low current measurements
Hi guys,
I'm having troubles measuring low currents (<300mA).
I'm using an Allegro ACS712 hall-effect probe connected with a MPC3208 12bit ADC and then to the Propeller chip.
What I have is non linearity of I vs V, as you can see from the graph below a certain value.
Any suggestions?
Tnx,
G.
Any suggestions?
Tnx,
G.
The source is a VAC usually 220V.
The V is linear and very well measured with the output of a PCB transformer (0-230V => 0-6V).
The I comes from the Vout pin of an ACS712-05 Allegro hall-effect sensor chip, that receives a +5V and a Ground references.
VAC => ACS712 => resistor LAMP
V=RI I need to measure independently both V and I.
Hope that clears things out.
Schematic?
More seriously though, at least the response is monotonic so you should be able to calibrate it out if needed.
Marty
Now, the hypothesis here is that the Ohm effect of changing the resistor value with the increase of temperature, that goes with the current, breaks the linearity...and that happens with low current in that it just then when it starts to load the lamps and increase their temperature...uhm...
still thinking....perhaps then the current sensed is RIGHT, in that is R that changes too...
what do I do?
for the schematics, I think I was clear enough, or am I not? please be more esplicit,
thank you
G.
a picture tells more than a 1000 words ...
here
- is the whole setup grounded ?
- what is your intention to measure?
- power meter (Watts)
- phase angle ?
- resistance ?
The pins on the lower side of the scheme are inputs and outputs.
+5V provides power to the chip
GND is ground
V and I are the outputs toward the ADC
The power circuits is grounded in that VIN is connected to the mains and therefore grounded. It is a VARIAC.
I just want to measure V and I, independently to the load applied.
When you get results that puzzle, it is a good idea to reality check your setup with a Multimeter.
ie check what the actual current flowing is, not what you think it might be.
2 Multimeters would allow you to read both I and V and plot those, with your own metering paths.
Yes, that got me too. Initially I thought the y axis was current and the x axis was a changing load, eg a variable resistor. But thinking about it more, I think the x axis might be Time. Is that correct?
If so, it is the expected result from a lightbulb.
"What I have is non linearity of I vs V, as you can see from the graph below a certain value. "
With current on the x axis the graph shows current increasing rapidly with applied voltage until the filament starts to heat up. At that point the resistance has increased and the rate of current increase slows and becomes more linear.
It would be simple to plot the change of the resistance vs power applied using R = E / I and P = E x I from the current graph data points.
Yes, the resistance of the filament will be about 10 times less at room temp than at white-hot. Look up
the resistivity of tungsten against temperature if you want to double-check. The actual resistance is
proportional to the reciprocal of the slope of a line from the origin to the point in question.
There is no simple relation between current and temperature since the filament will be losing heat by
both radiation and conduction and convection, all of which have different dependencies on temperature.
The slope of the curve is related to the rate of change of conductivity with voltage (which controls
temperature), and I wouldn't call it linear!
power depends on resistance and current (or voltage).
temperature depends on power (complex non linear fashion)
resistivity of tungsten depends on temperature (maybe quasi-linear, but will be
potentially discontinuous at phase transitions).
You are plotting current against voltage as a way of displaying 1/resistance, so there is a whole chain
of non-linear relationships in there. And the slope of the curve represents something rather convoluted
(do the algebra if you have a spare hour!)
You'd normally want to plot resistance against something, preferably temperature (but thats tricky to measure
especially as a filament is different temperatures along its length!).
That's the physicists approach at least.
As an EE all you need to know is the maximum current transient on switch on and the steady state current
at nominal voltage, surely? Or perhaps bulb life against voltage over-drive?
The Independent variable goes on the X-axis.
The Dependent variable goes on the Y-axis.
ie: d vs. t (distance versus time)
