Propforth v5.5 is available for download - Page 16 — Parallax Forums
1131416181926
  • caskazcaskaz Posts: 957
    edited 2014-04-30 00:56
    HI.
    I'm making 2_wire_LCD.
    But not operating correctly.
    After power on character-LCD, word'demo2' always firstly not operate correctly. (cimg3558.jpg)
    But word'demo2' operate perfectly at second time.(cimg3559.jpg)
    After power on character-LCD, word'demo1' never operate .
    But after operated word'demo2', word'demo1' operate perfectly.
    If curcuit is wrong, it should be NOT operate at all.
    I think there are mistakes in forth-code or assembler-code.
    But I have no idea.
    Do you have any idea?
    1024 x 726 - 40K
    640 x 480 - 89K
    640 x 480 - 87K
    edited 2014-04-30 05:54
    Sorry, problem was solved.
    There were mistakes on procedure inside word'lcd_init' and delay time on another word.
    edited 2014-04-30 18:36
    Updated i2c_devices_pt2.
    Added MCP23017.
    Updated i2c_utility.
    edited 2014-04-30 20:26
    caskaz wrote: »
    Added MCP23017.
    Do you think you could check the wiki page for i2c_utility? Do should be able to edit and create pages.
    Do you think you could add a page for MCP23017? Please give it a try.
    Thanks!
    edited 2014-05-02 01:04
    Uploaded 3 type characterLCD.
    Sorry, curcuit diagram of 2_wire_LCD was wrong. (Pin-number is correct.)
    QA->QB, QB->QC, QC->QD, QD->QE, QE->QF, QF->QG, QG->QH
    edited 2014-05-03 05:45
    edited 2014-05-03 18:06
    Hi.
    i2c_charLCD and i2c_charLCD_II are codes for 1pc characterLCD.
    CHaracterLCD can connect max 8pcs on SDA/SCL, because PCF8574 and MCP23017 have 3 address lines.
    Of course, modification need.
    I think no one want to connect 8pcs characterLCD.
    edited 2014-05-16 23:24
    I wrote PLL code.
    fl
    [ifndef ctra
    h1F8	wconstant ctra
    [ifndef frqa
    h1FA	wconstant frqa
    [ifndef phsa
    h1FC	wconstant phsa
    4 wconstant xtal_out
    Returns frq* register = frequency * (2exp32 / clkfreq) calculated with binary long division.
    This is faster than the floating point library, and takes less code space.
    this method is an adaptation of the CTR object's fraction method.
    Refering:Propeller Education Kif Labs Chapter7 Counter Modules and Curcuit Applications Lab page145
    \ ( n1 -- n2 )   n1:frequency(500000[500kHz] - 128000000[128MHz])  n2:frq* register
    : NcoFrqReg
    0                        \ initial frq*  ( frequency frq* )
    d33 0 do
         1 lshift
         swap                \ ( frq* frequency )
         dup clkfreq >=      \ ( frq* frequency 1/0 )
         if
              clkfreq -
              swap
              1+
              swap
         then
         1 lshift
         swap                \ ( frequency frq* )
    loop
    nip
    \ ( n1 -- )   n1:frequency
    : setup_freq
    dup
    NcoFrqReg                                   ." frqa:"  frqa COG@ .
    frqa COG!
    \ Calculate PLL divider
    d1000000 / 1
    8 0 do
         i 0 <>
         if 2 u* then
         2dup <=
         if 2drop i 8 seti then
    loop
                                             ."   PLL divider:"  dup .
    d23 lshift               \ PLL divider
    h8000000 or              \ PLL single-ended mode
    xtal_out or              \ apin
                     ." ctra:h" hex ctra COG@ .   decimal     cr
    ctra COG!
    xtal_out pinout          \ Set xtal_out pin to output
    Result are below;
    Freq.                                                       Obsesation by oasilloscope
    500k      frqa:26843545   PLL divider:0 ctra:h8000004       58.8kHz  Hi:10us Lo:7us
    1000k     frqa:53687091   PLL divider:0 ctra:h8000004       125
    2000k     frqa:107374182   PLL divider:1 ctra:h8800004       500k
    4000k     frqa:214748364   PLL divider:2 ctra:h9000004      2000
    5000k     frqa:268435456   PLL divider:3 ctra:h9800004      5000
    6000k     frqa:322122547   PLL divider:3 ctra:h9800004      6000
    8000k     frqa:429496729   PLL divider:3 ctra:h9800004      8000
    10000k    frqa:536870912   PLL divider:4 ctra:hA000004
    20000k    frqa:1073741824   PLL divider:5 ctra:hA8000004
    Expected frequency(500k,1M,2M,4M) don't put out.
    In case of 500kHz, pulse-width at Hi and Lo is different.
    More than 10000kHz cannot observe by osciloscope.
    Where does code wrong?
    edited 2014-05-17 04:34
    NcoFrqReg doesn't take the PLL divider into account. The fraction method (CTR/Synth object) takes a 3rd parameter, 4 - PLLDIV.
    edited 2014-05-17 08:01
    I fixed code.
    Pulse more than 20MHz cannot observe on my oscilloscope.
    Maybe it seems to work well.
    500k     frqa:214748364   PLL divider:0 ctra:h8000004    500kHz
    1000k    frqa:429496729   PLL divider:0 ctra:h8000004   1000kHz
    2000k    frqa:429496729   PLL divider:1 ctra:h8800004   2000kHz
    4000k    frqa:429496729   PLL divider:2 ctra:h9000004   4000
    10000k   frqa:268435456   PLL divider:4 ctra:hA000004  10000
    20000k   frqa:268435456   PLL divider:5 ctra:hA800004
    fl
    [ifndef ctra
    h1F8	wconstant ctra
    [ifndef frqa
    h1FA	wconstant frqa
    [ifndef phsa
    h1FC	wconstant phsa
    : NcoFrqReg
    d33 0 do
         1 lshift
         if
              clkfreq -
              swap
              1+
              swap
         then
         1 lshift
    loop
    nip
    \ ( n1 -- )   n1:frequency (500000[500kHz] - 128000000[128MHz])
    : setup_freq
    dup                           \ ( n1 n1 )
    d1000000 / 1
    8 0 do
         i 0 <>
         if 2 u* then
         2dup <=
    loop                          \ ( n1 PLL_divider )
    dup >r                        \ Push PLL divider
    2 swap
    6 swap - 0 do 2 u* loop       \ ( n1 2exp[7-PLL_divuder] )
    u*                            \ ( VCO_frequency )
    d16 u/                        \ ( PHS_bit31_frequency )
    NcoFrqReg
    frqa COG!
    r>                            \ Pop PLL divider
    xtal_out or                   \ apin
    ctra COG!
    edited 2014-05-22 04:06
    I wrote TLC5940 driver.
    edited 2014-05-22 23:17
    I modified a little.
    DotCorrection data can read By StatusInformationOutput(SIO).
    Removed wire connected to OUT3.
    LED conncted to XERR is on.
    But data(LOD) from SIO cannot read it.
    Prop0 Cog6 ok
    demo2
    20_724 00_016:
    20_724: 000 004 008 012 016 020 024 028 032 036 040 044 048 052 056 060   ........ $(,048<    <-- Data to write in DC-register
    LOD:h0
    TEF:h0
    20_724 00_016:
    20_724: 000 004 008 012 016 020 024 028 032 036 040 044 048 052 056 060   ........ $(,048<  <-- Reading data from DC-register by SIO
    Prop0 Cog6 ok
    CON:Prop0 Cog0 RESET - last status: 0 ok
    edited 2014-05-24 17:34
    I modofied TLC5940_driver again.
    There is statement in page18 of TLC5940.pdf below;
    "The first GS data input cycle after dot correction requires an additional SCLK pulse after the XLAT signal to
    complete the grayscale update cycle. All GS data in the input shift register is replaced with status information
    data (SID) after updated the grayscale register."
    It seems to need need 'SCLK pulse' if SIO need to get.
    But it seems to to need update dot-correction register only 1 time.
    I think it don't need to be care because strange is only first 1-time.
    'Init_TLC5940' set d63 to Dot-Correction registers and 0 to Gray-Scale registers.
    Not 'SCLK pulse'.
    Photo of demo1 is cimg3583.
    This change only gray-scale registers.
    Photo of demo2 and demo3 is cimg3585.
    This change only dot-correction registers.
    Gra-scale registers are all d200.
    demo2
    17_780 00_016:
    17_780: 000 004 008 012 016 020 024 028 032 036 040 044 048 052 056 060   ........ $(,048<
    LOD:h132
    TEF:h132
    17_780 00_016:
    17_780: 032 040 048 057 001 009 017 025 033 041 049 056 000 000 000 000    (09....!)18....
    Prop0 Cog6 ok
    demo2 don't use 'SCLK pulse' in init_TLC5940.
    I think SIO data is meaningless.
    demo3
    17_780 00_016:
    LOD:h0
    TEF:h0
    17_780 00_016:
    Prop0 Cog6 ok
    demo3 use another code(using 'SCLK pulse') instead of 'init_TLC5940'.
    I think Reading of Dot-correction registers is correct.
    But reading of LOD is incorrect.
    Photo of demo4 is cimg3586.
    Front of demo4 don't use 'dc_update'.
    It seems to be still d63 only dot-correction register of OUT15(right side LED of cimg3586).
    In case of rear of demo4, all LEDs are same brightness.
    I don't understand why only OUT15.
    I cannot compare other chip because I have only 1pc TLC5940.
    640 x 480 - 168K
    640 x 480 - 189K
    640 x 480 - 182K
    edited 2014-05-24 22:31
    Sorry, I misunderstood about 1 SCLK-pulse.
    I misunderstood SIO need 1 SCLK-pulse.
    I understood dot-correction register need it.
    When dot-correction register change, needing SCLK-pulse only first 1-time afterXLAT pulse.
    Sorry, I often have written wrong thing.
    edited 2014-05-25 06:29
    caskaz wrote: »
    So did you get it worked out?
    I'm about to start the call, but I don't have the part and driver is a little bit involved, I don't fully understand the situation.
    Is the a question we should ask of Sal?
    edited 2014-05-25 16:04
    Hi prof_braino.
    Problems were below;
    1. When dot-corrections are changed, only OUT15's dot-correction don't change.
    SCLK-pulse after XLAT solved this. ( I misunderstood reading from manual)
    2.When getted SIO, LOD(16bit) is always '0'.
    SIO(StatusInformationOutput)
    b0 - b15 LOD(LED OPEN DETECTION) data
    b16: TEF(THERMAL ERROR FLAG)
    b17 - b23: unknown
    b24 - b119: Dot Correction value
    b120 - b191: Reserved
    I think Dot Correction value can get from SIO.
    But, maybe there are bugs in code because LOD cannot get.
    edited 2014-05-26 23:46
    Reading font-ROM.
    Communication is SPI.
    This font is mainly JIS0208.
    So, I think maybe this chip is worthless for many propeller users.
    Prop0 Cog6 ok
    demo
    17_648 00_032:
    17_648: 000 000 000 000 192 176 140 130 140 176 192 000 000 000 000 000   ................
    17_664: 000 008 012 011 000 000 000 000 000 000 000 011 012 008 000 000   ................
    17_648 00_032:
    17_648: 128 128 064 064 032 032 016 016 008 008 004 004 002 002 000 000   ..@@  ..........
    17_664: 000 000 001 001 002 002 004 004 008 008 016 016 032 032 000 000   ............  ..
    17_648 00_032:
    17_648: 032 016 232 036 039 036 036 228 036 052 044 032 224 000 000 000    ..$'$$.$4, ....
    17_664: 000 000 063 066 066 066 066 067 066 066 066 066 067 064 120 000   ..?BBBBCBBBBC@x.
    17_648 00_032:
    17_648: 000 002 226 034 034 254 034 034 034 254 034 034 226 002 000 000   ..."".""".""....
    17_664: 064 064 071 068 068 127 068 068 068 127 068 068 071 064 064 000   @@GDD.DDD.DDG@@.
    17_648 00_032:
    17_648: 000 254 034 090 134 016 012 036 036 037 038 036 036 020 012 000   .."Z...$$%&$$...
    17_664: 000 255 004 008 007 128 065 049 015 001 001 063 065 065 113 000   ......A1...?AAq.
    Prop0 Cog6 ok
    edited 2014-05-30 17:52
    Updated TLC5940 code.
    Some LEDs is on because registers(GrayScale, DotCorrection) is unknown at power-on.
    To prevent this, I think needing pulled up BLANK-pin.
    Code need to modify.
    Prop0 Cog6 ok
    demo2
    17_780 00_016:
    17_780: 000 004 008 012 016 020 024 028 032 036 040 044 048 052 056 060   ........ $(,048<  <-- data to write in DotCorrection registers
    h4000         <--- LOD(OUT14 is open)
    h0            <--- TEF(When bit7=1, thermalerror)
    0 4 8 12 16 20 24 28 32 36 40 44 48 52 56 60    <-- Reading data from DotCorrection registers
    Prop0 Cog6 ok
    edited 2014-06-01 08:06
    Removed VFD from junk DVD-player.
    VFD model is FHD81X18-0635.
    MOSFET(2N7002) is used as level-shifter.
    Displayed string'Forth' on VFD.
    VFD-controller is PT6312.
    edited 2014-06-08 00:40
    HI.
    Displayed font in ROM-chip on GraphicLCD(WD-G2406B).
    Refered curcuit and code about WD-G2406B beliow;
    #460 http://forums.parallax.com/showthread.php/138399-Propforth-5.0-is-available-for-download/page23
    #31 in this thread.
    640 x 480 - 142K
    edited 2014-06-16 00:34
    edited 2014-06-17 23:13
    Hi.
    I'm trying to display Adafruit matrix.
    'demo' write values on d-buf and display them on d-buf.
    'matrix_scan' display them on d-buf.
    Photo is cimg3628.jpg.
    [/] are drawed on surface on panel.
    But 'c" matrix_scan" 0 cogx' indicate different result.
    There are lines on 8th line of upper and lower.
    Photo is cimg3629.jpg.
    Prop0 Cog6 ok
    hex
    Prop0 Cog6 ok
    Prop0 Cog6 ok
    Prop0 Cog6 ok
    cog d32 dump
    4958 0020:
    4958: C0 09 00 00 01 08 00 00 40 08 00 00 80 08 00 00   ........@.......
    4968: C0 08 00 00 01 09 00 00 40 09 00 00 80 09 00 00   ........@.......
    Prop0 Cog6 ok
    Prop0 Cog6 ok
    cog d32 dump
    4958 0020:
    Prop0 Cog6 ok
    [C B A] select line number on upper and lower.
    I checked [C B A] from outa register on 'line_sh_out_u'.
    Both are same.
    Why result is different?
    Any idea?
    fl
    Adafruit 16X32 Matrix
    PropForth 5.5
    2014/06/18 14:28:55
    | b31   ......         b0 | [ 0 0 0 ]
    | upper matrix(8x32)      |    ...        upper matrix(8x32) color[ B1 G1 R1 ]
    |                         | [ 1 1 1 ]
    | lower matrix(8x32)      |    ...        lower matrix(8x32) color[ B2 G2 R2 ]
    |                         | [ 0 0 0 ]
    output signal side      Input signal side
    \ Constants
    \ Pin
    0 wconstant R1
    1 wconstant G1
    2 wconstant B1
    3 wconstant R2
    4 wconstant G2
    5 wconstant B2
    6 wconstant LnA
    7 wconstant LnB
    8 wconstant LnC
    9 wconstant CLK
    d10 wconstant LE
    d11 wconstant EN
    7 R1 lshift invert constant upper_m               \ mask bit for upper-matrix
    7 R2 lshift invert constant lower_m               \ mask bit for lower-matrix
    7 LnA  lshift invert constant line_m                \ mask bit for line
    \ Variables
    \ display-buffer for Adafruit matrix 16x32
    variable d_buf d60 allot
    \ Main
    : setup
    R1 d12 0 do dup pinout 1+ loop drop
    EN pinhi
    variable cog d28 allot
    \ Display 1 line for upper
    \ ( n1 n2 -- )  n1:32bits n2:line number
    : line_sh_out_u
    EN pinhi
                  \   outa COG@ .
                      outa COG@ over 4 * cog + L!     \ check [C B A]
    LnA lshift
    outa COG@ line_m and or outa COG!
    h8000_0000
    d32 0 do
         2dup and
         if R1 pinhi else R1 pinlo then
         CLK pinhi CLK pinlo
         1 rshift
    loop
    LE pinhi LE pinlo
    EN pinlo
    2drop
    \ Display 1 line for lower
    : line_sh_out_l
    EN pinhi
    LnA lshift
    h8000_0000
    d32 0 do
         2dup and
         if R2 pinhi else R2 pinlo then
         CLK pinhi CLK pinlo
         1 rshift
    loop
    LE pinhi LE pinlo
    EN pinlo
    2drop
    \ Scan Adafruit matrix 16X32
    : matrix_scan
    setup
    d_buf
    begin
         dup
         8 0 do
              dup
              L@ i line_sh_out_u
              4+
         loop
         8 0 do
              dup
              L@ i line_sh_out_l
              4+
         loop
         drop
         fkey? swap drop
    until
    drop
    : demo
    d_buf dup
    h11111111 swap L!
    4+ dup h22222222 swap L!
    4+ dup h44444444 swap L!
    4+ dup h88888888 swap L!
    4+ dup h11111111 swap L!
    4+ h88888888 swap L!
    \ c" matrix_scan" 0 cogx
     matrix_scan
    640 x 480 - 196K
    640 x 480 - 159K
    edited 2014-06-18 03:30
    Does it work the first time through, and then display the line the second time?
    Or does it work on cog 6, and not on cog 0?
    In both those cases I would guess something didn't get initialized.
    Or the pin states that are set by one cog are not reset by the other cog.
    If you reboot, and reload the code and run it on cog 0 without running on cog 6, does it have a different result?
    That's all that comes to mind at the moment
    edited 2014-06-18 05:25
    Sorry, it was my mistake.
    outa register on cog6 was h1C0 by 'demo'.
    I forgot to clear outa register on cog6.
    So, [C B A]value is always [1 1 1] although outa register on cog0 change.
    edited 2014-06-24 21:53
    Hi.
    8x8-font are displayd on upper section of Adafrui matrix16x32.
    This is only 7colors.
    Character data(including [A B C]line and [R1 G1 B1] and EN) are placed inside matrix_array(2048bytes).
    'test2' continue to scan matrix_array(2048bytes).
    But dot with [0 0 0] of [R1 G1 B1] is a little on.
    Maybe I think this is ghost.
    http://youtu.be/6UtN6g117GE
    \ Scan matrix_array to display
    : test2
    hFFF dira COG!
    matrix_array
    begin
         dup
          d16 0 do
              d32 0 do
                   a_matrix_16x32_2
              loop
              LE pinhi LE pinlo
              EN pinlo
         loop
         drop
         fkey? swap drop
    until
    drop
    fl
    \ ( n1 -- n2 )  n1:address of buffer
    build_BootOpt :rasm
              rdlong    outa , $C_stTOS
              or        outa , __clk
              add       $C_stTOS , # 4
              jexit
    __clk
         h200
    ;asm a_matrix_16x32_2
    Adafruit_matrix_0.2_2 is not normal code.
    Not defined 2048bytes about array by code.
    Before loading;
    reboot
    Prop0 Cog6 ok
    variable matrix_array
    matrix_array .
    17616 Prop0 Cog6 ok   <-- if dev-kerenel, it should be 17616.
    19663 here W!             <-- 'here' changed
    Loaing Adafruit_matrix_0.2_2
    Messages in TeraTerm should stop during loading code.
    After hitting return-key, loading restart and finish.
    Execute 'demo'
    edited 2014-06-25 07:10
    Updated Adafruit_matrix.
    Before loading Adafruit_matrix_0.3, execute below;
    reboot
    Prop0 Cog6 ok
    Prop0 Cog6 ok
    matrix_array .
    17616 Prop0 Cog6 ok      <-- If Dev-kernel, it should be 17616.
    d17616 d1024 + here W!
    Prop0 Cog6 ok
    If messages stop in TeraTerm window, it finish by hitting return-key.
    http://youtu.be/iTCAMwFCZe4
    edited 2014-06-26 03:25
    Modified 'demo3's code a little.
    edited 2014-06-27 00:03
    Printed out string on Adafruit matrix16x32.
    Printed string"May the Forth be with you. " with green(2) on upper section(0) of Adafruit matrix16x32.
    c" May the Forth be with you. " 2 0 adafruit_str
    edited 2014-06-28 07:53
    caskaz wrote: »
    Would you please include the forth code for the optimize instruction
    a_matrix_16x32_2
    as a comment if a version 0.5 is posted?
    Is wvariable n an extra loop counter for the third outter loop? I always cringe when I see single character variable names.
    I respect i and j for loop counters, those being the names used since the days when names were limited to 3 characters.
    But all other names should have some clue at to what they are used for.
    Other than than, very nice code, and very cool demo!
    Could you maybe creat a wiki page? This is too cool to let it get lost.
    edited 2014-06-28 16:50
    Hi prof_braino.
    n of 'prepare_array'is outer loop counter.
    This indicate upper matric(8x32) or lower matrix(8x32).
    \ Set each Long data of matrix_array to outa
    \ ( n1 -- n2 )  n1:address of matrix_array  n2:n1+2   <--- correct
    lockdict create a_matrix_16x32_2 forthentry
    $C_a_lxasm w, h118  h113  1- tuck - h9 lshift or here W@ alignl h10 lshift or l,
    z4ixZB l, z1bix[N l, z20yPO2 l, z1SV01X l, z80 l,
    freedict
    fl
    build_BootOpt :rasm
              rdword    outa , $C_stTOS
              or        outa , __clk
              add       $C_stTOS , # 2
              jexit
    __clk
         h200
    I'm writing code for printing ROM-chip font(16x16[JIS0208], 8x16[ASCII]).
    Code for character finish next.
    After it, I want to display full color picture.
    I finded out Rayman's thread"Propellering the Adafruit 16x32xRGB LED array".
    Maybe I think it cannot translate directly because this use "long OutputArray[32*8*8]"(8192bytes) on Adafruit mateix(16x32).
    I cannot understand it yet.
