5mhz Crystal Substitute in SMC?
Just wanted to make sure I'm not missing something before ordering....
I need a smaller SMC solution.
Is this a suitable substitute for the 5mhz crystal?
http://www.digikey.com/product-detail/en/NX8045GB-5MHZ-STD-CSF-3/644-1202-1-ND/3894081
Phil, I thought it was 6 pf per page 25 of the data sheet. Would 8 pf be close enough?
Another option is a ceramic resonator - slightly lower precision than a Crystal.
http://www.digikey.com/product-detail/en/CSTCR5M00G53Z-R0/490-4720-1-ND/1219380
and if Size matters more than price, the Si504 Prog Osc comes as small as 2x2.5mm SMD, and you can define any Freq you like.
As to ceramic resonators: okay if you're not doing video. The BASIC Stamps all use ceramic resonators, BTW.
Personally, if size is a problem (and I know jmg will disagree), I would use (and have used without issue) a 10 MHz crystal at PLL8x. It is outside the 4-8 MHz stated spec for PLL locking, though.
Just to clarify a bit more, you should be looking for a crystal with 18-20pF of capacitance.
http://www.digikey.com/product-search/en?pv183=6185&pv139=564&pv35=10&pv35=6&pv69=3&FV=fff4000d%2Cfff8016d&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
The crystal 'sees' the two Pin C values in series., so that makes 36pF/Pin -> 18pF ideal Crystal operating point.
A crystal with a different operating point will still oscillate, but not precisely at the factory trim mean value.
The other XTAL options will likely also oscillate, and you could try a series R on XOUT to improve the phase margin if using the higher F settings at 5MHz.
How many ppm do you actually need ?
eg I've found some notes here, on a CMOS inverter oscillator
(Note the pins are not quite the same in ppm/pF)
HC49U/4 Xtal, 11.0592MHz Pull-ability
One Pin is ~ -2.3328ppm/pF pull and the other is ~ -7.052ppm/pF, on HC49U Xtal.
A 24MHz Murata crystal gave -0.332ppm/pF, & -3.132ppm/pF.
Looks like more products are now available.
Only difference I see is the ESR (equivalent series resistance).... is there a critical value needed for use with the prop?
Digikey list of SMC & Through Hole 5mhz 20pf Crystals
There is a diagram of a Pierce oscillator showing the series arrangement of the capacitors here, How-does-the-load-capacitance-of-a-crystal-effect-its-clock?
I couldnt find anything at digikey relating to product id JXG75P2... can you find it there by chance?
http://www.mouser.com/ProductDetail/ABRACON/ABM3C-10000MHZ-D4Y-T/?qs=sGAEpiMZZMsPDM5321osT8c7QnCB39Ur
Of course 10MHz is "outside" the range but that isn't normally a problem unless you are running at the extremes of the Prop operating conditions anyway. Besides Hydra used 10MHz and I have dozens of designs in the field using 10MHz.
And having crashes due to forgetting to change the clkfreq when you trying a few demo codes is not fun.
I'm checking mouser/digikey once a month to see if that 7x4mm 5mhz crystal will show up one day, if it does I will post it.
It allows you to use either a 5 MHz or 10 MHz crystal and handles the details of figuring which crystal is being used and doing the appropriate clock settings. No other programmer or user intervention is required.
Hundreds of times lower accuracy than a quartz crystal - I'd never choose a ceramic resonator myself, there are
many things that want accurate frequencies and low jitter.
Ceramic resonator - +/-5000 ppm typical spec (0.5%, 7 minutes a day, sensitive to temperature)
Quartz crystal - +/-30ppm typical spec. (0.003%, 3 secs/day)
TCXO - +/- 2ppm typical spec. (0.0002%)
Peter can you give a link or product number for the 5x3mm SMD packs? I would like to look at those, that size is just perfect.
The official range for the crystal is 4 to 8 MHz, which gives PLL operation from 64 to 128MHz. 10MHz is a bit outside that range, PLL at 160MHz and prop operation at 80MHz on PLL8. It seems to be working okay for many designs now, but I wonder about extended temperature ranges. Has anyone been using them at extreme temperatures?
I've used a couple of different ones, here are some links to Digikey.
10MHz 12pF 30ppm 48c @100
10MHz 8pF 50ppm 48c @100
