For the first FPGA version, I'll just have the following:
RDINIT D/#19bit - wait until FIFO write done, set read mode, begin reloading FIFO from address D[18:2] with byte offset D[1:0]
RDLONG D - read longfrom FIFO
RDWORD D - read wordfrom FIFO
RDBYTE D - read bytefrom FIFO
WRINIT D/#19bit - wait until FIFO write done, set write mode at address D[18:2] with byte offset D[1:0]
WRLONG D/# - write longto FIFO *
WRWORD D/# - write wordto FIFO *
WRBYTE D/# - write byteto FIFO *
* optional filter mode doesn't write bytes when they are $FF
I need to get this FIFO stuff working properly before I can add the random accesses.
I think you meant RDINIT D/#19bit - wait until FIFO read done ?
Just read later message that says there is now a single FIFO.
The Skip opcodes are gone ? (not needed any more ?)
These FIFO opcodes probably need spacial names ? - to leave the P1 names for random access opcodes ?
Something like
RDFINIT D/#19bit - wait until FIFO read done, set read mode, begin reloading FIFO from address D[18:2] with byte offset D[1:0]
RDFLONG D - read longfrom FIFO
RDFWORD D - read wordfrom FIFO
RDFBYTE D - read bytefrom FIFO
WRFINIT D/#19bit - wait until FIFO write done, set write mode at address D[18:2] with byte offset D[1:0]
WRFLONG D/# - write longto FIFO *
WRFWORD D/# - write wordto FIFO *
WRFBYTE D/# - write byteto FIFO *
The more I think about it, the more I like these FIFO reads/writes, especially as they allow non-aligned access.
Questions:
Can the RD call's set Z and C if zero, and the highest bit, like the P2 instructions?
Does an RDINIT flush any data from the FIFO that may still be in it? Or does it wait until the read fifo is empty?
Do writes have priority over reads?
It's one FIFO that can be either in hub READ or hub WRITE mode.
In READ mode, it just fills up and tops itself off whenever the opportunity arises, so there's no need to suppose that all the data is wanted. You can redirect it at any time.
Before redirecting the FIFO, though, for either READ or WRITE mode, it must wait for any pending WRITEs to finish.
The RDxxxx can set Z if the result is 0 and put the MSB of the data read (byte/word/long) into C.
Thanks for the clarification. Sounds like you plan to add random accesses in the next phase. Will they be similar to the way P1 works or will they require multiple instructions for a single access?
We'll have single instructions which do the whole thing. That's the plan, anyway.
Here's the FIFO in Verilog. It will change a little to fit within the context of use, but you can see that it uses only flops and one-stage mux's - nothing complicated:
// cog fifo
module cog_fifo
input clk,
input clear,
input write,
input [31:0] d,
input read,
output [31:0] q,
output empty,
output full
// fifo depth
reg [4:0] s;
assign empty = ~|s; // once not empty, stays not empty, no matter read demand
assign full = s[4]; // indicate 'full' four clocks early, four more levels to go
wire [4:0] s_inc = s + 1'b1;
wire [4:0] s_dec = s - 1'b1;
wire rd = read && !empty; //read okay whennot empty
wire wr = write && (!full || rd); //writewhen full is okay if concurrent read
wire [4:0] wr_level = wr && rd ? s_dec // concurrent readandwrite
: s; // just a write
always @(posedge clk)
if (clear || (rd ^ wr)) // read + write = no change
s <= clear ? 0 // clear = 0
: wr ? s_inc // write = +1
: s_dec; //read = -1
// fifo data
reg [19:0][31:0] fifo;
wire [19:0][31:0] fifo_pop = {d, fifo[19:1]};
genvar i;
generate
for (i=0; i<20; i++)
begin : cog_fifo_gen
if ((rd || wr) && i <= wr_level)
fifo[i] <= wr && wr_level == i ? d
: fifo_pop[i];
end
endgenerate
assign q = fifo[0];
endmodule
And keeps things sane, as there's no arbitration to worry about.
Makes sense. Is it Dual Port RAM & 20 deep, or 16 ? I could find no use case that needed more than 16 ?
(but I did find one special phase case that needed a pass-thru / bypass that is easy to catch )
I figured the most important thing was being able to start at any boundary - that involves the byte-write-enables. When the write completes, there is some byte-write-enable consideration, too.
There can be a special mode where $FF byte values don't get written. That would allow sprites to overlay directly on byte-sized scan line data, while permitting transparency in some pixels.
Because the read commands must be given a few cycles ahead of where their resultant data enter the FIFO, some latency must be accommodated - hence, the four extra levels and early 'full' indicator. Now I'm wondering if the 'full' indicator should just be signalled when the FIFO is 12 deep. What do you think?
Will it be possible to poll FIFO "write-full" or "read-empty" states to enable non-blocking FIFO access?
The beauty of this FIFO business is that the read can never run dry and the write can never overflow. The hub-side connections are running at one long per clock, remember.
I may not have understood your question, though. Most of the time, the read buffer will be full and the write buffer will be empty. So, random accesses should have lots of opportunities.
Best to test it ? - the one special case I found with my earlier Tag FIFO checks @ 16 deep, was fSys/1 streaming, with a +16c delayed read start which meant the next cycle pass had Write and Empty on the same slot clock.
Here is the earlier flow-test dump, from a QuickBasic decision simulator I coded, showing the special case Tag FIFO data flows & decisions
when in hubexec, just RDFLONG into the instruction pipeline.
That's the plan. And it doesn't matter if a hub exec instruction takes more than one clock, which would have been problematic if we had tried to sync the PC the hub slots.
What about PTRA and PTRB, though? They've become somewhat redundant.
Need to test it ? - the one special case I found with a 16 deep, was fSys/1 streaming, with a +16c delayed read start which meant the next cycle pass had Write and Empty on the same slot clock.
Here is the flow-test dump, from a QuickBasic deciison simulator I coded, showing and the special case
Sensed with a 5 bit address compare on the Dual port Ram Pointers (otherwise SysCLK 19 triggers a bypass)
Neat! We'll need to keep at least two longs ready in the FIFO's flop outputs, though, for early use in the cycle. The data arriving from the hub RAM is very late in the cycle - too late to just forward through some gates.
I think they are still needed, especially in hubexec mode.
hubexec will keep the fifo busy, so compiled code will use PTRA/PTRB for hub stack, array access etc with the random access instructions. A single FIFO would thrash horribly without PTRA/B.
If you want to get rid of PTRA/PTRB, we would need multiple FIFO's, one for hubexec, and at least one for data access (more would be better, but at least one works) and even then we would miss the indexed PTRA/PTRB mode for stack frames (local vars)
- as long as it compiles to small silicon, the details do not matter too much
Won't the FIFO still need to include/queue the 4 Byte Write Enables to handle 8/16/32 and split writes ? (or is that coded elsewhere?)
There would be cases where both would be very useful, so why would direct flush the FIFO ?
Someone would not really have the same address in both opcodes (would they ?)
I was hoping the direct instructions *wouldn't* flush the FIFO. Just asking to verify.
I think these wr_en signals are decoded from the 2 lsb of the address which, I presume, should also determine the byte 8bit-left-shift multiplier
I don't think Addr alone has enough info. an Aligned byte, looks the same as an aligned word or long, and for non-aligned which Chip hopes to support it gets even messier..
You could get
xxxL
LLLx
xxLL
LLxx
xxxW
Wxxx
xWWx
as well as the more usual
Bxxx
xBxx
xxBx
xxxB
WWxx
xxWW
LLLL
I think that needs 4 BWE signals, to do what is needed (1 o 2 or 3 or 4 bytes changed ) in the single clock available.
Something like
RDFINIT D/#19bit - wait until FIFO read done, set read mode, begin reloading FIFO from address D[18:2] with byte offset D[1:0] RDFLONG D - read long from FIFO RDFWORD D - read word from FIFO RDFBYTE D - read byte from FIFO WRFINIT D/#19bit - wait until FIFO write done, set write mode at address D[18:2] with byte offset D[1:0] WRFLONG D/# - write long to FIFO * WRFWORD D/# - write word to FIFO * WRFBYTE D/# - write byte to FIFO *It's one FIFO that can be either in hub READ or hub WRITE mode.
ie simplex, not duplex. Saves important silicon I guess.
jmg, There is only one per cog, see post above yours
Bill, the write has priority to finish before the read starts.
// cog fifo module cog_fifo ( input clk, input clear, input write, input [31:0] d, input read, output [31:0] q, output empty, output full ); // fifo depth reg [4:0] s; assign empty = ~|s; // once not empty, stays not empty, no matter read demand assign full = s[4]; // indicate 'full' four clocks early, four more levels to go wire [4:0] s_inc = s + 1'b1; wire [4:0] s_dec = s - 1'b1; wire rd = read && !empty; // read okay when not empty wire wr = write && (!full || rd); // write when full is okay if concurrent read wire [4:0] wr_level = wr && rd ? s_dec // concurrent read and write : s; // just a write always @(posedge clk) if (clear || (rd ^ wr)) // read + write = no change s <= clear ? 0 // clear = 0 : wr ? s_inc // write = +1 : s_dec; // read = -1 // fifo data reg [19:0][31:0] fifo; wire [19:0][31:0] fifo_pop = {d, fifo[19:1]}; genvar i; generate for (i=0; i<20; i++) begin : cog_fifo_gen always @(posedge clk) if ((rd || wr) && i <= wr_level) fifo[i] <= wr && wr_level == i ? d : fifo_pop[i]; end endgenerate assign q = fifo[0]; endmodule(but I did find one special phase case that needed a pass-thru / bypass that is easy to catch )
Makes hubexec super easy!
jmp/call/ret/branches just do an RDINIT internally
Lower performance branches (that are taken) but in-line non-hub code should run full speed.
Branch not taken: 1 clock
Branch taken: 2..17 clocks (I think), say average of 8
Assuming on average one in eight instructions is a branch that is taken:
7/8+8/8 cycles for 8 instructions
15/8 * 100 ... a bit better than 50MIPS!
fSysDivN = 1 HUB_RdPtr = 3 ReadDelay = 19 TestClks = 384 WrInfo : ---- => Slot Rotate miss WrInfo : H->F => Copy Hub to Fifo, Nibble Address WrInfo : **** => Skip due to TM_FIFO Waiting on Read RdInfo : ddd => Pre-Trigger StartRd Delay RdInfo : F->P => Fifo to Pin with Contents in HEX RdInfo : >>>> => HUB to Pin Direct pass thru, Contents in HEX RdInfo : www => Read Wait, set by fSys/N RdInfo : EEE => Read Data not ready, Error if seen after started SysClk WrInfo Wa RdInfo Rv HUB_RdPtr FifoRdPtr 0 ---- ddd 0003H 0003H 1 ---- ddd 0003H 0003H 2 ---- ddd 0003H 0003H 3 H->F 3 ddd 0003H 0003H 4 H->F 4 ddd 0004H 0003H 5 H->F 5 ddd 0005H 0003H 6 H->F 6 ddd 0006H 0003H 7 H->F 7 ddd 0007H 0003H 8 H->F 8 ddd 0008H 0003H 9 H->F 9 ddd 0009H 0003H 10 H->F A ddd 000AH 0003H 11 H->F B ddd 000BH 0003H 12 H->F C ddd 000CH 0003H 13 H->F D ddd 000DH 0003H 14 H->F E ddd 000EH 0003H 15 H->F F ddd 000FH 0003H 16 H->F 0 ddd 0010H 0003H 17 H->F 1 ddd 0011H 0003H 18 H->F 2 ddd 0012H 0003H 19 **** F->P 0003H 0013H 0003H 20 ---- F->P 0004H 0013H 0004H 21 ---- F->P 0005H 0013H 0005H 22 ---- F->P 0006H 0013H 0006H 23 ---- F->P 0007H 0013H 0007H 24 ---- F->P 0008H 0013H 0008H 25 ---- F->P 0009H 0013H 0009H 26 ---- F->P 000AH 0013H 000AH 27 ---- F->P 000BH 0013H 000BH 28 ---- F->P 000CH 0013H 000CH 29 ---- F->P 000DH 0013H 000DH 30 ---- F->P 000EH 0013H 000EH 31 ---- F->P 000FH 0013H 000FH 32 ---- F->P 0010H 0013H 0010H 33 ---- F->P 0011H 0013H 0011H 34 ---- F->P 0012H 0013H 0012H 35 H->F 3 >>>> 0013H 0013H 0013H << Rd=Wr special case 36 H->F 4 >>>> 0014H 0014H 0014H 37 H->F 5 >>>> 0015H 0015H 0015H 38 H->F 6 >>>> 0016H 0016H 0016HSensed with a 5 bit address compare on the Dual port Ram Pointers (otherwise SysCLK 19 triggers a bypass)That's the plan. And it doesn't matter if a hub exec instruction takes more than one clock, which would have been problematic if we had tried to sync the PC the hub slots.
Yeah, I agree.
- deterministic (16 clock / 8 instruction) cycles apart in all cases
- turbo (writes as soon as it can, does not wait like deterministic)
Furthermore, a single level write buffer for turbo mode would improve performance even more.
direct/random hub access should not flush the FIFO for best performance.
The direct access instructions would work around the FIFO accesses.
I just added those four bits. What I had posted was intended for the read FIFO, but now I'm making it handle both read and write.
You could get
xxxL LLLx or xxLL LLxx or xxxW Wxxx or xWWx as well as the more usual Bxxx xBxx xxBx xxxB WWxx xxWW LLLLI think that needs 4 BWE signals, to do what is needed (1 o 2 or 3 or 4 bytes changed ) in the single clock available.
