Shop Learn P1 Docs P2 Docs Events
TACHYON O/S V3.0 JUNO - Furiously Fast Forth, FAT32+LAN+VGA+RS485+OBEX ROMS+FP+LMM+++ - Page 40 — Parallax Forums
13738404243109
    edited 2014-02-13 20:13
    I've been seeing some weird traffic come through and some of the requests are invalid with really long urls. I don't know whether a request for //log0001.txt is valid though but I will add the code to handle it as it should be /log001.txt.
    [FONT=courier new]2014/02/14 14:08:39 #6 CONNECT
    2014/02/14 14:08:39 #6 GET /log0001.txt
    HTTP/1.1
    Host: 192.168.16.150:82
    Connection: keep-alive
    Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
    User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/32.0.1700.107 Safari/537.36
    Accept-Encoding: gzip,deflate,sdch
    Accept-Language: en-GB,en-US;q=0.8,en;q=0.6
    2014/02/14 14:08:40 #6  --> LOG0001.TXT
    2014/02/14 14:08:40 #6 BLKSEND @010C.7E00  for 0000.102B
    2014/02/14 14:08:40 #6 BLKSEND COMPLETE
    2014/02/14 14:08:40 #6 DISCONNECTING --- DISCONNECTED
    2014/02/14 14:08:41 #6   CLOSING   ok
    [/FONT]
    Normal remote connect to tachyonforth.com
    2014/02/14 14:20:11 #4 CONNECT
    2014/02/14 14:20:11 #4 GET /
    HTTP/1.1
    Host: tachyonforth.com
    User-Agent: Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/32.0.1700.107 Safari/537.36
    Accept-Language: en-US,en;q=0.8
    Cache-Control: max-age=259200
    2014/02/14 14:20:11 #4 CONTENT = text/html
    2014/02/14 14:20:11 #4  --> HOME.HTM
    2014/02/14 14:20:11 #4 BLKSEND @0107.5E00  for 0002.70C1
    2014/02/14 14:20:13 #4 BLKSEND COMPLETE
    2014/02/14 14:20:13 #4 DISCONNECTING --- DISCONNECTED
    2014/02/14 14:20:14 #4   CLOSING
    2014/02/14 14:20:14 #4 CONNECT
    2014/02/14 14:20:14 #4 GET /image
    HTTP/1.1
    Accept: image/webp,*/*;q=0.8
    Referer: http://tachyonforth.com/
    2014/02/14 14:20:14 #4  --> IMAGE
    2014/02/14 14:20:14 #4 BLKSEND @0109.EE00  for 0000.3F4C
    2014/02/14 14:20:14 #4 BLKSEND COMPLETE
    2014/02/14 14:20:15 #4 DISCONNECTING --- DISCONNECTED
    2014/02/14 14:20:15 #4   CLOSING
  • richaj45richaj45 Posts: 179
    edited 2014-02-14 17:46
    @Peter
    I notice in your Tachyon V2.3 code that cog 0 is left with only the serial receive PASM code.
    Why not do receive and transmit in the same cog?
    rich
    edited 2014-02-14 18:01
    richaj45 wrote: »
    @Peter
    rich
    At the time I first wrote Tachyon I didn't want to be limited by these relatively slow speeds, even 115k is a push for the full-duplex object and I know that the bit timing at this speed is flakey. If you want precise bit timing at high speeds for full duplex you have to dedicate a cog to receive and one to transmit. But my kernel code didn't waste time trying to buffer anything for transmit because at high speeds you are far better off just bashing out the bits yourself (cog-wise speaking that is). So when I published Tachyon it was working at 3M baud and at this speed the Tachyon cog wastes little time transmitting. For a compromise, both for Bluetooth and for users who might be baud rate limited or were using PropForth I dropped the rate to it's present standard of 230,400 baud. Even my serial routines written in Tachyon Forth itself can handle these speeds too.
    Now in saying all this I have been meaning to release a version where the high speed serial cog can switch to a slower speed but handle multiple full duplex buffered channels. At slower speeds it makes more sense to buffer transmit data so the system would switch it's emit vector over to the serial cog instead. This has uses in many applications where I don't need high speed but multiple serial ports.
  • D.PD.P Posts: 790
    edited 2014-02-15 00:36
    HTTP/1.1
    [/FONT]
    HTTP/1.1
    HTTP/1.1
    Been trying to connect, sometimes I get part of the home page followed by garbled data and sometimes I get just a reset.
    Probably between updates again.
    Mac OSX 10.8.5 and I tried Safari, FF and Chrome
    edited 2014-02-15 02:48
    D.P wrote: »
    I think I need to adjust timeouts and I'm sure I have a bug in that I am disconnecting too early sometimes. Just haven't had time to check it properly, sorry. But once I fine tune it I will pile some real info onto the unit. Basically all the Tachyon support files etc. More than likely I will have more than one unit running and the RS232 and RS485 and Bluetooth ports running to some other Prop stuff. Since I have a couple of webcams floating around I could have one or two monitoring actual motor control, I'd like to do a robot arm --> pub THIRSTY REACH OPEN BEER GRASP SERVE ; . Anyway, whatever I hook up it will be educational and fun. (P.S. Parallax, C may be "educational" as in institutions, but it ain't fun).
  • max72max72 Posts: 1,152
    edited 2014-02-15 05:28
    That would be a great addition...
  • artkennedyartkennedy Posts: 174
    edited 2014-02-15 12:03
    Howdy, I have been working with (learning) PropForth and have decided to try Tachyon. My first attempts at loading it have failed.
    My process:
    - load Tachyon V2.3.spin in the PropTool and press f11.
    - kill PropTool.
    - Load TerraTerm and connect to QuickStart board.
    - Find nothing on screen, press CR several times
    - note typical response: "
  • D.PD.P Posts: 790
    edited 2014-02-15 14:23
    Tip: make sure you change your TeraTerm Setup->Port Transmit delay to around 23 msec/line, no char delay before you cut and pasted EXTEND.fth or you own code into the terminal for compilation.
    .PINS
    .INFO
    Now back to your project (hardware, software, mechanical...) because a bunch of accidental complexity (compilers, linkers, sealed libraries, downloaders, separate terminal) has just been removed for you with this Tachyon / FORTH implementation, hat tip to PeterJ
    I would recommend reading the Intro multiple times and doing each example multiple times, it can be very frustrating at first comming from a purely procedural programming background.
    I can help with basic questions.
    Enjoy, welcome to the fun side.
    edited 2014-02-15 14:44
    artkennedy wrote: »
    My process:
    - kill PropTool.
    edited 2014-02-15 15:19
    Thanks, Peter and D.P. Did what you said and it looks like I have a good beginning.
    Over on PropForth I have a thread going "Learning Forth" where I was getting a lot of help from Loopy, who suggested I try Tachyon. Posted quite a bit about what I am doing.
    I have some experience *long-ago* working with Forth on a New Micros Inc. board. I have a ways to go to wake all that up but it is now forward ho!
    I am sure I will have more questions and I do thank your for responding so quickly.
    edited 2014-02-15 15:42
    Back again . . . I am using a QuickStart board - so after installing Tachyon and EXTEND.FTH I also attempted to install QS.FTH without success.
    After ^C it does not show as a Module Loaded.
    Do I need to edit the W5200 stuff out of the QS.FTH file?
  • D.PD.P Posts: 790
    edited 2014-02-15 17:15
    artkennedy wrote: »
    The file in the drop box has a tick in it where it shouldn't it seems
    \ ----- RTC has been tested
    ( S-35390A RTC )`         \ <--- remove that tick
    Also I had to increase my line delay to 40ms, maybe because, well let's just let Peter answer this.
    00:00:10  End of source code, 0084 lines processed and 0000 errors found
    Load time = 45,285ms
    edited 2014-02-15 19:31
    D.P wrote: »
    I fired up a Win7 system with TeraTerm and a standard Parallax Prop demo board and cleaned up the tick in QS.FTH. Everything loaded fine with the standard Prop tool and with TeraTerm set to 20ms. Load time for QS.FTH was 4.2 secs so everything is fine so far. Since QS.fth does not automatically perform a BACKUP then any reset at this stage will lose QS.fth. I have just added the ?BACKUP word to the end of the document now so that it locks itself into EEPROM.
    I can't see why there should be any other problems though. It doesn't matter if QS has the pin definitions for parts that haven't been loaded, it won't hurt.
    EDIT: updated the versions and checked them though there seems to be an error in reporting the loading time, the actual time is much shorter, so I will check that but I think it is probably a temporary Forth register problem.
    Note: It looks like extend.fth is not hte most current version as I removed QWORDS from the current version and extended WORDS with an optional control switch to modify the listing. Maybe I will change that back so that I still have one definition for WORDS but add QWORDS name to do the same thing as it did before.
    edited 2014-02-15 20:31
    Thanks you two. All good now. Time to start playing with the code.
    BTW, I've noticed something strange when loading the *.fth files. The console echo of the loading process stops incrementing lines at the bottom of the page and just screen prints over and over on the same line. Any idea why?
  • D.PD.P Posts: 790
    edited 2014-02-15 21:59
    artkennedy wrote: »
    Artifacts of the terminal session where [~ and ]~ suppress console "interaction", from extend.fth below. As long as you get 0000 errors every thing is nice.
    \ start of load symbol - suppress console interaction
    pub [~                  OFF ECHO OFF OK ' LEMIT uemit W! ;
    \ end of load symbol - reenable interactive console
    pub ]~                  ON ECHO ON OK 0 uemit W! ;
    edited 2014-02-15 22:09
    artkennedy wrote: »
    Not quite sure what you mean when you mean when you say it stop incrementing the lines etc as EXTEND.fth ends up processing 1615 lines but it doesn't count any comment blocks in there as the editor says that there are 2662 lines altogether. There are some words that echo even during a load and I suppose it would be really nice if they didn't maybe and that line numbers reflected the actual line itself and so on but normally these things aren't of great concern itself. Certainly if I was producing this Forth as a commercial product I would clean it up but the big emphasis in development is on actual use and runtime performance etc. That doesn't mean I won't tidy up some of these cosmetic details though as I would find them useful too, but there are only so many hours in a day to maintain and improve Tachyon and also to get my work done :)
    But thanks for the feedback, I do take note and it's always good to get someone's first impressions, the hiccups they come across etc. I'm looking into a few of these things right at this moment.
    EDIT: originally the tilde sequences [~ and ]~ were interpreted by the serial driver as well but these have since been removed. It may well be that I remove the requirement for tilde words altogether in updates and just have dummy words for them for legacy source.
    EDIT: I see the bug with the load time report, I had introduced proper handling of nested braces a little while ago and that used the same spare location as the lap counter for counting the nesting levels. Fixed that up in the kernel so it's all good now.
    edited 2014-02-15 23:05
    I have been testing for output on a serial port I have set up on P27-Tx P26-Rx at 9600 baud. I have successfully made this test in PropForth.
    I did the test shown under REDIRECTING OUTPUT.
    I found that currently the correct entry is "9600 SERBAUD" by consulting the WORDS list.
    Seemed to run okay on the Prop side but I received no output using an hp48 calculator as I have before.
    I'm wondering if the fact I'm running with a 5 MHz clock and 16x PLL means I need to alter the parameter for SERBAUD.
    edited 2014-02-16 00:19
    artkennedy wrote: »
    An example of redirecting output is shown in the Intro where we need to define an EMIT or output word that the emit vector can point to and then we have an example of creating a word that sets that vector, in the case of a serial LCD we just say LCD ." whatever I tell you" CON and it will appear on the LCD. The 9600 SERBAUD only refers to setting the baudrate for the SEROUT word, nothing more. There are many many things in common between PropForth and Tachyon and perhaps many more differences, so consult the Intro as I try to cover the basics in this plus I just update it on the fly as required so it's always up-to-date as are all the Google webpage documents.
    Say the HP calc is on P27 we can define the output as
    : HPEMIT #P27 SEROUT ;
    : HPKEY #P267 SERIN ;
    : HP ' HPEMIT uemit W! ' HPKEY ukey W! ;
    This may need some refinement and it's probably not as nice as having a proper multiport serial object running, but it's what I have used until now. There will be an upgrade soon to the serial cog to handle multiple serial ports.
  • D.PD.P Posts: 790
    edited 2014-02-16 12:03
    Any plans to add fixed point math operators to Tachyon?
    OH HOLY COW you really cleaned up the loader in the lastest kernel, really nice.
    00:00:00  End of source code, 2889 lines processed and 0000 errors found
    Load time = 2,714ms
    NAMES:  $5E70...74EF for 5759 (3245 bytes added)
    CODE:   $0000...3101 for 6786 (6401 bytes added)
    CALLS:  0500 vectors free
    RAM:    11631 bytes free
  • ChameleonChameleon Posts: 14
    edited 2014-02-16 17:06
    A task which may be interesting to someone on this thread, the Forth skills for which I am currently lacking: DTMF decoding. There are chips which can perform this function, but they require 6 I/O pins (D0...D3, ENA#, Dataready). For the overall project I'm working on, I have a "spare cog" which could spend its time doing this if it's doable and reliable (1 pin certainly is nicer than 6).
    For those not familiar with DTMF (Dual-tone Multi-frequency), it's the touch tones used in phone dialers, which is ubiquitous in Amateur radio control in addition to landline phones. It is a 4x4 matrix of non harmonically related tones between 697 and 1633 Hz mixed to create 16 sinusoidal waveforms. Thankfully, the tones were well thought out to avoid problems with harmonics and intermod, and the specs for tone accuracy are nice and tight (<1.8% deviation).
    I have barely started thinking about how to determine frequency of a single-frequency square wave via Forth, let alone a dual tone sinusoidal wave. Anyone have any thoughts, or is it better to spend the 6 pins? I tend to jump in with both feet, and have done so with Forth, so easier to develop isn't necessarily better, if the end result is reliable with a smaller pin count. I'm definitely not looking for anyone to do it for me (where's the fun of learning in that?), but would be thankful for some pointers.
    edited 2014-02-16 17:28
    Chameleon wrote: »
    Phil Pilgrim did a BELL 202 1200 baud modem object a while back so you could apply some of those techniques I guess but Phil also did some DTMF work here too.
    BTW: if you need any of those 8870 and 8880 (I think) DTMF chips I think I still have tubes of them from years back.
  • D.PD.P Posts: 790
    edited 2014-02-16 18:36
    Chameleon wrote: »
    For the HT9170B at 2.45 a chip and 4 IOs not counting ENB or PWRdn (both could be held static)
    http://www.ebay.com/itm/HT9170B-HT9170-Holtek-DTMF-Receiver-/200494796632
    edited 2014-02-16 19:03
    Or the BU8872 from DigiKey for a couple of bucks, it has 3-wire serial data interface.
  • D.PD.P Posts: 790
    edited 2014-02-16 23:04
    I asked about fixed point math operators in Tachyon because I'm having difficulty with an approach to translate some of my spin code.
    UPDATE: Let's just forget this I'm gonna implement a table lookup method with smoothing, for the Buck method below I probably should use an off board MCU
    Calculate the relative humidity from a dry buld and wet bulb pair using the calculated staturation
    vapor pressure at each bulb.
    CON
      _CLKMODE = XTAL1 + PLL16X
      _XINFREQ = 5_000_000
    OBJ
      f32           : "F32"
    VAR
      Long  VPa     'Actual Vapor Pressure
      Long  Sd      'Saturation VP at dry bulb
      Long  Sw      'Saturation VP at wet bulb
      Long  Dryc    'Dry bulb temp in C
      Long  Wetc    'Wet bulb temp in C
      Long  Atm     'Atmospheric pressure in millibars
      Long  PerHum  'Percent Humidity
    PUB  CalcHumidity
            'Saturation Vapour Pressure at Dry Temp in millibars
            Sd := 6.112 * f32.Exp(f32.FDiv(f32.FMul(17.67, Dryc), f32.FAdd(243.5, Dryc)))
            'Saturation Vapour Pressure at Wet Bulb in millibars
            Sw := 6.112 * f32.Exp(f32.FDiv(f32.FMul(17.67,  Wetc), f32.FAdd(243.5, Wetc)))
            'Actual Vapour Pressure in millibars
    	VPa  := f32.FSub(Sw, f32.FMul(0.00066, f32.FMul(f32.FAdd(1.0, f32.FMul(0.00115,Wetc)), f32.FMul(f32.FSub(Dryc, Wetc),Atm))))
            'Humidity Percentage
    	PerHum := f32.FMul(100.0, f32.FDiv(VPa, Sd))
  • Brian RileyBrian Riley Posts: 626
    edited 2014-02-16 23:33
    I sell a kit for the MT8870 chip for $5 plus $2 S&H ... it includes the chip, crystal, socket and three 1% precision resistors and two caps. You can find it here at my website.
    edited 2014-02-16 23:51
    I see what I did - omitted the "#P" in front of the port numbers. I guess that is a holdover from PF.
    A multiple serial object sounds great. I am going to be running three serial peripherals. If you could include support for 7 bit with 2 stop bits that would be sweet. I know that stuff is oooold but I am building a kludge that needs it, maybe. The 7 bits would be for a Protek 506 DMM. I had run successful tests with the DMM and the hp48 using 8 bits on the calculator and just clearing the hi bit of data received. I expected the same to work on the Propeller but I couldn't get it going with PropForth even with very extensive experimentation which I believe eliminated all other possible causes. I'm hoping Tachyon is different in that respect.
    Cheers . . .
    edited 2014-02-17 00:50
    D.P wrote: »
    Would something like this be okay, assuming I had it ready to release?
    [FONT=courier new]
    pub  SatVP ( temp -- satVP )
        F32
        17.67 OVER F*
        OVER 243.5 F+
        F/ FExp
    pub CalcHumidity ( Atm Dryc Wetc -- rh )
        F32 3 LOCAL                      '' Select F32 notation and save inputs as locals (X1=Wetc)
        X2 SatVp                         '' dry bulb satVP
        X1 SatVp                         '' wet bulb satVP
        X2 X1 F- X3 F*
        0.00115 X1 F* 1.0 F+ ROT F*
        0.00066 F* F-                    '' VPa
        SWAP F/ 100.0 F*
        3 RELEASE
        ;[/FONT][FONT=courier new]
    [/FONT]
    This is one way of doing it so you wouldn't need all those variables and that basically looks right I think.
    edited 2014-02-17 01:49
    artkennedy wrote: »
    Cheers . . .
    The # forces the number to decimal and the P is ignored as these prefix number modes allow symbols to be intermixed in a number, writing #P6 just helps us to see it is P6, the port pin.
    There is really no problem with running this at the moment using SERIN and SEROUT with the SERIN as part of a little buffer code running in their own cogs. I got some code I've used in other applications that I will post back up on the Intro page, so have a look back there soon. It's very easy to custom craft your own serial I/O in this fashion as it is all high level Forth, no PASM, and their are plenty of cogs available.
  • D.PD.P Posts: 790
    edited 2014-02-17 08:36
    [FONT=courier new]
        F32
        17.67 OVER F*
        OVER 243.5 F+
        F/ FExp
        X2 X1 F- X3 F*
        SWAP F/ 100.0 F*
        3 RELEASE
    [/FONT]
    Absolutely, I was looking at how many table entries I had to input and it's enormous. The problem gets real tricky around 95-100% consending RH, the saturation vapor equations become the most accurate.
    Also your code makes perfect sense, I'm feeling the procedural syntax parasite leaving this host finally. One thing though is I don't see the DONATE button. [8>}
    edited 2014-02-17 12:03
    Tracy Allen made an integer only version of the sensirion (in spin). Maybe you can check it.
