$2.49 38 kHz IR Proximity Sensor Module
I ordered two. http://www.ebay.com/itm/IR-Infrared-Obstacle-Avoidance-Sensors-Module-for-Arduino-Smart-Car-Robot-HM-/400662837159
3-6V, two trimpots (prolly IR frequency and intensity) with active-low digital output from 38 kHz IR receiver module.
Lots of other sensors linked on that page.
Now don't forget to budget a dollar for the twins' college fund!
Um, it's going into an escrow account?
If I was really mean, I'd send you gift cards for the twins to use at Chuck E Cheese!
Well then , you better do a side trip to SC and visit doggiedoc, and the another to CT to visit me!
1/2" snow yesterday, do you remember what that looks like ?
62 today, go figure.
Another solution would be to make a small PCB for BoeBot to make a sensor daughterboard using the existing components; just soldering them down would be an improvement. Of course, that PCB might cost as much as this sensor, which has an onboard IC for generating the IR pulses, and thus may require one less pin (two pins for two sensors) than the stock configuration. Will advise upon receipt.
