Questions about the AES Encryption object 137 written by Mark_T
I have been playing around trying to understand this object. http://obex.parallax.com/object/137
It seems fairly straight forward and I'm trying to verify the results shown on the terminal display with an online AES encrypt / decrypt.
I am using this website: http://aes.online-domain-tools.com/
Here is a couple examples that is shown on the terminal:
Monte Carlo 128 bits
COUNT = 0
KEY = 139a35422f1d61de3c91787fe0507afd
PLAINTEXT = b9145a768b7dc489a096b546f43b231f
CIPHERTEXT = d7c3ffac9031238650901e157364c386
COUNT = 1
KEY = c459caeebf2c42586c01666a9334b97b
PLAINTEXT = d7c3ffac9031238650901e157364c386
CIPHERTEXT = bc3637da2daf8fcf7c68bb28c143a0a4
I entered the above key and plaintext from count 0 into the online encrypt and I don't get the the same cipher result that is shown on the terminal. The Monte Carlo method that he set up in the demo uses ECB mode. I tried all the different combinations of plaintext and hex and I never get the same result as shown on the terminal.
What am I doing wrong or don't understand about this?
Thanks.
Don
COUNT = 0
COUNT = 1
Thanks.
Don
If you are using 'cut and paste' to transfer data from your computer, you might be providing UTF-16 (in Windows) or UTF-8 in Linux.
The relationship is that UTF-16 and UTf-8 take more than one byte to represent a character. So results might vary. UTF-16 and UTF-8 are NOT the same.
Consider setting up a rigorous ASCII scheme or a rigorous UTF scheme for testing.
So, there is a secondary issue that encrypted text has to somehow anticipate which font format is expected.
Here is a few of the responses that print on the terminal from that method:
COUNT = 80
KEY = ffffffffffffffffffff800000000000
PLAINTEXT = 00000000000000000000000000000000
CIPHERTEXT = 545d50ebd919e4a6949d96ad47e46a80
COUNT = 81
KEY = ffffffffffffffffffffc00000000000
CIPHERTEXT = dbdfb527060e0a71009c7bb0c68f1d44
COUNT = 82
KEY = ffffffffffffffffffffe00000000000
CIPHERTEXT = 9cfa1322ea33da2173a024f2ff0d896d
Now if you copy and paste the key and Plaintext into these online encryptors you do get the same Ciphertext result using the ECB method. So not sure that your explanation makes total sense.
Here are some more results from the method "VaryPlain(bits)".
COUNT = 105
KEY = 00000000000000000000000000000000
PLAINTEXT = ffffffffffffffffffffffffffc00000
CIPHERTEXT = 7678f3a833f19fea95f3c6029e2bc610
COUNT = 106
PLAINTEXT = ffffffffffffffffffffffffffe00000
CIPHERTEXT = 3aa426831067d36b92be7c5f81c13c56
COUNT = 107
PLAINTEXT = fffffffffffffffffffffffffff00000
CIPHERTEXT = 9272e2d2cdd11050998c845077a30ea0
And they also produce the same correct Ciphertext using copy and paste.
http://en.wikipedia.org/wiki/Advanced_Encryption_Standard#Test_vectors
If I give you an example could you show me how to use it with your object?
Here's some data:
Key: 70629CC47F4614712456569D5200DA77
IV: 309A22336A8EA576F6A3BA9DD97FD20E
Plaintext: 322E30302C5230322C4330312C4D49443A464646464646464600000000000000
Method: CBC Encrypt
Also same key & plaintext using ECB Encrypt.
The key and IV were generated on my Mac using ssh.
Here's what I tried and I don't believe its correct because if I compare it to the same data input in this website I get different results: http://aes.online-domain-tools.com/
VAR byte buffer[180] 'buffer to assemble output strings long bpos long nn long ii long jj long plaintext [4*4] long ciphertext [4*4] byte thekey [16] '[32] long initvec [4] long check [4] long before long after repeat nn from 0 to 15 thekey[nn] := byte[@ExKey][nn] repeat nn from 0 to 7 '15 plaintext[nn] := long[@ExPlain][nn] repeat nn from 0 to 3 initvec[nn] := long[@ExIV][nn] aes.Start aes.SetKey (128, @thekey) debug.str(string("Key: ")) repeat nn from 0 to 15 debug.hex(byte[@TheKey][nn], 2) debug.tx(13) ' aes.CBCEncrypt (@ExPlain, @ciphertext, 4, @ExIV) aes.ECBEncrypt (@ExPlain, @ciphertext) debug.str(string("IV: ")) repeat nn from 0 to 3 debug.hex(long[@InitVec][nn], 8) debug.tx(13) debug.str(string("Plain: ")) repeat nn from 0 to 7 '15 debug.hex(long[@PlainText][nn], 8) debug.tx(13) debug.str(string("Cipher: ")) repeat nn from 0 to 15 debug.hex(long[@CipherText][nn], 8) debug.tx(13) DAT ExKey byte $70, $62, $9C, $C4, $7F, $46, $14, $71 byte $24, $56, $56, $9D, $52, $00, $DA, $77 ExPlain long $322e3030 long $2c523032 long $2c433031 long $2c4d4944 long $3a464646 long $46464646 long $46000000 long $00000000 long $00000000 long $00000000 long $00000000 long $00000000 long $00000000 long $00000000 long $00000000 long $00000000 ExIV long $309A2233 long $6A8EA576 long $F6A3BA9D long $D97FD20EVery much appreciate any help here.
Thanks.
Don
This long $322e3030 in the DAT section becomes 30302e32 when printed out with your methods. Do they need to be entered that way into the encryption methods? I don't understand why this is done.
Appreciate any help with this.
Thanks again.
Don
So a little more playing to do to fully understand it but any advice greatly appreciated.
I think you'll find that the Propeller is a little endian machine, so: is stored in memory as $44, $33, $22, $11 (in that order).
The common practice is to treat all values as byte vectors (array or octets) or sometimes
bit-vectors. Thus you would expect all test vectors to be in memory in byte ordering whatever
the processor.
