Questions about the AES Encryption object 137 written by Mark_T — Parallax Forums
Don MDon M Posts: 1,654
edited 2014-03-14 04:51 in Propeller 1
I have been playing around trying to understand this object. http://obex.parallax.com/object/137
It seems fairly straight forward and I'm trying to verify the results shown on the terminal display with an online AES encrypt / decrypt.
I am using this website: http://aes.online-domain-tools.com/
Here is a couple examples that is shown on the terminal:
Monte Carlo 128 bits
COUNT = 0
KEY = 139a35422f1d61de3c91787fe0507afd
PLAINTEXT = b9145a768b7dc489a096b546f43b231f
CIPHERTEXT = d7c3ffac9031238650901e157364c386
COUNT = 1
KEY = c459caeebf2c42586c01666a9334b97b
PLAINTEXT = d7c3ffac9031238650901e157364c386
CIPHERTEXT = bc3637da2daf8fcf7c68bb28c143a0a4
I entered the above key and plaintext from count 0 into the online encrypt and I don't get the the same cipher result that is shown on the terminal. The Monte Carlo method that he set up in the demo uses ECB mode. I tried all the different combinations of plaintext and hex and I never get the same result as shown on the terminal.
What am I doing wrong or don't understand about this?
Thanks.
Don
    edited 2014-03-12 23:52
    I wonder if some of the problem might lie in the Propeller expecting you to use ASCII.
    If you are using 'cut and paste' to transfer data from your computer, you might be providing UTF-16 (in Windows) or UTF-8 in Linux.
    The relationship is that UTF-16 and UTf-8 take more than one byte to represent a character. So results might vary. UTF-16 and UTF-8 are NOT the same.
    Consider setting up a rigorous ASCII scheme or a rigorous UTF scheme for testing.
    So, there is a secondary issue that encrypted text has to somehow anticipate which font format is expected.
  • Don MDon M Posts: 1,654
    edited 2014-03-13 08:05
    What is odd is that in the demo he has another method called "VaryKey(bits)"
    Here is a few of the responses that print on the terminal from that method:
    COUNT = 80
    KEY = ffffffffffffffffffff800000000000
    PLAINTEXT = 00000000000000000000000000000000
    CIPHERTEXT = 545d50ebd919e4a6949d96ad47e46a80
    COUNT = 81
    KEY = ffffffffffffffffffffc00000000000
    CIPHERTEXT = dbdfb527060e0a71009c7bb0c68f1d44
    COUNT = 82
    KEY = ffffffffffffffffffffe00000000000
    CIPHERTEXT = 9cfa1322ea33da2173a024f2ff0d896d
    Now if you copy and paste the key and Plaintext into these online encryptors you do get the same Ciphertext result using the ECB method. So not sure that your explanation makes total sense.
    Here are some more results from the method "VaryPlain(bits)".
    COUNT = 105
    KEY = 00000000000000000000000000000000
    PLAINTEXT = ffffffffffffffffffffffffffc00000
    CIPHERTEXT = 7678f3a833f19fea95f3c6029e2bc610
    COUNT = 106
    PLAINTEXT = ffffffffffffffffffffffffffe00000
    CIPHERTEXT = 3aa426831067d36b92be7c5f81c13c56
    COUNT = 107
    PLAINTEXT = fffffffffffffffffffffffffff00000
    CIPHERTEXT = 9272e2d2cdd11050998c845077a30ea0
    And they also produce the same correct Ciphertext using copy and paste.
  • Mark_TMark_T Posts: 1,981
    edited 2014-03-13 16:55
    No idea about that site, the test vectors are those given by NIST:
    http://en.wikipedia.org/wiki/Advanced_Encryption_Standard#Test_vectors
    edited 2014-03-13 19:06
    Mark- I'm having a hard time understanding how to use this.
    If I give you an example could you show me how to use it with your object?
    Here's some data:
    Key: 70629CC47F4614712456569D5200DA77
    IV: 309A22336A8EA576F6A3BA9DD97FD20E
    Plaintext: 322E30302C5230322C4330312C4D49443A464646464646464600000000000000
    Method: CBC Encrypt
    Also same key & plaintext using ECB Encrypt.
    The key and IV were generated on my Mac using ssh.
    Here's what I tried and I don't believe its correct because if I compare it to the same data input in this website I get different results: http://aes.online-domain-tools.com/
    VAR
      byte buffer[180] 'buffer to assemble output strings
      long bpos
      long nn
      long ii
      long jj
      long plaintext [4*4]
      long ciphertext [4*4]
      byte thekey [16] '[32]
      long initvec [4]
      long check [4]
      long before
      long after
      repeat nn from 0 to 15
        thekey[nn] := byte[@ExKey][nn]
      repeat nn from 0 to 7 '15
        plaintext[nn] := long[@ExPlain][nn]
      repeat nn from 0 to 3
        initvec[nn] := long[@ExIV][nn]
      aes.Start
      aes.SetKey (128, @thekey)
      debug.str(string("Key: "))
        debug.hex(byte[@TheKey][nn], 2)
      debug.tx(13)
    '  aes.CBCEncrypt (@ExPlain, @ciphertext, 4, @ExIV)
      aes.ECBEncrypt (@ExPlain, @ciphertext)
      debug.str(string("IV: "))
        debug.hex(long[@InitVec][nn], 8)
      debug.tx(13)
      debug.str(string("Plain: "))
        debug.hex(long[@PlainText][nn], 8)
      debug.tx(13)
      debug.str(string("Cipher: "))
        debug.hex(long[@CipherText][nn], 8)
      debug.tx(13)
    DAT
    ExKey         byte $70, $62, $9C, $C4, $7F, $46, $14, $71
                  byte $24, $56, $56, $9D, $52, $00, $DA, $77
    ExPlain       long $322e3030
                  long $2c523032
                  long $2c433031
                  long $2c4d4944
                  long $3a464646
                  long $46464646
                  long $46000000
                  long $00000000
                  long $00000000
                  long $00000000
                  long $00000000
                  long $00000000
                  long $00000000
                  long $00000000
                  long $00000000
                  long $00000000
    ExIV          long $309A2233
                  long $6A8EA576
                  long $F6A3BA9D
                  long $D97FD20E
    Very much appreciate any help here.
    Thanks.
    Don
    edited 2014-03-13 19:16
    Also why do you reverse the order of the longs when you print them out with the "prinarr" method?
    This long $322e3030 in the DAT section becomes 30302e32 when printed out with your methods. Do they need to be entered that way into the encryption methods? I don't understand why this is done.
    Appreciate any help with this.
    Thanks again.
    Don
    edited 2014-03-13 20:04
    Ok I think I may have figured out the ECB method. If I use your prinarr method to reverse the order of each long and then run the encryption now I get the same result as on line...
    So a little more playing to do to fully understand it but any advice greatly appreciated.
  • ersmithersmith Posts: 6,285
    edited 2014-03-14 03:37
    Don M wrote: »
    I think you'll find that the Propeller is a little endian machine, so:
       long $11223344
    is stored in memory as $44, $33, $22, $11 (in that order).
    edited 2014-03-14 03:52
    Ok that gives me a clue as to what I think I need to do. Stay tuned...
    Cryptography papers are excruciatingly careful to explain any order or endianness assumptions.
    The common practice is to treat all values as byte vectors (array or octets) or sometimes
    bit-vectors. Thus you would expect all test vectors to be in memory in byte ordering whatever
    the processor.
