TheoBot
Hacking an Ebay China $10 Theo Jansen "Strandbeest" kit into a differential-drive walker using continuous rotation servos. Same 9g servo & CR mods used in Spike: http://forums.parallax.com/showthread.php/151632
Coupling one crankshaft to its servo: http://www.youtube.com/watch?v=kSADSBj-xrQ
Legs on one side powered by a servo tester: http://www.youtube.com/watch?v=xq4AbO_xZu8
My favorite serendipitous discovery is that after installing both servos and extending the chassis the requisite length, the resulting center gap is sized perfectly for my favorite 15-cent 5cm x 7cm perfboard: http://www.ebay.com/itm/261340136969
Now I just have to decide what new feature to build into this bot. I'm bored with fire, lasers, & rubber band shooters. What's a bot to do?
Gattling gun.
Now you cats are starting to tickle my building bone...
Not sure that Theo would be on board with these less-than-green solutions, but I like them. I like them very much.
How's about a starfire space cannon? http://forums.parallax.com/showthread.php/153782-starfire-space-cannon
Maybe a flaming marshmallow...
Should be able to pull it off for Saturday's robot show. Will advise and Youtube.
Like father, like daughter......chipette of the old block, etc, etc.
Well done!!
Will definitely like to the children!
Put a small can in the middle gap and use another mini servo to control the port that will leave the m&ms . You can also control the motor with voice using a microphone or sound sensor.
Sort of a Pied Piperbot... how to lure all the kiddies away from the village. Fun, yet troubling!
It is a great mechanism, full props to Theo Jansen. The fact that it runs as fast and smoothly as it does on little 9 gram servos is a testament to its walking efficiency. So get one, Whit! Or maybe I'll order one for you since I still owe you for a certain box of goodies you mailed me a while back.
Also interesting that both Strandbeast and Spider now come in regular and supersized versions.
FYI :- The original Theo Strandbeast chassis (the one you have, and the one behind left in my picture above) was attached as a self build kit to an edition of "Otona no Kagaku" a Japanese magazine printed by Gakken, it was a very successful edition as they did follow up articles....
Err..A Long story cut short....
The SchneeBeest behind right is my old robot pal which Gakken requested to snap a few pictures and then let it travel to a Theo exhibition in Japan....as a thank you they sent me back their second iteration (front beast in picture) of the Strandbeast which is almost a smaller clone of the Steel Rhinoceros Theo designed.
No i have not hacked it yet.
Yes its a solid build...
My calculations indicate that it would hold and carry the weight of a S2 chassis...
Regards G
Edit: I just saw Lindsey's pic online in the TOC at http://servo.texterity.com/servo/201404/m3/Page.action?lm=1395213387000&pg=5
Amy's pic with Spiderbot was in the previous issue's TOC. Phew! The twins are happy now that the balance of the universe has been restored. Both photos attached here. Thank goodness they got their mom's good looks.
It's a pleasure to be in the same issue with Gordon and David from this forum, plus Dave Prochnow and his Lego EV3 article. I have his 1987 Tab book "Chip Talk" about speech synthesis. I'm clearly the low man on this totem pole.
http://servo.texterity.com/servo/201404/m3/Page.action?lm=1395213387000&pg=53
And thumbnails links to every page:
http://servo.texterity.com/servo/201404/m3/PageContent.action?lm=1395213387000
Armed with mom's good looks and your penchant for robots and tinkering, there's no stopping those two!!
I see similar results - you get a couple pages and then it wants you to subscribe. Win7 and Firefox here.
Flyer attached.
So green with envy... Oh! Back to the S3 work!
