S2 Scribbler - Pimping My Ride - 3D printing "Mini Skirts" now with Gripper Arm - Page 2 — Parallax Forums
2»
    edited 2014-03-04 06:08
    Wow! That's one big arm!
    Is the arm an accessory to the S2 or is the S2 an accessory to the arm?? :smile:
    You are really making me want a 3D printer. My wife is going to come hunt you down if I buy one!!
  • jdoleckijdolecki Posts: 726
    edited 2014-03-04 06:14
    You need to do the scanning leds.
    Like the Cylons had in Battlestar Galacta.
  • GarethGareth Posts: 278
    edited 2014-03-05 12:55
    Final Blenderising has enabled me to slot quite easily the base servo to the bottom skirt piece I have already designed.
    The Arm is working better than I thought (5 servos) and is sufficiently dexterous to pick up pencils (hmmm that give me an idea)
    500 x 281 - 215K
    edited 2014-03-05 13:00
    Good idea to put it on the back. Did you have to add counterweights to the front or can the 3rd wheel handle it ok?
    edited 2014-03-05 13:18
    Your confusing me now..... let me go look.....
    ........ I have done so many mods that i don't know what is front or back .....
    .....The gripper arm now will put it weight onto the single "Boggy" wheel which is ....the back of the S2..(where the Neo Pixels are).
    I had hoped that it would fit on the front however as you point out it did tilt forward lifting the "Boggy" wheel off the floor.
    The arm only weighs 100 grammes thats including the servo even.
    The S2 does not mind calling its back the front and vicaverca, its just the operator/programmer that has to do the brain gymnastics.
    edited 2014-03-05 13:31
    You know, if you give the arm a longer reach, it can reach over the top of the S3.5 like a scorpion!
    OK, I'll go away now........and leave you to your work!
    806 x 638 - 17K
  • W9GFOW9GFO Posts: 4,010
    edited 2014-03-05 13:45
    Gareth wrote: »
    Just FYI: http://en.wikipedia.org/wiki/Bogie
    edited 2014-03-06 14:10
    mindrobots wrote: »
    errrr sorta like this :-
    1024 x 768 - 71K
    edited 2014-03-06 14:24
    Printed a new "Mini Skirt" with cradle for Servo.... so its now mobile...
    I have connected a Mouse which makes it easy to test all movement possibilities :-
    1024 x 768 - 89K
    1024 x 768 - 69K
    1024 x 768 - 78K
    1024 x 768 - 74K
    1024 x 768 - 67K
    1024 x 768 - 73K
    edited 2014-03-06 14:49
    Thanks for correcting my Typo..nice details...
    In my defence it was late and the boggie man (also spelled bogieman, boogeyman, or boogie man) tapped the window........
    Regards G
    edited 2014-03-06 15:43
    Gareth wrote: »
    This is perfect! Now you have a Scribbler that can draw and change colors!!
  • WhitWhit Posts: 4,194
    edited 2014-03-08 15:26
    Very nice Gareth!
  • NikosGNikosG Posts: 705
    edited 2014-03-09 07:12
    The last photo on post #40 is really very cool!!!!!
    The S2 put itself the pen into the pen tube!
    As said "mindrobots" (post #42) the S2 will be able to change pen.
    Gareth,
    print a Pen-Case on top of the S2 with 3 pens (red green blue) and give the S2 the ability to change pen in order to scribble with colors!!!!!
    Amazing work!
    Congratulations!!!!!!
    edited 2014-03-11 19:29
    The arm could also be a very interesting pen lifter too.
