Trying to read a EPROM
Hello all,
I am staring to go crazy, I am just trying to read a EPROM.
Here is the full code.
I can send the address to the EPROM, if I hook up LED's to the props I/O's I can see the address counting up.
I can see both "/CS" and "/OE" going on and off.
I can see the data on the EPROM's data bus (D0 to D7), But the prop refuses to read the inputs. For the life of me I cant figure it out. The prop should be good, it is about 2 weeks old. It has to be the code, but I cant see it.
HELP PLEASE!!! I am at the end of my rope of always running into problems, problems I should not be having.
TC
CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 CON 'pin A0 = 8 A14 = 22 D0 = 0 D7 = 7 CS = 24 OE = 27 IO_OE = 26 VAR long address byte Data OBJ PST : "Parallax Serial Terminal" PUB main PST.start(115_200) dira[A0..A14] ~~ dira[CS] ~~ dira[OE] ~~ dira[IO_OE] ~~ dira[D0..D7] ~ outa[A0..A14] := 0 outa[CS] := 1 outa[OE] := 1 outa[IO_OE] := 1 'turn on the translator PST.str(string("Address,Data")) PST.NewLine repeat address from $0000 to $7FFF PST.hex(address,4) PST.char(44) outa[A14..A0] := address outa[CS] := 0 outa[OE] := 0 Data := outa[D7..D0] PST.hex(Data,2) PST.NewLine outa[OE] := 1 outa[CS] := 1 waitcnt(clkfreq + cnt) 'wait 1 second
TC
http://obex.parallax.com/search/EEPROM
This one in particulaar is good.
http://obex.parallax.com/object/23
instead of
Because it is not a "EEPROM" it is a "EPROM" They are not the same. The one I am reading is parallel, 15 address lines, 8 data lines, a /CS line, and a /OE line
Sorry TC,
That's what I get for try to answer a question after being up for 36 hours straight. EPROM and EEPROM kinda look the same with one eye open.
Very familiar with EPROM's. I have my first 1702 (Altair 8800), and a couple of dozen 2708's.
http://en.wikipedia.org/wiki/EPROM
It's cool, been there more times then I want to remember.
This is my first time trying to read from one. So I am a little bit of a newbe.
