Wireless Key Fob Remote issue
TheGrue
I recently purchased a Wireless Key Fob Remote and had it working on my PPD Board for several minutes with D1 connected to a 10K resistor and then to the Propeller pin. The same wiring with the D2-->10K-->Propeller Pin. I had it working for the two main buttons to change the settings of a servo. now after some use all I get is a Red constant LED and I noticed that one of the chips is overheating. Any ideas what could have caused this? Wrong resistor? Mind you I am rusty on my Ohm's Law. Did I fry it?
Do you have an complete wiring diagram for how you connected everything?
Pretty hot to touch. Reading in Fahrenheit. Oh and the laser pointer is off at this close of range. The reading is from this chip:
If so, have you gotten it to work without overheating again? I saw on the manufacture specs that the unit works up to 250' line of site. Have you ever seen how far this remote's maximum range is?
Parallax does not make the item, but resells it.
Please ask more questions if you are having trouble with the product.
BTW: Welcome to the forums!
