Trying to read a EPROM — Parallax Forums
TCTC Posts: 1,019
edited 2014-02-22 13:48 in Propeller 1
Hello all,
I am staring to go crazy, I am just trying to read a EPROM.
Here is the full code.
CON
        _clkmode = xtal1 + pll16x                                               'Standard clock mode * crystal frequency = 80 MHz
        _xinfreq = 5_000_000
CON     'pin
  A0            = 8
  A14           = 22
  D0            = 0
  D7            = 7
  CS            = 24
  OE            = 27
  IO_OE         = 26
VAR
  long  address
  byte  Data
OBJ
  PST      : "Parallax Serial Terminal"
PUB main
  PST.start(115_200)
  dira[A0..A14] ~~
  dira[CS] ~~
  dira[OE] ~~
  dira[IO_OE] ~~
  dira[D0..D7] ~
  outa[A0..A14] := 0
  outa[CS] := 1
  outa[OE] := 1
  outa[IO_OE] := 1              'turn on the translator
  PST.str(string("Address,Data"))
  PST.NewLine
  repeat address from $0000 to $7FFF
    PST.hex(address,4)
    PST.char(44)
    outa[A14..A0] := address
    outa[CS] := 0
    outa[OE] := 0
    Data := outa[D7..D0]
    PST.hex(Data,2)
    PST.NewLine
    outa[OE] := 1
    outa[CS] := 1
    waitcnt(clkfreq + cnt)      'wait 1 second
I can send the address to the EPROM, if I hook up LED's to the props I/O's I can see the address counting up.
I can see both "/CS" and "/OE" going on and off.
I can see the data on the EPROM's data bus (D0 to D7), But the prop refuses to read the inputs. For the life of me I cant figure it out. The prop should be good, it is about 2 weeks old. It has to be the code, but I cant see it.
HELP PLEASE!!! I am at the end of my rope of always running into problems, problems I should not be having.
TC
    edited 2014-02-22 10:51
    Why not visit to OBEX to get some i2c drivers?
    http://obex.parallax.com/search/EEPROM
    This one in particulaar is good.
    http://obex.parallax.com/object/23
  • Beau SchwabeBeau Schwabe Posts: 6,568
    edited 2014-02-22 10:52
    Try ...
    Data := ina[D7..D0]
    instead of
  • TCTC Posts: 1,019
    edited 2014-02-22 10:56
    That did it, Thank you. I have no idea why i did not see that.
  • TCTC Posts: 1,019
    edited 2014-02-22 11:08
    Publison wrote: »
    Because it is not a "EEPROM" it is a "EPROM" They are not the same. The one I am reading is parallel, 15 address lines, 8 data lines, a /CS line, and a /OE line
    edited 2014-02-22 13:18
    TC wrote: »
    Sorry TC,
    That's what I get for try to answer a question after being up for 36 hours straight. EPROM and EEPROM kinda look the same with one eye open. :)
    Very familiar with EPROM's. I have my first 1702 (Altair 8800), and a couple of dozen 2708's.
    http://en.wikipedia.org/wiki/EPROM
  • TCTC Posts: 1,019
    Publison wrote: »
    Sorry TC,
    It's cool, been there more times then I want to remember.
    This is my first time trying to read from one. So I am a little bit of a newbe.
