28 reels, 2 heads, $5799 PNP getting good reviews
I am probably ordering this in a few days, getting a few more questions answered by the company. Watch this video at almost 5:00 in to see the speed with only 1 head.
28 Reels, 1 tray for bulk parts.
8mm=21 reels,12mm= 4reels ,16mm=2reels
http://www.adafruit.com/blog/2013/06/18/neoden-tm-240a-automatic-pick-and-place-machine/
There is a 16 reel version for under 4k.
Tutorials from the company:
http://www.youtube.com/user/NeoDentech
I am VERY interested in getting one if it works.
Bean
1) Pick and Place Machine TM240A: 1
2) 4 types of nozzle: Totally 6
(Version: XS2, S2, M1, ML1)
3) 8G SD Card: 1
4) Card reader: 1
5) Nozzle disassemble tool: 1 set
6) Adjustment tool for Nylon Spool Wheel: 1
7) Nozzle cleaning tool: 1 set
8) User manual: 1
9) Video training course: 1 set
10) PCB Coordinate file transformation tool: 1
We will be in the market pretty quickly.
Bean
Looks cool, is there a paste dispense option ?
They are really good on emails for support. See contact info on their site. I have not looked into paste dispensing as I use stencils only. I do not think this machine has that option, but I could be wrong on that.
Can you explain the purchase process. I've never ordered anything this expensive from China.
Did you have to wire the money ? How did you pay ? How was their English ? Did you get questions answered ?
Our funds have grown and we are going to order one, but want to make sure we do it right.
Bean
Bean
You won't have to worry about paying for repairs while it's under warranty (except possibly shipping)however, do you know if it requires routine maintenance of any kind? Would going out of alignment be an issue? and can it be adjusted through built in software options? If you had to ship it back for warranty repair, would you have to pay shipping both ways?
Good luck with it.
Do you have any 0402 parts to try ?
Bean
What is your impression now that you have had a couple days to "play" with it ?
Bean
I will definitely post an update when I run my first boards, but that may be end of next week. If you have any specific questions, I am happy to try something on the machine in the mean time with the demo board. On their youtube channel they have a lot of good stuff to watch.
In the manual, there is no "getting started step 1, 2, 3". I will put together my own in house programming tutorial when I figure it out.
My board was cut from a panel and is not perfect with the eagle coords to the edges, but it placed certainly within spec for the solder to manage any offset. In it also very easy to create offsets per position, or per board. In real use, I would make an effort to adjust the offset per panel or board. With the laser it would be fast to make any minor offset tweaks in advance of running. It is easy to specify if you are placing just one small board, or use that board in an XY array. It is very easy to create an offset for the pick location (stack offset). You specify how much to increment the tape with the Feed Set. You can offset the entire board with Origin offset. Parts are input in mm, including the height of the part, rotation in any degree. You can "skip" a part.
The box that it came in makes a good temporary work bench.
Example .csv file that places 4 .01 uf parts.
Here is a crude iphone vid.
http://www.youtube.com/watch?v=BBh0Dz6g78M
If it's not too much trouble, could you post the text file that you used on the machine ?
I'm I little lost as to set the speed to 150%.
Bean
The forum wont allow a .csv so I will post it.
Here is an example that shows a speed line added to the part list. The speed is an imaginary part with a component number of 0, the 10 tells the machine that the speed is 100%. You can insert this line anywhere you want in front of a part with a speed desired for the next component to follow, then put a line after that component to set the speed back.
I included the fiducials in the file for reference. You can enter edit, move the laser to the fiducial marks to see if it is correct, if not then add the offsets to the Origin Offset in the first part of the file. You also can move the needle to each component in the tape and check the pick up location, and make individual offsets in the file as well under stack offset.
We haven't received our funds yet, but when we do the TM240a will be our first purchase.
Bean
Have you had any major problem ?
Do you still think it is well worth the money ?
Just wondering because we might be buying one soon.
Bean
Overall, I am very pleased with the machine. It is really fast, accurate, never misses. My previous method of running boards was my own pick and place CNC modification that was slow and required manual tape incrementation in the feed, plus only one tape could be loaded at a time. So this is a gigantic time saver for me. From about 45 minutes to make a set of boards for one system to less than 5 minutes including stenciling now.
I have been getting emails from them that they are doing a 10% discount right now.
Vid:
http://www.youtube.com/watch?v=iBlIT-kK7Pk
I am really happy with placement of 0603 parts.
Bean
Bean
Why? Well you paid for the machine via a SWIFT wire transfer that generally costs me a total of $45USD in fees ($30 to the sender's bank, $15 to the reciever's bank) when I send money abroad. You would have to have the company collect the customs duties and wire back money to DHL for yet another $45USD in fees.
That would be somewhat silly. It is best to just deal with things the way they are and have the payment for customs onhand for the DHL driver.
