Real Color Displays RC880 - Page 2 — Parallax Forums
2»
  • huskernuthuskernut Posts: 3
    edited 2008-10-19 04:12
    Thanks for the information, I have joined that group
  • dbsdbs Posts: 1
    edited 2010-04-03 18:42
    are you still looking to repair your rc880? because i have an rc880 with no leads and i have no idea if it work but you are welcome to it for postage costs
  • jimdp219jimdp219 Posts: 4
    edited 2014-03-04 15:52
    I have the original software for the RC880 multicolor it runs on XP,Win 7 ran it on both. I also have the pin out of the DB9 com port to telephone jack on the back of the sign. It runs great then I tried a USB to Com port converter and it worked great.
    Also have the original manual if anyone needs what I have let me know.
  • kelbadokelbado Posts: 4
    edited 2014-03-07 15:53
    jimdp219 wrote: »
    Your post is so current I've got my hopes up that I'll be able to access your manual. A link? Hard copy? Please let me know. I have a working display with remote. Thanks
    edited 2014-03-07 18:11
    Here Is the manual and software link hope this helps.
    https://github.com/Swap-File/rc880
    I did not have the remote so the software is what I used to program it and it is real easy to use once you make a patch cord for it.
    edited 2014-03-08 03:51
    Thanks. I realize Im looking for a written manual for using the remote in programming the sign. Do you have this?
    edited 2014-03-08 04:23
    This is a link to the written manual for the remote all 36 pages of it can you access it?
    edited 2014-03-08 10:07
    YES!!! Thanks. I didn't see it among the other information. I'm on way thanks to you.��
    edited 2014-03-11 19:27
    Got to the password step. Someone has programmed a password so I'm stuck at this step. Any ideas as to access or delete or bypass the existing password?
    edited 2014-03-23 05:48
    Setting or Clearing the password is on page 5. You can use the Factory Reset and send button once you have it connected to a serial port COM1 page 35 using the software it is real easy to use. Make a cord with a db9 female to male cord made for pc from Radio Shack. Open the sign up on the connector end and slice into the white and red wires to the phone jack serial port cable db9-3 red to white and db9-5 yellow to red. Follow the pin out on page 35. Do you have a serial port on your machine? If not you can use a serial port emulator that plugs in with USB connected to the db9 cable.
    http://www.siongboon.com/projects/2006-03-06_serial_communication/DB9%20female.gif
    1024 x 768 - 61K
    1024 x 576 - 44K
  • WhitWhit Posts: 4,194
    oscar - looks great!
    And I LOVE the background music - I will definitely steal this idea for my next video - thanks for making my day!
  • Is it still active?
    Anyone? :)
