i2c Nothing Works!!! - Page 4 — Parallax Forums
124»
  • T ChapT Chap Posts: 4,235
    edited 2014-02-13 13:36
    In PASM, they set Set ACCEL_CONFIG register AFS_SEL bits to 2. Are you setting your range to the same value?
    You may be best off just trying to dissect the PASM version since it is already working. The object seems to allow you to PST.DEC(MPU.GetRX) PST.DEC(MPU.GetTemp) etc. You should spend about 5 hours in the manual making notes and getting familiar with the various settings before trying to create an object for it. That device is very involved.
  • zlantzzlantz Posts: 136
    edited 2014-02-13 13:51
    T Chap wrote: »
    The Config bits are chosen in the Start# functions, that was my first experience of learning pasm (using user chosen values instead of the preset values). The output should scale accordingly as it does in the pasm driver, just experience more sensitivity by adjusting those values.
    I was just thinking the same thing, now that I know how to read the mag in spin. After the other day I have a fair understanding of how the PASM driver flows... not entirely sure how it works, but I can see how to copy the existing code with slight changes to do what I want.
    My biggest conscern is, how do you retrieve data From the pasm read section? At no point is iaX or paX copied to aX, but aX (spin) holds the value of iaX/paX (pasm).
    edited 2014-02-13 14:29
    You already have been "retrieving data from pasm".
    ser.dec(aX)
    wrlong iaX, paX 'take the pasm value of ax 9iaX) and write it to hub ram at the pointer to ax (pax)... which is aX in hub.
    iaX long 0 ' Interim aX value this will get written to hub ram so your main program can use it
    edited 2014-02-13 14:42
    zlantz:
    You just might find that PASM is a better friend than you ever imagined. :) It integrates amazingly well with SPIN, and the respective strengths of SPIN and PASM complement each other in a rather marvelous fashion.
    edited 2014-02-13 14:46
    I am trying to jump into pasm... learning a new language all over again is rough. But I think I am getting it.
    I managed to get it to return something for the Chip ID, its returning 0xD1 but it should be 0x68.
    once I can figure out how to get pasm to give me the right chip id, I should be able to get the mag data with the same method.
    also now my Accel X and Gyro Z value is off in my pasm code, but right in the 6050_pasm code.
    '' MPU-60X0-PASM.spin
    '' Reads gyro and accelerometer data from the MPU-60X0 chips
    '' Read loop is in Propeller Assembler
    '' Based on Jason Dorie's code for the ITG-3200 and ADCL345 chips
    '' Note that this code assumes an 80 MHz clock
    '' The TestMPU routine can be used to verify correct setup of, and
    '' communication with, the MPU-60X0.  Load the object into RAM, then
    '' use f12 to bring up the terminal emulator to see the output.
      * User Init Select                        *
      * Updates by: Zack Lantz                  *
      Place in Main .Spin:
      Con
        ' // Accelerometer Settings
        mAFS0 = 0
        mAFS1 = 1
        mAFS2 = 2
        mAFS3 = 3
        ' // Gyroscope Settings
        mFS0 = 0
        mFS1 = 1
        mFS2 = 2
        mFS3 = 3
        ' // Digital Low Pass Filter Settings
        DLP0 = 0          ' Bandwidth = 260 Hz
        DLP1 = 1          ' Bandwidth = 184 Hz
        DLP2 = 2          ' Bandwidth = 94  Hz
        DLP3 = 3          ' Bandwidth = 44  Hz
        DLP4 = 4          ' Bandwidth = 21  Hz
        DLP5 = 5          ' Bandwidth = 10  Hz
        DLP6 = 6          ' Bandwidth = 5   Hz
        DLP7 = 7          ' Reserved
        ' // Current Settings (Passed to MPU-6050.spin)
        AccelFS = AFS2
        GyroFS  = FS3
        mAFS    = mAFS2
        mFS     = mFS3
        mDLP    = DLP3
      Then start MPU Driver with:
      MPU.Start(MPUscl, MPUsda, mAFS, mFS, mDLP)    ' MPU-6050 Gyro & Accel Sensor Data  w/ User Init AFS, FS, & DLP
      Everything else works the same.
      New Functions:
        Start (SCL, SDA, aFS, gFS, fDLP)
        StartA(SCL, SDA, aFS, gFS, fDLP, PM) ', SF)
        StartX(SCL, SDA)
      *** Note:  I didn't add in SampleRate feature as it is 0 to 255 & Calculated as follows:
      Sample Rate = Gyroscope Output Rate / (1 + SMPLRT_DIV)
      Where Gyroscope Output Rate = 8kHz when the DLPF is disabled (DLPF_CFG = 0 or 7), and 1kHz when the DLPF is enabled (see Register 26)
    The slave address of the MPU-60X0 is b110100X which is 7 bits long. The LSB bit of the 7 bit address is
    determined by the logic level on pin AD0. This allows two MPU-60X0s to be connected to the same I2C bus.
    When used in this configuration, the address of the one of the devices should be b1101000 (pin AD0
    is logic low) and the address of the other should be b1101001 (pin AD0 is logic high).
    CON
      * MPU-9150_Spin                           *
      * by: Zack Lantz                          *
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq               ' system freq as a constant
      MS_001   = CLK_FREQ / 1_000                                   ' ticks in 1ms
      US_001   = CLK_FREQ / 1_000_000                               ' ticks in 1us
    ' // AK8975 Register Map
      Name    Address   READ/WRITE    Description     Bit width    Explanation
      WIA      00H        READ        Device ID          8
      INFO     01H        READ        Information        8
      ST1      02H        READ        Status 1           8         Data status
      HXL      03H        READ        Measurement data   8         X-axis data
      HXH      04H        READ        Measurement data   8         X-axis data
      HYL      05H        READ        Measurement data   8         Y-axis data
      HYH      06H        READ        Measurement data   8         Y-axis data
      HZL      07H        READ        Measurement data   8         Z-axis data
      HZH      08H        READ        Measurement data   8         Z-axis data
      ST2      09H        READ        Status 2           8         Data status
      CNTL     0AH      READ/WRITE    Control            8
      RSV      0BH      READ/WRITE    Reserved           8         DO NOT ACCESS
      ASTC     0CH      READ/WRITE    Self-test          8
      TS1      0DH      READ/WRITE    Test 1             8         DO NOT ACCESS
      TS2      0EH      READ/WRITE    Test 2             8         DO NOT ACCESS
      I2CDIS   0FH      READ/WRITE    I2C disable        8
      ASAX     10H        READ        X-axis sensitivity adjustment value   8    Fuse ROM
      ASAY     11H        READ        Y-axis sensitivity adjustment value   8    Fuse ROM
      ASAZ     12H        READ        Z-axis sensitivity adjustment value   8    Fuse ROM
    ' // MPU-6050 Register Map
    Con
      Self_Test_X     = $0D  ' 13
      Self_Test_Y     = $0E  ' 14
      Self_Test_Z     = $0F  ' 15
      Self_Test_A     = $10  ' 15
      SMPLRT_Div      = $19  ' 25
      Config          = $1A  ' 26
      Gyro_Config     = $1B  ' 27
      Accel_Config    = $1C  ' 28
      Mot_Thr         = $1F  ' 31
      FIFO_En         = $23  ' 35
      I2C_Mst_Ctrl    = $24  ' 36
      I2C_Slv0_Addr   = $25  ' 37
      I2C_Slv0_Reg    = $26  ' 38
      I2C_Slv0_Ctrl   = $27  ' 39
      I2C_Slv1_Addr   = $28  ' 40
      I2C_Slv1_Reg    = $29  ' 41
      I2C_Slv1_Ctrl   = $2A  ' 42
      I2C_Slv2_Addr   = $2B  ' 43
      I2C_Slv2_Reg    = $2C  ' 44
      I2C_Slv2_Ctrl   = $2D  ' 45
      I2C_Slv3_Addr   = $2E  ' 46
      I2C_Slv3_Reg    = $2F  ' 47
      I2C_Slv3_Ctrl   = $30  ' 48
      I2C_Slv4_Addr   = $31  ' 49
      I2C_Slv4_Reg    = $32  ' 50
      I2C_Slv4_Do     = $33  ' 51
      I2C_Slv4_Ctrl   = $34  ' 52
      I2C_Slv4_Di     = $35  ' 53
      I2C_Mst_Status  = $36  ' 54
      INT_Pin_Cfg     = $37  ' 55
      INT_Enable      = $38  ' 56
      INT_Status      = $3A  ' 58
      Accel_XOut_H    = $3B  ' 59
      Accel_XOut_L    = $3C  ' 60
      Accel_YOut_H    = $3D  ' 61
      Accel_YOut_L    = $3E  ' 62
      Accel_ZOut_H    = $3F  ' 63
      Accel_ZOut_L    = $40  ' 64
      Temp_Out_H      = $41  ' 65
      Temp_Out_L      = $42  ' 66
      Gyro_XOut_H    = $43  ' 67
      Gyro_XOut_L    = $44  ' 68
      Gyro_YOut_H    = $45  ' 69
      Gyro_YOut_L    = $46  ' 70
      Gyro_ZOut_H    = $47  ' 71
      Gyro_ZOut_L    = $48  ' 72
      Ext_Sens_Data_00  = $49 ' 73
      Ext_Sens_Data_01  = $4A ' 74
      Ext_Sens_Data_02  = $4B ' 75
      Ext_Sens_Data_03  = $4C ' 76
      Ext_Sens_Data_04  = $4D ' 77
      Ext_Sens_Data_05  = $4E ' 78
      Ext_Sens_Data_06  = $4F ' 79
      Ext_Sens_Data_07  = $50 ' 80
      Ext_Sens_Data_08  = $51 ' 81
      Ext_Sens_Data_09  = $52 ' 82
      Ext_Sens_Data_10  = $53 ' 83
      Ext_Sens_Data_11  = $54 ' 84
      Ext_Sens_Data_12  = $55 ' 85
      Ext_Sens_Data_13  = $56 ' 86
      Ext_Sens_Data_14  = $57 ' 87
      Ext_Sens_Data_15  = $58 ' 88
      Ext_Sens_Data_16  = $59 ' 89
      Ext_Sens_Data_17  = $5A ' 90
      Ext_Sens_Data_18  = $5B ' 91
      Ext_Sens_Data_19  = $5C ' 92
      Ext_Sens_Data_20  = $5D ' 93
      Ext_Sens_Data_21  = $5E ' 94
      Ext_Sens_Data_22  = $5F ' 95
      Ext_Sens_Data_23  = $60 ' 96
      I2C_Slv0_Do       = $63 ' 99
      I2C_Slv1_Do       = $64 ' 100
      I2C_Slv2_Do       = $65 ' 101
      I2C_Slv3_Do       = $66 ' 102
      I2C_Mst_Delay_Ctrl  = $67 ' 103
      Signal_Path_Reset   = $68 ' 104
      Mot_Detect_Ctrl     = $69 ' 105
      User_Ctrl         = $6A ' 106
      PWR_MGMT_1        = $6B ' 107
      PWR_MGMT_2        = $6C ' 108
      FIFO_CountH       = $72 ' 114
      FIFO_CountL       = $73 ' 115
      FIFO_R_W          = $74 ' 116
      WHO_AM_I          = $75 ' 117
    CON                        ' CONs for TestMPU test routine
      SDA_PIN        = 10
      SCL_PIN        = 11
      SERIAL_TX_PIN  = 30
      SERIAL_RX_PIN  = 31
    VAR
      long Cog
      ' // Zero Calibration, Measurement Data, and Status Storage
      long x0, y0, z0, a0, b0, c0, d0, e0, f0, t
      ' // PASM / Spin Storage
      'long FIFOcnt, FIFOrw, mID, mInfo, mStatus, PT_En, MM_En, FIFO_Enable, Verify_Registers, drift
      ' // PASM Returns
      long rx, ry, rz, temp, ax, ay, az, arx, ary, mID, mInfo, mStatus, mX, mY, mZ, cID         ' PASM code assumes these to be contiguous
      'long E1, E2, E3, E4, E5, E6, E7, E8, E9, E10, E11, E12                                   ' PASM code assumes these to be contiguous
    OBJ
      debug : "FullDuplexSerial"
    PUB TestMPU  | MPUcog
      ' Start serial i/o cog
      ' Start cog to pull gyro/accel data from chip
      ' Print data to serial out every few seconds
      debug.start(SERIAL_RX_PIN, SERIAL_TX_PIN, 0, 115200) 'Start cog to allow IO with serial terminal
      'repeat 4
      '   waitcnt(clkfreq + cnt)
      debug.str(string("Starting..."))
      debug.tx(13)
      debug.str(string("GX  GY  GZ    AX  AY  AZ"))
      debug.tx(13)
      debug.str(string("-------------------------"))
      debug.tx(13)
      MPUcog := StartX( SCL_PIN, SDA_PIN )
      'Output gyro data, then accel data, once per second
      repeat
         debug.hex(GetChipID, 2)
         debug.str(string("   "))
         debug.dec(GetAXz)
         debug.str(string(", "))
         debug.dec(GetAYz)
         debug.dec(GetAZz)
         debug.dec(GetRXz)
         debug.dec(GetRYz)
         debug.dec(GetRZz)
         debug.dec(GetMXz)
         debug.dec(GetMYz)
         debug.dec(GetMZz)
         debug.tx(13)
         'waitcnt((clkfreq / 10) + cnt)
    ' // Basic Start with User Accel AFS & Gyro FS & DLP
    PUB Start( SCL, SDA, aFS, gFS, fDLP ) : Status
      if aFS == 0
        AccelFS := %00000000  ' ±  2 g
      elseif aFS == 1
        AccelFS := %00001000  ' ±  4 g
      elseif aFS == 2
        AccelFS := %00010000  ' ±  8 g
      elseif aFS == 3
        AccelFS := %00011000  ' ± 16 g
      if gFS == 0
        GyroFS := %00000000   ' ±  250 ° /s
      elseif gFS == 1
        GyroFS := %00001000   ' ±  500 ° /s
      elseif gFS == 2
        GyroFS := %00010000   ' ± 1000 ° /s
      elseif gFS == 3
        GyroFS := %00011000   ' ± 2000 ° /s
                          '| DLPF_CFG |   Accelerometer    |          Gyroscope          |
      if fDLP == 0        '             Bw (Hz)  Delay (ms)  Bw (Hz)  Delay (ms)  FS (Khz)
        DLP := %00000000  '      0        260        0         256       0.98        8
      elseif fDLP == 1
        DLP := %00000001  '      1        184       2.0        188       1.9         1
      elseif fDLP == 2
        DLP := %00000010  '      2         94       3.0         98       2.8         1
      elseif fDLP == 3
        DLP := %00000011  '      3         44       4.9         42       4.8         1
      elseif fDLP == 4
        DLP := %00000100  '      4         21       8.5         20       8.3         1
      elseif fDLP == 5
        DLP := %00000101  '      5         10      13.8         10      13.4         1
      elseif fDLP == 6
        DLP := %00000110  '      6          5      19.0          5      18.6         1
      elseif fDLP == 7
        DLP := %00000111  '      7           RESERVED             RESERVED           8
      PowerMgmt  := %00000001  ' X gyro as clock source
      SampleRate := %00000001  ' 500 Hz
      ComputeTimes
      gyroSCL  := 1 << SCL     'save I2C pins
      gyroSDA  := 1 << SDA
      Status := Cog := cognew(@Start_Sensors, @rx) + 1
      CalibrateAccel
    ' // Start w/ Full User Init Settings
    PUB StartA( SCL, SDA, aFS, gFS, fDLP, PM ) : Status
      if aFS == 0
      elseif aFS == 1
      elseif aFS == 2
      elseif aFS == 3
      if gFS == 0
        GyroFS := %00000000
      elseif gFS == 1
        GyroFS := %00001000
      elseif gFS == 2
        GyroFS := %00010000
      elseif gFS == 3
        GyroFS := %00011000
      elseif fDLP == 1
      elseif fDLP == 2
      elseif fDLP == 3
      elseif fDLP == 4
      elseif fDLP == 5
      elseif fDLP == 6
      elseif fDLP == 7
      if PM == 0
        PowerMgmt := %00000000  ' Internal 8MHz oscillator
      elseif PM == 1
        PowerMgmt := %00000001  ' PLL with X axis gyroscope reference
      elseif PM == 2
        PowerMgmt := %00000010  ' PLL with Y axis gyroscope reference
      elseif PM == 3
        PowerMgmt := %00000011  ' PLL with Z axis gyroscope reference
      elseif PM == 4
        PowerMgmt := %00000100  ' PLL with external 32.768kHz reference
      elseif PM == 5
        PowerMgmt := %00000101  ' PLL with external 19.2MHz referenc
      elseif PM == 6
        PowerMgmt := %00000110  ' Reserved
      elseif PM == 7
        PowerMgmt := %00000111  ' Stops the clock and keeps the timing generator in reset
      ' *** Sample Rate = Gyroscope Output Rate / (1 + SMPLRT_DIV)
      ' // 0 threw 255
      SampleRate := %00000001   ' 500 Hz Sample Rate,   %00000000 = 1000 Hz Sample rate
      ComputeTimes
      gyroSDA  := 1 << SDA
      CalibrateAccel
    ' // Start Basic, No User Init
    PUB StartX( SCL, SDA ) : Status
      AccelFS := %00010000  ' AFS2
      GyroFS  := %00011000  ' FS3
      DLP        := %00000011  ' 40 Hz
      ComputeTimes
      gyroSDA  := 1 << SDA
      CalibrateAccel
      CalibrateGyro
    PUB Stop
      if Cog
        cogstop(Cog~ - 1)
    '   Accessors
    ' // Raw Values
    Pub GetaX             ' Accel X Raw
      return rX 'aX
    Pub GetaY             ' Accel Y Raw
      return rY 'aY
    Pub GetaZ             ' Accel Z Raw
      return rZ 'aZ
    Pub GetgX             ' Gyro X Raw
      return aX 'gX
    Pub GetgY             ' Gyro Y Raw
      return aY 'gY
    Pub GetgZ             ' Gyro Z Raw
      return aZ 'gZ
    Pub GetmX             ' Mag X Raw
      return mX
    Pub GetmY             ' Mag Y Raw
      return mY
    Pub GetmZ             ' Mag Z Raw
      return mZ
    PUB GetTemp           ' Temperature
      return temp
    'Pub GetTempF         ' Temp Deg F
    'Pub GetTempC         ' Temp Deg C
    PUB GetRXz            ' Accel X - Zero Offset
      return rx - x0
    PUB GetRYz            ' Accel Y - Zero Offset
      return ry - y0
    PUB GetRZz            ' Accel Z - Zero Offset
      return rz - z0
    PUB GetAXz            ' Gyro X - Zero Offset
      return ax - a0
    PUB GetAYz            ' Gyro Y - Zero Offset
      return ay - b0
    PUB GetAZz            ' Gyro Z - Zero Offset
      return az - c0
    PUB GetMXz            ' Mag X - Zero Offset
      return mx - d0
    PUB GetMYz            ' Mag Y - Zero Offset
      return my - e0
    PUB GetMZz            ' Mag Z - Zero Offset
      return mz - f0
    PUB GetARX           ' Pitch Angle
      return arx
    PUB GetARY           ' Roll Angle
      return ary
    Pub GetAccelOffsetX  ' Accelerometer Zero Offset X
      return x0
    Pub GetAccelOffsetY  ' Accelerometer Zero Offset Y
      return y0
    Pub GetAccelOffsetZ  ' Accelerometer Zero Offset Z
      return z0
    Pub GetGyroOffsetX   ' Gyroscope Zero Offset X
      return a0
    Pub GetGyroOffsetY   ' Gyroscope Zero Offset Y
      return b0
    Pub GetGyroOffsetZ   ' Gyroscope Zero Offset Z
      return c0
    Pub GetMagOffsetX    ' Magnetometer Zero Offset X
      return a0
    Pub GetMagOffsetY    ' Magnetometer Zero Offset Y
      return b0
    Pub GetMagOffsetZ    ' Magnetometer Zero Offset Z
      return c0
    Pub GetChipID
      return cID
    Pub CalAccel         ' Calibrate Accelerometer
      CalibrateAccel
    Pub CalGyro          ' Calibrate Gyroscope
      CalibrateGyro
    Pub CalMag           ' Calibrate Magnetometer
      CalibrateMag
    PRI computeTimes                                       '' Set up timing constants in assembly
                                                           '  (Done this way to avoid overflow)
      i2cDataSet := ((clkfreq / 10000) *  350) / 100000    ' Data setup time -  350ns (400KHz)
      i2cClkLow  := ((clkfreq / 10000) * 1300) / 100000    ' Clock low time  - 1300ns (400KHz)
      i2cClkHigh := ((clkfreq / 10000) *  600) / 100000    ' Clock high time -  600ns (400KHz)
      i2cPause   := clkfreq / 100000                       ' Pause between checks for operations
    ' // Calibrations Copied from MPU-6050 PASM
    Pri CalibrateAccel | tc, xc, yc, zc, dr
      x0 := 0         ' Initialize offsets
      y0 := 0
      z0 := 0
      'wait 1/2 second for the body to stop moving
      waitcnt( constant(80_000_000 / 2) + cnt )
      'Find the zero points of the 3 axis by reading for ~1 sec and averaging the results
      xc := 0
      yc := 0
      zc := 0
      repeat 256
        xc += rX ' aX
        yc += rY ' aY
        zc += rZ ' aZ
        waitcnt( constant(80_000_000/192) + cnt )
      'Perform rounding
      if( xc > 0 )
        xc += 128
      elseif( xc < 0 )
        xc -= 128
      if( yc > 0 )
        yc += 128
      elseif( yc < 0 )
        yc -= 128
      if( zc > 0 )
        zc += 128
      elseif( zc < 0 )
        zc -= 128
      x0 := xc / 256
      y0 := yc / 256
      z0 := zc / 256
    Pri CalibrateGyro | tc, xc, yc, zc, dr
      a0 := 0         ' Initialize offsets
      b0 := 0
      c0 := 0
      xc := 0
      yc := 0
      zc := 0
      repeat 256
        xc += aX ' gX
        yc += aX ' gY
        zc += aX ' gZ
      'Perform rounding
      if( xc > 0 )
        xc += 128
      elseif( xc < 0 )
        xc -= 128
      if( yc > 0 )
        yc += 128
      elseif( yc < 0 )
        yc -= 128
      if( zc > 0 )
        zc += 128
      elseif( zc < 0 )
        zc -= 128
      a0 := xc / 256
      b0 := yc / 256
      c0 := zc / 256
    Pri CalibrateMag | tc, xc, yc, zc, dr
      d0 := 0         ' Initialize offsets
      e0 := 0
      f0 := 0
      xc := 0
      yc := 0
      zc := 0
      repeat 256
        xc += mX
        yc += mY
        zc += mZ
      'Perform rounding
      if( xc > 0 )
        xc += 128
      elseif( xc < 0 )
        xc -= 128
      if( yc > 0 )
        yc += 128
      elseif( yc < 0 )
        yc -= 128
      if( zc > 0 )
        zc += 128
      elseif( zc < 0 )
        zc -= 128
      d0 := xc / 256
      e0 := yc / 256
      f0 := zc / 256
    ' // Resets All Registers on MPU
    Pri FactoryReset | i
      ' // *** Reset Value is 0x00 for all registers other than:
      ' //     Register 107: 0x40  (PWR_MGMT_1)
      ' //     Register 117: 0x68  (WHO_AM_I)
      repeat i from $00 to $75
        Write_Register(i, $00)
        if i == PWR_MGMT_1
          Write_Register(PWR_MGMT_1, $40)  ' Device Off
        if i == WHO_AM_I
          Write_Register(WHO_AM_I, $68)    ' Device ID = 0x68
    ' // Configure Digital Motion Processor  -  Uses FIFO for Data Access
    Pri SetDMP
      ' // TODO:  Addin DMP Control Setup / Load DMP Firmware to MPU Memory
    ' // Configure FIFO  -  Used for DMP
    Pri SetFIFO
      ' // TODO:  Addin FIFO Control Setup
    DAT
            org   0
    Start_Sensors
    '  --------- Debugger Kernel add this at Entry (Addr 0) ---------
    '   long $34FC1202,$6CE81201,$83C120B,$8BC0E0A,$E87C0E03,$8BC0E0A
    '   long $EC7C0E05,$A0BC1207,$5C7C0003,$5C7C0003,$7FFC,$7FF8
            mov             p1, par                         ' Get data pointer
            mov             prX, p1                         ' Store the pointer to the rx var in HUB RAM
            add             p1, #4
            mov             prY, p1                         ' Store the pointer to the ry var in HUB RAM
            add             p1, #4
            mov             prZ, p1                         ' Store the pointer to the rz var in HUB RAM
            add             p1, #4
            mov             pT, p1                          ' Store the pointer to the temp var in HUB RAM
            add             p1, #4
            mov             paX, p1                         ' Store the pointer to the ax var in HUB RAM
            add             p1, #4
            mov             paY, p1                         ' Store the pointer to the ay var in HUB RAM
            add             p1, #4
            mov             paZ, p1                         ' Store the pointer to the az var in HUB RAM
            add             p1, #4
            mov             paRX, p1                        ' Store the pointer to the arx var in HUB RAM
            add             p1, #4
            mov             paRY, p1                        ' Store the pointer to the ary var in HUB RAM
            add             p1, #4
            mov             pamID, p1                         ' Store the pointer to the ax var in HUB RAM
            add             p1, #4
            mov             pamInfo, p1                         ' Store the pointer to the ay var in HUB RAM
            add             p1, #4
            mov             pamStatus, p1                         ' Store the pointer to the az var in HUB RAM
            add             p1, #4
            mov             pamX, p1                         ' Store the pointer to the ax var in HUB RAM
            add             p1, #4
            mov             pamY, p1                         ' Store the pointer to the ay var in HUB RAM
            add             p1, #4
            mov             pamZ, p1                         ' Store the pointer to the az var in HUB RAM
            add             p1, #4
            mov             pacID, p1                         ' Store the pointer to the az var in HUB RAM
            ' // cID, E1 threw E12
            mov             i2cTemp,i2cPause
            add             i2cTemp,CNT                     ' Wait 10us before starting
            waitcnt         i2cTemp,#0
            call            #SetConfig
            mov             loopCount, CNT
            add             loopCount, loopDelay
    ' Main loop
    '   loopDelay defined in data section
    '   Nominally set to CLK_FREQ/200 give 200hz update rate, but the update takes less than
    '   500us, so the delay could potentially be set to give an update rate as high as 2000hz
    :loop
                            call    #MPUReadValues
                            call    #MPUComputeDrift
                            call    #ComputeAngles
                            wrlong  iT, pT
                            subs    irX, drift
                            wrlong  irX, prX
                            subs    irY, drift
                            wrlong  irY, prY
                            subs    irZ, drift
                            wrlong  irZ, prZ
                            wrlong  iaX, paX
                            wrlong  iaY, paY
                            wrlong  iaZ, paZ
                            wrlong  iaRX, paRX
                            wrlong  iaRY, paRY
                            wrlong  iamID, pamID
                            wrlong  iamInfo, pamInfo
                            wrlong  iamStatus, pamStatus
                            wrlong  iaMX, paMX
                            wrlong  iaMY, paMY
                            wrlong  iaMZ, paMZ
                            wrlong  iacID, pacID
                            waitcnt loopCount, loopDelay
                            jmp     #:loop
    ' MPUReadValues
    '   Starting at the ACCEL_X data register,  read in the 3 accel values,
    '   the temperature, and the 3 gyro values, as these are held in
    '   sequential register locations.
    MPUReadValues
                            mov     i2cSDA, gyroSDA          'Use gyro SDA,SCL
                            mov     i2cSCL, gyroSCL
                            mov     i2cAddr, #59            ' Address of ACCEL_XOUT_H
                            mov     i2cDevID, #%11010000    ' Device ID of the MPU
                            call    #StartRead              ' Tell the I2C device we're starting
                            ' // Read Accel, Temp, Gyro  (2 Bytes Each)
                            mov     i2cMask, i2cWordReadMask
                            test    i2cTestCarry, #0 wc     ' Clear the carry flag to make reads auto-increment
                            call    #i2cRead
                            call    #i2cRead
                            'Sign extend the 15th bit
                            test    i2cData, i2cWordReadMask     wc
                            muxc    i2cData, i2cWordMask
                            mov     iaX, i2cData
                            call    #i2cRead
                            call    #i2cRead
                            mov     iaY, i2cData
                            call    #i2cRead
                            call    #i2cRead
                            mov     iaZ, i2cData
                            call    #i2cRead
                            'test    i2cTestCarry, #1 wc      ' Set the carry flag to tell it we're done
                            call    #i2cRead
                            mov     iT, i2cData
                            call    #i2cRead
                            call    #i2cRead
                            mov     irX, i2cData
                            call    #i2cRead
                            call    #i2cRead
                            mov     irY, i2cData
                            call    #i2cRead
                            call    #i2cRead
                            mov     irZ, i2cData
    [B]
                            ' // Should Read 0x68,  Currently Reading 0xD1
                            ' // Read Chip ID  (1 Byte)
                            mov     i2cAddr, WHO_AM_I       ' Address of Magnetometer to Read
                            call    #i2cRead
                            mov     iacID, i2cData
    [/B]
                            ' // Read Magnetometer via AUX Bus
                            mov     i2cAddr, $00            ' Address of Magnetometer Start Read
                            mov     i2cDevID, #%00011000    ' Device ID of the Magnetometer
                            ' // Read Config Info
                            test    i2cTestCarry, #1 wc     ' Clear the carry flag to make reads auto-increment
                            call    #i2cRead
                            'call    #i2cRead
                            mov     iamID, i2cData
                            call    #i2cRead
                            'call    #i2cRead
                            mov     iamInfo, i2cData
                            call    #i2cRead
                            'call    #i2cRead
                            mov     iamStatus, i2cData
                            ' // Start Measurment Readings
                            call    #i2cRead
                            call    #i2cRead
                            mov     iaMX, i2cData
                            call    #i2cRead
                            call    #i2cRead
                            mov     iaMY, i2cData
                            call    #i2cRead
                            call    #i2cRead
                            mov     iaMZ, i2cData
                            call    #i2cStop
    MPUReadValues_Ret       ret
                            ' Compute drift - for my gyro (Jason's ITG-3200)
                            '(Temp + 15000) / 100 = drift
    MPUComputeDrift
                            mov     drift, iT               ' Start with the temperature reading
                            add     drift, tempOffset       ' Offset it by 15,000
                            ' divide drift by 100
                            mov     divisor, #100
                            mov     dividend, drift
                            test    dividend, i2cWordReadMask    wc
                            muxc    signbit, #1             ' record the sign of the original value
                            abs     dividend, dividend
                            mov     divCounter, #10
                            shl     divisor, divCounter
                            mov     resultShifted, #1
                            shl     resultShifted, divCounter
                            add     divCounter, #1
                            mov     drift, #0
    :divLoop
                            cmp     dividend, divisor   wc
                  if_nc     add     drift, resultShifted
                  if_nc     sub     dividend, divisor
                            shr     resultShifted, #1
                            shr     divisor, #1
                            djnz    divCounter, #:divLoop
                            test    signbit, #1     wc
                            negc    drift, drift
    MPUComputeDrift_Ret     ret
    ComputeAngles
                            mov     cx, iaZ
                            mov     cy, iaX
                            call    #cordic
                            mov     iaRX, ca
                            mov     cx, iaZ
                            mov     cy, iaY
                            call    #cordic
                            mov     iaRY, ca
    ComputeAngles_ret       ret
    ' SetConfig
    '  See MPU-6000/6050 Register Map document for register addresses and
    '   valid settings
    SetConfig
                            mov     i2cSCL, gyroSCL
                            call    #i2cReset                'Reset i2c
    :MPUSetConfig           mov     i2cDevID, #%11010000     'Device ID for the MPU-6000/6050
                            ' // Power Management
                            mov     i2cAddr, #107             'Set PWR_MGMT_1 register bit 0 to choose
                            mov     i2cValue, PowerMgmt       ' X gyro as clock source  '
                            call    #i2cWriteRegisterByte
                            mov     i2cValue, #%00000001      ' X gyro as clock source  '
                            ' // Digital Low Pass Filter _ Config
                            mov     i2cAddr, #26
                            mov     i2cValue, #%00000100      'Set DLPF_CONFIG to 4 for 20Hz bandwidth
                            mov     i2cAddr, #26
                            mov     i2cValue, DLP             'Set DLPF_CONFIG to 3 for 40Hz bandwidth
                            ' // Sample Rate Divider
                            mov     i2cAddr, #25              'SMPLRT_DIV = 1 => 1khz/(1+1) = 500hz sample rate
                            mov     i2cAddr, #25              'SMPLRT_DIV = 1 => 1khz/(1+0) = 1000hz sample rate
                            mov     i2cValue, SampleRate
                            ' // Gyro _ Config
                            mov     i2cAddr, #27              'GYRO_CONFIG register, set FS_SEL bits to 3 gives a
                            mov     i2cValue, GyroFS          ' full scale range of +-2000 deg/sec
                            ' // Gyro _ Config
                            mov     i2cValue, #%00011000      ' full scale range of +-2000 deg/sec
                            ' // Accel _ Config
                            mov     i2cAddr, #28              'Set ACCEL_CONFIG register AFS_SEL bits to 1,
                            'mov     i2cValue, #%00001000      ' sets +-4g full scale range
                            mov     i2cValue, #%00010000      ' sets +-8g full scale range
                            call    #i2cWriteRegisterByte     'ACCEL_HPF is zero which turns off high-pass filtering
                            mov     i2cAddr, #28              'Set ACCEL_CONFIG register AFS_SEL bits to 2
                            mov     i2cValue, AccelFS        ' sets +-8g full scale range
                            ' Write_Register(User_Ctrl,    %00000000)   ' 106 - Disable Master Mode
                            ' Write_Register(INT_Pin_Cfg,  %00110010)   ' 55  - INT_Pin_Cfg  i2c Bypass Enabled
                            mov     i2cAddr, User_Ctrl       ' Disable Master Mode
                            mov     i2cValue, #%00000000
                            mov     i2cAddr, INT_Pin_Cfg     ' Enable Pass-Through Mode
                            mov     i2cValue, #%00110010
                            ' // Extra Config Settings:
                            mov     i2cAddr, #Address
                            mov     i2cValue, #%BIN_Value
    SetConfig_Ret
                            ret
    StartRead
                            call    #i2cStart
                            mov     i2cData, i2cDevID
                            mov     i2cMask, #%10000000
                            call    #i2cWrite
                            mov     i2cData, i2cAddr
                            mov     i2cMask,#%10000000
                            call    #i2cWrite
                            call    #i2cStart
                            or      i2cData, #1
                            call    #i2cWrite
    StartRead_Ret           ret
                            call    #i2cStart
                            call    #i2cWrite
                            mov     i2cTime,i2cClkLow
                            add     i2cTime,cnt             ' Allow for minimum SCL low
                            waitcnt i2cTime, #0
                            call    #i2cWrite
                            waitcnt i2cTime, #0
                            mov     i2cData, i2cValue
                            call    #i2cWrite
                            call    #i2cStop
    i2cWriteRegisterByte_Ret
                            ret
    '' Low level I2C routines.  These are designed to work either with a standard I2C bus
    '' (with pullups on both SCL and SDA) or the Propellor Demo Board (with a pullup only
    '' on SDA).  Timing can be set by the caller to 100KHz or 400KHz.
    '' Do I2C Reset Sequence.  Clock up to 9 cycles.  Look for SDA high while SCL
    '' is high.  Device should respond to next Start Sequence.  Leave SCL high.
    i2cReset                andn    dira,i2cSDA             ' Pullup drive SDA high
                            mov     i2cBitCnt,#9            ' Number of clock cycles
    :i2cResetClk            andn    outa,i2cSCL             ' Active drive SCL low
                            or      dira,i2cSCL
                            waitcnt i2cTime,i2cClkHigh
                            or      outa,i2cSCL             ' Active drive SCL high
                            or      dira,i2cSCL
                            andn    dira,i2cSCL             ' Pullup drive SCL high
                            waitcnt i2cTime,i2cClkLow       ' Allow minimum SCL high
                            test    i2cSDA,ina         wz   ' Stop if SDA is high
                  if_z      djnz    i2cBitCnt,#:i2cResetClk ' Stop after 9 cycles
    i2cReset_ret            ret                             ' Should be ready for Start
    '' Do I2C Start Sequence.  This assumes that SDA is a floating input and
    '' SCL is also floating, but may have to be actively driven high and low.
    '' The start sequence is where SDA goes from HIGH to LOW while SCL is HIGH.
    i2cStart
                            or      dira,i2cSCL
                            or      outa,i2cSDA             ' Active drive SDA high
                            or      dira,i2cSDA
                            mov     i2cTime,i2cClkHigh
                            add     i2cTime,cnt             ' Allow for bus free time
                            andn    outa,i2cSDA             ' Active drive SDA low
                            waitcnt i2cTime,#0
    i2cStart_ret            ret
    '' Do I2C Stop Sequence.  This assumes that SCL is low and SDA is indeterminant.
    '' The stop sequence is where SDA goes from LOW to HIGH while SCL is HIGH.
    '' i2cStart must have been called prior to calling this routine for initialization.
    '' The state of the (c) flag is maintained so a write error can be reported.
    i2cStop
                            add     i2cTime,cnt             ' Wait for minimum clock low
                            waitcnt i2cTime,i2cClkLow       ' Wait for minimum setup time
                            waitcnt i2cTime,#0              ' Allow for bus free time
    i2cStop_ret             ret
    '' Write I2C data.  This assumes that i2cStart has been called and that SCL is low,
    '' SDA is indeterminant. The (c) flag will be set on exit from ACK/NAK with ACK == false
    '' and NAK == true. Bytes are handled in "little-endian" order so these routines can be
    '' used with words or longs although the bits are in msb..lsb order.
    i2cWrite                mov     i2cBitCnt,#8
                            add     i2cTime,cnt             ' Wait for minimum SCL low
    :i2cWriteBit            waitcnt i2cTime,i2cDataSet
                            test    i2cData,i2cMask    wz
                  if_z      or      dira,i2cSDA             ' Copy data bit to SDA
                  if_nz     andn    dira,i2cSDA
                            waitcnt i2cTime,i2cClkHigh      ' Wait for minimum setup time
                            ror     i2cMask,#1              ' Go do next bit if not done
                            djnz    i2cBitCnt,#:i2cWriteBit
                            andn    dira,i2cSDA             ' Switch SDA to input and
                            waitcnt i2cTime,i2cClkHigh      '  wait for minimum SCL low
                            waitcnt i2cTime,i2cClkLow       ' Wait for minimum high time
                            test    i2cSDA,ina         wc   ' Sample SDA (ACK/NAK) then
                            andn    outa,i2cSCL             '  active drive SCL low
                            andn    outa,i2cSDA             '  active drive SDA low
                            or      dira,i2cSDA             ' Leave SDA low
                            rol     i2cMask,#16             ' Prepare for multibyte write
                            waitcnt i2cTime,#0              ' Wait for minimum low time
    i2cWrite_ret            ret
    '' Read I2C data.  This assumes that i2cStart has been called and that SCL is low,
    '' SDA is indeterminant.  ACK/NAK will be copied from the (c) flag on entry with
    '' ACK == low and NAK == high.  Bytes are handled in "little-endian" order so these
    '' routines can be used with words or longs although the bits are in msb..lsb order.
    i2cRead                 mov     i2cBitCnt,#8
                            andn    dira,i2cSDA             ' Make sure SDA is set to input
    :i2cReadBit             waitcnt i2cTime,i2cClkHigh
                            waitcnt i2cTime,i2cClkLow       ' Wait for minimum clock high
                            test    i2cSDA,ina         wz   ' Sample SDA for data bits
                  if_nz     or      i2cData,i2cMask         ' Accumulate data bits
                  if_z      andn    i2cData,i2cMask
                            ror     i2cMask,#1              ' Shift the bit mask and
                            djnz    i2cBitCnt,#:i2cReadBit  '  continue until done
                            waitcnt i2cTime,i2cDataSet      ' Wait for end of SCL low
                  if_c      or      outa,i2cSDA             ' Copy the ACK/NAK bit to SDA
                  if_nc     andn    outa,i2cSDA
                            or      dira,i2cSDA             ' Make sure SDA is set to output
                            andn    outa,i2cSDA             ' Leave SDA low
    i2cRead_ret             ret
    ComputeAngles
                            mov     cx, iaZ
                            mov     cy, iaX
                            call    #cordic
                            mov     iaRX, ca
                            mov     cx, iaZ
                            mov     cy, iaY
                            call    #cordic
                            mov     iaRY, ca
    '' Perform CORDIC cartesian-to-polar conversion
    ''Input = cx(x) and cy(x)
    ''Output = cx(ro) and ca(theta)
    cordic                  abs       cx,cx           wc
                  if_c      neg       cy,cy
                            mov       ca,#0
                            rcr       ca,#1
                            movs      :lookup,#cordicTable
                            mov       t1,#0
                            mov       t2,#20
    :loop                   mov       dx,cy           wc
                            sar       dx,t1
                            mov       dy,cx
                            sar       dy,t1
                            sumc      cx,dx
                            sumnc     cy,dy
    :lookup                 sumc      ca,cordicTable
                            add       :lookup,#1
                            add       t1,#1
                            djnz      t2,#:loop
                            shr       ca, #16
    cordic_ret              ret
    cordicTable             long    $20000000
                            long    $12E4051E
                            long    $09FB385B
                            long    $051111D4
                            long    $028B0D43
                            long    $0145D7E1
                            long    $00A2F61E
                            long    $00517C55
                            long    $0028BE53
                            long    $00145F2F
                            long    $000A2F98
                            long    $000517CC
                            long    $00028BE6
                            long    $000145F3
                            long    $0000A2FA
                            long    $0000517D
                            long    $000028BE
                            long    $0000145F
                            long    $00000A30
                            long    $00000518
    dx                      long    0
    dy                      long    0
    cx                      long    0
    cy                      long    0
    ca                      long    0
    t1                      long    0
    t2                      long    0
    '' Variables for the gyro routines
    p1                      long    0
    pT                      long    0                       ' Pointer to Temperature in hub ram
    prX                     long    0                       ' Pointer to X rotation in hub ram
    prY                     long    0                       ' Pointer to Y rotation in hub ram
    prZ                     long    0                       ' Pointer to Z rotation in hub ram
    paX                     long    0                       ' Pointer to X accel in hub ram
    paY                     long    0                       ' Pointer to Y accel in hub ram
    paZ                     long    0                       ' Pointer to Z accel in hub ram
    paRX                    long    0                       ' Pointer to X accel angle in hub ram
    paRY                    long    0                       ' Pointer to Y accel angle in hub ram
    pamID                   long    0
    pamInfo                 long    0
    pamStatus               long    0
    paMX                    long    0
    paMY                    long    0
    paMZ                    long    0
    pacID                   long    0
    iT                      long    0                       ' Interim temperature value
    irX                     long    0                       ' Interim rX value
    irY                     long    0                       ' Interim rY value - These values are temp storage before drift compensation
    irZ                     long    0                       ' Interim rZ value
    iaY                     long    0                       ' Interim aY value
    iaZ                     long    0                       ' Interim aZ value
    iaRX                    long    0                       ' Interim aX value
    iaRY                    long    0                       ' Interim aY value
    iamID                   long    0
    iamInfo                 long    0
    iamStatus               long    0
    iaMX                    long    0
    iaMY                    long    0
    iaMZ                    long    0
    iacID                   long    0
    i2cWordReadMask         long    %10000000_00000000
    i2cWordMask             long    $ffff0000
    loopDelay               long    80_000_000 / 200
    loopCount               long    0
    '' Variables for dealing with drift / division
    tempOffset              long    15000
    drift                   long    0
    divisor                 long    0
    dividend                long    0
    resultShifted           long    0
    signbit                 long    0
    divCounter              long    0
    '' Variables for i2c routines
    i2cTemp                 long    0
    i2cCount                long    0
    i2cValue                long    0
    i2cDevID                long    0
    i2cAddr                 long    0
    i2cDataSet              long    0                       ' Minumum data setup time (ticks)
    i2cClkLow               long    0                       ' Minimum clock low time (ticks)
    i2cClkHigh              long    0                       ' Minimum clock high time (ticks)
    i2cPause                long    0                       ' Pause before re-fetching next operation
    i2cTestCarry            long    1                       ' Used for setting the carry flag
    ' // PASM / Spin Control Settings
    FIFOcnt                 long    %00000000
    FIFOrw                  long    %00000000
    'mID                     long    %00000000
    'mInfo                   long    %00000000
    'mStatus                 long    %00000000
    MM_En                   long    0
    FIFO_Enable             long    0
    Verify_Registers        long    0
    ' // MPU-6050 User Set Init Settings
    GyroFS                  long    %00000000
    AccelFS                 long    %00000000
    PowerMgmt               long    %00000000
    SampleRate              long    %00000000
    DLP                     long    %00000000
    '' Local variables for low level I2C routines
    gyroSCL                 long    0                       ' Bit mask for SCL
    gyroSDA                 long    0                       ' Bit mask for SDA
    i2cSCL                  long    0                       ' Bit mask for SCL
    i2cSDA                  long    0                       ' Bit mask for SDA
    i2cTime                 long    0                       ' Used for timekeeping
    i2cData                 long    0                       ' Data to be transmitted / received
    i2cMask                 long    0                       ' Bit mask for bit to be tx / rx
    i2cBitCnt               long    0                       ' Number of bits to tx / rx
            FIT   496
    Edit: I cannot for the life of me, get pasm to pass info back to spin properly. Or it is not reading it properly or storing it properly in pasm. I really have no idea... Ever try speaking a language you dont know?
    I think I will have better luck gettin my Spin driver working, as it mostly is working now. Just need to get the numbers in the right spot on the numberline. Back to the language thing.
    My pasm driver gives idental results as My spin driver, except for No Mag data or chip id. And all I did was Copy the 6050 pasm driver, and add extra results to it. I didnt change any of the original code.
    Edit2: Just worked on the Spin driver a bit more, it appears that all outputs are correct & to scale.
    edited 2014-02-13 19:18
    WHO_AM_I                  long    $75
    Maybe someone can confirm this, but I am not sure you can use a constant declared in your top program as a valid number in pasm like you are doing. Instead, try to use the device ID as shown by putting it in DAT.
    edited 2014-02-13 20:46
    T Chap wrote: »
    WHO_AM_I                  long    $75
    It didnt do much. I think im going to put the PASM version off to the side as I am horrible with pasm.
    I have my Spin driver working near 100%... I have a little bit shifting question...
    The accel, temp, & gyro reads 2 bits per axis, High bit First
    The Mag reads 2 bits per axis, Low bit First.
    is this the right way to handle the bit shift?:
        mX := i2cRead(0)       ' Mag_X_L
        mX |= i2cRead(0) << 8  ' Mag_X_H
        mY := i2cRead(0)       ' Mag_Y_L
        mY |= i2cRead(0) << 8  ' Mag_Y_H
        mZ := i2cRead(0)       ' Mag_Z_L
        mZ |= i2cRead(1) << 8  ' Mag_Z_H
        ~~mX
        ~~mY
        ~~mZ
    This is the equivalent accel & gyro bit shift, the resulting values, once adjusted, gives clean proper results:
        aX  := i2cRead(0)   << 8
        aX  |= i2cRead(0)
        aY  := i2cRead(0)   << 8
        aY  |= i2cRead(0)
        aZ  := i2cRead(0)   << 8
        aZ  |= i2cRead(0)
        Temp := i2cRead(0)  << 8
        Temp |= i2cRead(0)
        gX  := i2cRead(0)   << 8
        gX  |= i2cRead(0)
        gY  := i2cRead(0)   << 8
        gY  |= i2cRead(0)
        gZ  := i2cRead(0)   << 8
        gZ  |= i2cRead(1)
        ~~aX
        ~~aY
        ~~aZ
        ~~gX
        ~~gY
        ~~gZ
    This is the other associated math that converts the Raw values into something usable:
    ' // Update G-Force, Degrees per Second, and Mag Angle
    Pub UpdateForceVals | faX, faY, faZ, fgX, fgY, fgZ
        ' // Accelerometer
        faX := f.fSub(f.fFloat(aX), 32768.0)
        faY := f.fSub(f.fFloat(aY), 32768.0)
        faZ := f.fSub(f.fFloat(aZ), 32768.0)
        ' // Convert Accel Value to G-Force
        ' G-Force = Accel[x] / 8,192  (AFS-1)
        Accel[0] := f.fAdd(f.fDiv(faX, cAccelFS), 8.0)
        Accel[1] := f.fAdd(f.fDiv(faY, cAccelFS), 8.0)
        Accel[2] := f.fAdd(f.fDiv(faZ, cAccelFS), 8.0)
        ' // Gyroscope
        fgX := f.fSub(f.fFloat(gX), 32768.0)
        fgY := f.fSub(f.fFloat(gY), 32768.0)
        fgZ := f.fSub(f.fFloat(gZ), 32768.0)
        ' // Convert Gyro Value to Degrees per Second
        ' Gyro = Gyro[x] / 16.4       (FS-3)
        Gyro[0] := f.fAdd(f.fDiv(fgX, cGyroFS), 2048.0)
        Gyro[1] := f.fAdd(f.fDiv(fgY, cGyroFS), 2048.0)
        Gyro[2] := f.fAdd(f.fDiv(fgZ, cGyroFS), 2048.0)
        ' // Magnetometer      Max ~= +/- 580
        Mag[0] := f.fFloat(mX)
        Mag[1] := f.fFloat(mY)
        Mag[2] := f.fFloat(mZ)
    I wish pasm was a skill of mine, because the speed at which this runs is much faster. Potentially I could just bit shift to do the same as what I did above much faster, but bit shifting is about the same as pasm to me, a new language. I could try using spin2cpp so I can compile my project with PropellerC, that should make it faster. I'll get it one day!
    Any good asm / pasm books to refrence for learning? I have just ordered the 2 mentioned earlier in this thread.
