PropStick USB discontinued or just out of stock?
Just noticed that the PropStick USB has disappeared from all of the product lists. A site search for the part name takes me to the product page which lists it as not available.
Is this a stock issue or has it been discontinued?
I have a board design nearly completed that was based on using them so I can avoid needing to surface mount critical parts (Prop, USB, Mem, power filters, etc.).
Digikey has the PROPSTICK USB.
They have 11 of them.
Duane J
Thanks for the reply.
My main concern is if they have discontinued the item. The board system that I have designed around the PropStick USB is for use in 4 new systems that I also hope to sell. If it is gone then I will have to redesign my main board or figure out how to make a compatible module. I was hoping to avoid having to do surface mount work. We are a specialty manufacturer and machine shop and while I can easily have the thru-hole boards done in house I don't have the setup for surface mount work.
Kerry S
I here you.
I too like the DIP-40 format.
However I have never had a "Store bought" PropStick. I have made several from scratch using the 40 pin Prop and 2 40 pin DIP sockets, technically these are more like the serial port PropSticks. I rarely need to have the small size afforded by the surface mount parts.
I sure hope parallax doesn't discontinue the PropStick.
All is not lost though. There are several guys that make a board that has the same, or close, pinout.
Duane J
We are planning another production run of the PropStick, not to worry. However, I cannot speak to the long-term availability of the product. Currently monthly sales are just enough to save the product from EOL, but discontinuation may loom in its future should sales drop any lower.
We were planning an update to the board, but after a cost and sales analysis it was determined that it was better to keep the product as-is. Hence the reason for the slight inventory hiccup.
Just want to be completely transparent, since you're planning to use the PropStick in your product.
Jessica
Jessica,
Thank you very much for the information and heads up.
That board is such a nice professionally made multilayer brain board for my setup that even with the added cost it is worth it just for the peace of mind.
If my products take off then hopefully that will add enough to the sales to keep it being viable. If they don't, well then I guess it is all a moot point anyway.
Andrew, that M44D40+ module of yours looks nice. Do you still sell those? I have been using the raw DIP chips + extras on a breadboard for prototyping. Those would be great for fast start stuff where USB is not needed!
Unfortunately my product relies on USB for the user interface connection since the P1 does not have the graphics capabilities I need.
Kerry S.
I appreciate your candour about the product. If it comes to it's EOL what kind of warning can I and others expect?
The form factor of USB Propstick should have broad appeal, but I suspect it is more the high price point, than the design that is pushing the low volumes.
FTDI give some good examples of what prices small-modules can be supplied for.
The pins on the current USB Propstick look labour intensive, perhaps an alternative could help lower the price ?
I've seen some modules with both DIP-holes, and SMD edge-style lands, which allows both forms of mounting.
They are supplied with stick-pins, not soldered. That removes a lot of cost, and expands user choices.
Jessica, any idea when they might be re-stocked?
http://www.freetronics.com/products/leostick
Having the USB as part of the board saves more money. ( it does need 2.0mm thick PCB material.)
I see it as part of a Propeller travelling dev kit with the SD preloaded with PropellerTool, SimpleIDE, and other packages. It also makes for a sensible extension to an RPi or other "real computer" board with a USB HUB for robotics control applications.
The dongle has a DIP-32 footprint, FTDI, SD Card, a 400mA regulator, and allows adding 2 dual channel ADCs or a mix of QuadSPI flash or SRAM. I'm going to great lengths to make it a standard 5MHz crystal offering.
If the volume is high enough, I could get rid of the USB connector, but I think there is a certain utility to having through-hole 5V to 3.3V regulation. As it stands, using special material and adding gold fingers just ain't worth the cost.
Looks cool. Last time I checked I think the Micro-usb connectors were cheaper than the older ones, and are now the standard on Power supplies (which is why RPi changed to Micro-USB on their power )
I was mainly meaning 'PCB as USB' for Parallax production volumes, where the tooling is worth it.
I think it is this one
http://www.findchips.com/avail?part=USB-7201
http://www.mouser.com/ProductDetail/Bud-Industries/USB-7201-C/?qs=sGAEpiMZZMsrGrAVj6eTveSYJQndvkYpOtKeNipBqaQ%3d
Yes, the SD Card is on the bottom and end. The clear part is out of stock at Mouser, but they usually have them.
Steve, your dongle looks real good! (Ummm, that just sounds wrong) Anyway, I like the protection it has with the casing......um, yeah.....
Plus having an SD is a big bonus! Well done!!
Their super flexible to use for experimentation
Here, Andrew, is a picture of one of your M44D40+ Props on a plugboard.
There is a lot of stuff on there:
1. 3.3V regulator with 5V input from a 500mA wall wart.
2. The PC interface is a PropPlug with about 2 feet of 4 wire ribbon cable extension.
3. TX/RX activity light using a pair of yellow LEDs with pulse stretchers monitoring the serial pins at 115kbaud.
4. Flashing a Bi-Colored LED in 7 ways with 2 prop pins using the CTRA counter.
5. SD-Card program and data storage.
6. 2 coil latching relay experiment in making an auto-zero chopper amplifier for thermocouples.
7. PCA9554 8 bit Expander with I2C buss driving some LEDs.
8. And a way cool XProtoLab O-Scope by GaboTronics.
Thanks Andrew for them.
(Sorry about not getting back to you sooner, been very busy.)
Duane J
a little more EEPROM would be nice (it's kinda
what I've been waiting for...)
