal
    spikes seems to promote eye-strain like nothing else.
    edited 2014-07-06 05:40
    Turns out that a wire wrap connection can be more resistant to vibration than a soldered connection. Solder tends to metal fatigue and crack. For most use I would not worry about "normal" vs "modified".
    edited 2014-07-06 07:28
    I'll buck the retro trend here by admitting that have never wire wrapped and have no intention of trying. Give me leaded solder or give me death! Yeah, I know, one in the same.
    Wire wrap is bulkier, uglier, costs more, harder to modify, probably slower construction. What's the great appeal?
    edited 2014-07-06 10:14
    When wiring the address bus and data bus of a computer you tend to have many connections to the same pin on the microprocessor. This becomes awkward with point to point soldering, but the length of a wire wrap pin allows for many connections. I've also heard people claim that the circuits have less noise at higher frequencies than point to point soldering, but I can't confirm that.
    @Heater, OK I'll post some details about what I'm up to soon.
    edited 2014-07-06 10:28
    I can't remember the last time I wire-wrapped a circuit. I have the wire, which I still use for point-to-point soldered connections, and the tool, which is used only for stripping the wire now. Wire-wrap DIP sockets are pretty expensive, and the tools are now outrageously pricey. I'm pretty much with erco on this one...
    edited 2014-07-06 12:27
    Phew. I figured I had a dogpile coming my way. :)
    edited 2014-07-06 13:00
    wire-wrap tech -1
    #30 wire-wrap wire for point-to-point soldering +1
    Feel free to park the wire-wrap tools and sockets next to the churn and the spinning wheel.
    edited 2014-07-06 13:46
    Actually, the spinning wheel is still in use some places...
  • WhitWhit Posts: 4,191
    edited 2014-07-06 13:53
    PJ Allen wrote: »
    :-) - Alright PJ, erco and Phil - I get the message.
    Thanks for all the answers everybody - I guess since I kept seeing tools and info about wire wrapping and never used it myself - I was afraid I was missing a skill-set. Guess not. Still might try it on something simple if I find the supplies on sale.
    edited 2014-07-06 14:03
    Whit,
    If you've already got the tools (strip, wrap, unwrap), I'd say give it a try just to see for yourself what it offers. But if you don't already have the tools, I seriously wouldn't bother. Even the simplest hand wrap tools are grotesquely expensive, and the meager benefits they offer do not justify the cost, IMO.
  • max72max72 Posts: 1,155
    edited 2014-07-06 14:10
    Never made a full project based on W/W, but I have a wire wrap hand tool and a couple of spools.
    They come handy for some modifications of an existing board, and I think it's nice to have this option. Sometimes it's the neater solution.
    Massimo
    edited 2014-07-06 14:59
    I don't wire wrap any more, but I've had some circuits I did in the early and mid 80s and they're still okay. They will oxidize over time, and if the wire is on there loosely, the oxidation will get between the wire and post. That will almost always yield a poor connection. Soldering is air tight (or is supposed to be).
    There are people that make entire circuits on wire wrap sockets only. Sort of a takeoff on the dead-bug technique. They use the 30ga wire and solder to the post, gluing the sockets side by side and not even using perf board. It's whatever works, so I wouldn't go by what anyone tells you is good or bad, the right way or the wrong way. eBay has cheap(er) wire wrapping tools, and as someone else mentioned, the wire and the basic tool are also handy for making fixes in traditionally soldered projects. Buy one OK wire wrap tool for $15 or $20, and that'll set you up for life.
  • garyggaryg Posts: 420
    edited 2014-07-06 16:02
    I use wire wrapping on quite a few of my projects.
    Because of how I use wire wrapping, I don't like the modified method.
    I never could trust the wrapped wire SO
    when I've completed wrapping, I test the circuit as I would on a breadboard THEN
    I permanently connect the wrapped terminal with solder.
    I actually wire wrap most of my stuff without wire wrapping sockets.
    Using standard DIP sockets, two turns usually holds the wire wrap in place, if insulation has been stripped.
    I only fabricate a few projects per year, but I haven't had any failures as yet.
    I know, Sounds peculiar, I guess I'm a bit odd.
    edited 2014-07-06 16:04
    This is the tool I bought many years ago from Radio Shack and which I still use just for stripping the 30-gauge wire:
    It cost but a few bucks back then (1980's). Today, they're more than $30 from DigiKey! -- for this little freaking handheld piece of metal.
    edited 2014-07-06 16:47
    garyg wrote: »
    Welcome to the club. We will add your distinctiveness to our own.
    edited 2014-07-06 18:37
    The best wire wrap tool I used was the 'slit and wrap' tool that put the wire spool on the wrapping tool. With it you could wrap multiple pins in a daisy chain fashion without stripping or cutting the wire except at the ends. Only 2 or 3 turns of wire around the pin were required for a good connection. If you wanted to be absolutely sure the connection stayed good you could solder the wire to the pins after testing.
    edited 2014-07-06 19:56
    @Phil - That is exactly what I was looking at - except at Jameco. Just looks fun. I guess a tool 30 years is work the cost. $1 per year isn't so bad. ;-) Unless surface mount components replace everything - which it looks like they are.
    edited 2014-07-06 21:05
    Whit, if you like old school and want to feature the wires, go BIG.
    1024 x 409 - 60K
    edited 2014-07-07 06:54
    @erco - looks like the wood is the weakest link in that photo!
    edited 2014-07-07 07:10
    erco,
    Dogpile here.
    How dare you say wire wrap is uglier. A nice big board covered in logic and wire wrapped neatly is a thing of beauty. Like for example the ALU board of the Magic-1 homebrew computer. See below:
    As for "bulkier" I'm not sure one could layout a double sided PCB for a design like this that would be smaller in area. This will also be easier to modify if you make the odd mis-connection or minor design revision.
    edited 2014-07-07 08:04
    I too have had one of those OK Industries hand tools for years, and it still works perfectly. The wrapping/unwrapping ends are still useful when you have a stub of through-hole component lead to solder to. It's easy to secure the end of the wire before soldering. Also, if you have a header some weird sensor and don't have the mating connector, wire-wrap neatly for quick tests. The wire is available in a rainbow of colors, not only the "blue-wire" favored for pcb rework.
    edited 2014-07-07 08:18
    Heater. wrote: »
    See below:
    ...now THAT is a beautiful thing!!!
    edited 2014-07-07 08:50
    @Heater:
    One drop is not rain.
    One taco is not dinner.
    One post is not a dogpile.
    That sounds so deep. Too bad it didn't work into a nice Haiku.
    I must admit, that's a great example of a beautiful professional wire wrap job. I suspect there are some ugly ones out there by hacks like me. :)
    edited 2014-07-07 09:12
    Nor one taco a dinner.
    One post? No dogpile.
    :lol: You were close enough for government work!!
