1600 Pound Model Rocket
1/10 scale Saturn V rocket has a beautiful flight & perfect parachute deployment. It even lands upright! If the comments are correct, this hobby rocket uses no steel or aluminum. Man, that's a LOT of other materials (cardboard tubes, plywood, maybe carbon fiber ?). Things have changed a bit since I was flying my littles Estes CamRoc! Any rocket builders here?
...a long time ago, in a state far, far away.
One of my loves from when I was a kid. Still fly every now and then. I have an altimeter that lives on a breadboard that I would like to fly one day.
But for a time I did play with Vashon model rockets, which were propelled by pressurized Freon. So while I didn't start any brush fires, I contributed to a few extra holes in the ozone layer. That's right; blame me.
Two of these puppy's to build here. My son has a third.
Been Estes rocket since 1974.
For your reading enjoyment Gordon.
http://www.mindspring.com/~vashon/history.html
http://www.oldrocketforum.com/showthread.php?t=776
It seems the V2 roughly weighed 4500 kg (empty) though, so it is smaller by weight.
http://www.v2rocket.com/start/makeup/design.html
Here are specifics...
http://www.nar.org/cabinet/waiverinst.html
High Powered Rocketry is still considered "model rocketry". They use commercially manufactured motors, though some user assembly is permitted. Metal is allowed in their construction, but I didn't see any upper limit to size. You do have to get FAA permission to fly in most cases. I did not find any information as to whether navigation systems were an issue.
When amateur groups fly teddy bears upto a miniature orbital space station and bring them back safely on a later mission!
Erlend
My one brother had built this really sleek, black, single stage rocket about 12-15 inches long. On it's maiden flight on a perfectly calm day, it went straight up and as best we could tell at max altitude, the parachute charge shot the rocket cartridge out the back instead of popping off the nose cone. Once this happened, the rocket was immediately nose heavy so it went nose down and started heading for the ground......it landed no more than 3 feet from the launcher and stuck itself about 4 inches into the ground. We got very quiet as we realized what had happened and how lucky we were not to be standing *THERE*!
Being 6, 12 and 15 at the time, launch operations shortly resumed.
I had a similar incident, didn't end up as well for the rocket though...
It was a Estes WAC Corporal, it had a long tapered balsa nose cone. The engine popped out instead of the chute and it came straight down and hit the concrete parking spot nearby. The nose cone splinted like an exploding cigar...
C.W.
WOW! That is a beautiful piece of work Dave.
C.W.
There were a number of different fuels used back then (not commercial motors). We used Zn and sulfur fuels. Most groups that used ZN + S used powder fuel packed in the rocket, but in our last year we used fuel made from melting the Zn+sulfur mix into about 8-inch cylindrical sections and loading them into the rockets. We had a number of safeguards (including for the high temperature bath we use casting the sections), but I doubt that would be allowed today.
We did test the fuel and ignitors in the woods behind the school, but could only launch the rockets at an annual meet at an army base in Virginia. We were supposed to keep the altitude under about 10,000 ft, but the advantage of the cast fuel was the long burn time (and density of the fuel). Most powdered Zn + S rockets burned their fuel in less than a second. Our large one kept burning when it went through the clouds. We lost sight of it then, but an Army artillery observer was able to track it and later found it buried on the range and recovered it. (We didn't use parachutes, but planned to in following years.) We took first place at the meet, but the army never told us the altitude it actually went.
Unfortunately, that was the last year of the club. The faculty adviser got married and moved away, and no one else had the necessary 'sense of adventure'.
Tom
October Sky:
http://putlocker.bz/watch-october-sky-online-free-putlocker.html
