problem when using propeller-load with xmmc or xmm-single (propgcc default branch) - Page 2 — Parallax Forums
24
    edited 2014-03-01 07:18
    I hate to suggest this but one possible "solution" would be to install VirtualPC and a Linux distro and build under Linux. You can even still use Windows as your Propeller development environment since Eric recently added a way to build Windows binaries under Linux. The build is a lot faster under Linux and probably also won't have these problems you're encountering. In fact, you might decide you like Linux so much you'll abandon Windows! :-)
  • trancefreaktrancefreak Posts: 186
    edited 2014-03-01 07:25
    I have no problem using Linux because I'm quite familiar with it. Used it for years when I did Java development.
    But maybe it is faster if Steve could upload his default branch build, so that I can test this weekend ;-)
    If Steve has no time I will definitely consider installing Linux :-)
    Thanks David for the suggestion!
  • jazzedjazzed Posts: 11,803
    edited 2014-03-01 08:47
    Hi Christian,
    Here is an alpha_1_9 default branch build package. https://drive.google.com/file/d/0BzcfH7bdVTbtWVVDRndHeWt0Qkk/edit?usp=sharing
    edited 2014-03-01 09:14
    jazzed wrote: »
    Hi Christian,
    Hi Steve,
    Thanks very much! I will test if XMM is working today evening.
    Did you do something special to get the branch built on windows? I have problems using make.
    Christian
    edited 2014-03-01 09:27
    Wooooooooohooooooooooooo! It works, I have XMMC with sqi SRAM working :-) Never thought that I could be so happy ;-)
    So there is definitely an issue when using the rebuild.sh script instead of make. If I don't get make to work on windows I will use Linux for development.
    @Steve: Could you post how u built the sources? Because I have no luck with make.
    Christian
    edited 2014-03-01 09:46
    Christian
    Could you try xmm-single to see if that works for you? I'm having trouble getting ebasic3 working in xmm-single mode but I haven't been able to find the bug in the XMM kernel that might cause this problem.
    David
    edited 2014-03-01 10:01
    David Betz wrote: »
    David
    Hi David,
    XMM-Single is working for me. I will solder the flash ram onto my board today evening and try XMM split also.
    Christian
    edited 2014-03-01 10:09
    Hi Steve,
    Christian
    I built it on Linux. The windows build really needs to be fixed. The linux build generally takes less time though.
    edited 2014-03-01 10:28
    jazzed wrote: »
    Which compiler are you using that you can create windows binaries with linux?
    edited 2014-03-01 11:32
    GCC of course :)
    Pull repository.
    $ cd propgcc
    $ make
    $ make CROSS=win32
    edited 2014-03-01 12:20
    David Betz wrote: »
    David
    Hi David,
    XMM-Split does also work. Filling an array with 1024 int values takes 3,6 us in XMM-Split.
    Christian
    edited 2014-03-01 14:00
    Hi David,
    Christian
    Thanks for testing xmm-single. I wonder why it doesn't work with ebasic3? I can't see anything wrong with the XMM kernel code. I must be missing something somewhere I guess.
    edited 2014-03-01 14:02
    Hi David,
    Christian
    I just noticed you said xmm-split not xmm-single. That shouldn't work with only an SRAM for external memory. It's designed for a system that has both flash and RAM. The code runs from flash and the data is placed in RAM. Did you mean "xmm-single"?
    edited 2014-03-01 14:13
    David Betz wrote: »
    Hi David,
    I tested XMM-single, which worked and XMM-split (My own board has sram and flash. I have just soldered the flash ram to the board after sram test was successfull. So both ram work :-))
    edited 2014-03-01 14:23
    Hi David,
    Okay thanks. I didn't know you had a flash chip as well. Which driver are you using for both? sqi_flash_sram_xmem?
    edited 2014-03-01 14:25
    Yes, this is the driver I am using. Works absolutely well and even the xmm-split performance is good enough for my needs. I need a bigger RAM because I have to buffer DMD characters, numbers and so on.
    edited 2014-03-01 14:29
    Great! I'm glad things are working well for you. Thanks for reporting the XMM problems!
    edited 2014-03-01 14:35
    David Betz wrote: »
    I have to thank you and Steve for helping me out! Thanks again!
    edited 2014-03-01 14:38
    No problem. Glad we were able to help.
    edited 2014-03-01 14:53
    FYI, I figured out why ebasic3 isn't working in xmm-single mode. The problem is that I'm missing HUB declarations to force certain variables into hub memory so they can be accessed by the PASM VM running in a separate COG. I'm not going to bother fixing this because I would probably never want to run ebasic3 in xmm-single or xmm-split mode anyway. It was designed for CMM or xmmc. However, ebasic2 seems to work just fine in xmm-single mode. I'm posting this to let you know that I don't think my problem with ebasic3 has anything to do with a bug in the xmm-single support in propgcc.
    edited 2014-03-01 14:59
    David Betz wrote: »
    Thanks for the update, David!
    edited 2014-03-01 15:08
    Hi David,
    I have a question with regards to start a new cog in the default branch. Is it by default, that the cog runs in xmm mode, when xmm is set when compiling the sources or do I have to use another function to do that?
    Is there also a way to start a new cog in LMM mode?
    Christian
    edited 2014-03-01 15:15
    Hi David,
    Christian
    I'm not sure. We may have to wait for Eric to answer that. I only did the new xmem driver support. Eric added the multiple XMM COG support. Sorry.
    edited 2014-03-01 15:22
    David Betz wrote: »
    No problem, maybe Eric reads this and answers. Would be good if LMM cogs are still available.
    edited 2014-03-01 15:43
    Actually, now that I think of it, I don't think there is any way to have two different memory models in the same program. The problem is that you'd have to have two copies of any library functions you used.
    edited 2014-03-01 16:04
    David Betz wrote: »
    It is possible to run LMM code from an XMM memory model of course. Just tag the function as HUBTEXT. Not sure if that applies to cogs other than the main one though.
    edited 2014-03-01 16:22
    jazzed wrote: »
    I don't think this is true. Just because it is in hub memory does not mean it is LMM code. There is no LMM kernel in an XMM program to load into another COG. You can, of course, run XMM code that happens to be running a function that is in hub memory. Maybe that would be adequate? Again, you'd have to be sure that function was not going to call any library functions because those will probably be in external memory in XMM mode. It will work to call them but it will go through the cache.
    edited 2014-03-01 17:02
    David Betz wrote: »
    In this case (where code is tagged as HUBTEXT) the XMM kernel is supposed to fetch code from HUB RAM, and since the code is essentially the same except for some macros, it is practically LMM code.
    I have a program where the tagged LMM code out-performs normal LMM code :)
    edited 2014-03-01 17:06
    jazzed wrote: »
    Really? That's hard to believe. Every memory reference in XMM mode goes through an XMM macro as does fetching of the next instruction. It's hard to believe that could outperform rdlong for fetching instructions. Maybe we should examine that code to see if there is some bug at work?
    edited 2014-03-01 17:14
    David Betz wrote: »
    I'll test it on the default branch and see if it fails. :<
