5mhz Crystal Substitute in SMC? — Parallax Forums
JBWolfJBWolf Posts: 405
edited 2013-12-18 14:46 in General Discussion
Just wanted to make sure I'm not missing something before ordering....
I need a smaller SMC solution.
Is this a suitable substitute for the 5mhz crystal?
http://www.digikey.com/product-detail/en/NX8045GB-5MHZ-STD-CSF-3/644-1202-1-ND/3894081
    edited 2013-11-02 15:49
    The load capacitance spec of that crystal is low at 8 pF. I believe the Prop provides more like 18-20 pF, which means the crystal will probalby oscillate, but slightly off the specified frequency.
    edited 2013-11-02 15:56
    It seems like all the really small crystals I've seen in Propeller boards have been 10MHz. The Propeller Backpack uses a 10MHz crystal. Perhaps you can get the part number for Backpack's crystal.
  • hover1hover1 Posts: 1,929
    edited 2013-11-02 15:59
    Phil, I thought it was 6 pf per page 25 of the data sheet. Would 8 pf be close enough?
  • jmgjmg Posts: 15,200
    edited 2013-11-02 16:43
    JBWolf wrote: »
    Another option is a ceramic resonator - slightly lower precision than a Crystal.
    http://www.digikey.com/product-detail/en/CSTCR5M00G53Z-R0/490-4720-1-ND/1219380
    and if Size matters more than price, the Si504 Prog Osc comes as small as 2x2.5mm SMD, and you can define any Freq you like.
    edited 2013-11-02 16:54
    You're looking at the wrong spec. The 6 pF is for I/O pins. The correct spec is on page 14, where it shows 36 pF for both pins (18 pF apiece) for a 4-16 MHz crystal. So, no, 8 pF is not close enough.
    As to ceramic resonators: okay if you're not doing video. The BASIC Stamps all use ceramic resonators, BTW.
    Personally, if size is a problem (and I know jmg will disagree), I would use (and have used without issue) a 10 MHz crystal at PLL8x. It is outside the 4-8 MHz stated spec for PLL locking, though.
  • SRLMSRLM Posts: 5,045
    edited 2013-11-02 17:26
    Just to clarify a bit more, you should be looking for a crystal with 18-20pF of capacitance.
    This apparent discrepancy was explained somewhere, but I wouldn't know where to begin looking for it. I think it was either Mike Green or Tracy Allen who explained it. IIRC, the 36pF figure represents a value that is twice that of the crystal spec. Whether that's because it's the sum of two pins, while the crystal spec is per pin, or something else, I don't remember. But, whatever the reason, 18-20pF is the correct crystal spec to look for in a 5MHz crystal.
    edited 2013-11-02 21:32
    The crystal 'sees' the two Pin C values in series., so that makes 36pF/Pin -> 18pF ideal Crystal operating point.
    A crystal with a different operating point will still oscillate, but not precisely at the factory trim mean value.
    The other XTAL options will likely also oscillate, and you could try a series R on XOUT to improve the phase margin if using the higher F settings at 5MHz.
    How many ppm do you actually need ?
    eg I've found some notes here, on a CMOS inverter oscillator
    (Note the pins are not quite the same in ppm/pF)
    HC49U/4 Xtal, 11.0592MHz Pull-ability
    One Pin is ~ -2.3328ppm/pF pull and the other is ~ -7.052ppm/pF, on HC49U Xtal.
    A 24MHz Murata crystal gave -0.332ppm/pF, & -3.132ppm/pF.
  • JBWolfJBWolf Posts: 405
    edited 2013-12-17 14:38
    - Update -
    Looks like more products are now available.
    Only difference I see is the ESR (equivalent series resistance).... is there a critical value needed for use with the prop?
    Digikey list of SMC & Through Hole 5mhz 20pf Crystals
    edited 2013-12-17 16:11
    In the range of ESR values they quote on the Digikey selection table, it won't make a difference. How small an SMT crystal do you need? I have one 5MHz AT cut 20pF from Jauch, 7mm x 5mm. JXG75P2 series.
    There is a diagram of a Pierce oscillator showing the series arrangement of the capacitors here, How-does-the-load-capacitance-of-a-crystal-effect-its-clock?
    edited 2013-12-17 16:48
    7 x 5 is very nice... my circuit board is 12mm wide, so size is everything. I am using a CNC to cut .385mm wide channels between traces. so almost no component is too small for my use (except some of those microscopic resistors).
    I couldnt find anything at digikey relating to product id JXG75P2... can you find it there by chance?
  • jazzedjazzed Posts: 11,803
    edited 2013-12-17 19:16
    I gave up finding a small enough 5MHz crystal, and decided to use 10MHz instead (5mm x 3.2mm).
    http://www.mouser.com/ProductDetail/ABRACON/ABM3C-10000MHZ-D4Y-T/?qs=sGAEpiMZZMsPDM5321osT8c7QnCB39Ur
    edited 2013-12-17 20:07
    I have used the small cylindrical crystals for quite some time but for the last couple of years I have been using the small 5x3mm SMD packs. Now the reason I use these smaller crystals is not necessarily because they are smaller but because I disagree with SMD lead forming a HC49/4 pack which ends up with ridiculously large pads spaced so far apart. On a typical double sided pcb we don't have all those extra layers for full ground planes and shielding so I choose to use a package that does not obstruct routing tracks from the I/O next to the crystal pins. The result is that I can place the crystal very close to the Prop with high noise immunity and still have my I/O go past the crystal. In contrast the HC49s span the whole width of a QFP and if I had to use the package I'd rather it were through-hole as at least the pads are minimal and closer together.
    Of course 10MHz is "outside" the range but that isn't normally a problem unless you are running at the extremes of the Prop operating conditions anyway. Besides Hydra used 10MHz and I have dozens of designs in the field using 10MHz.
    706 x 548 - 24K
    edited 2013-12-17 20:17
    The Propeller Backpack uses a 10 MHz crystal (due to size contraints), with no reported issues.
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-12-17 20:23
    For a beginner demo board I think a 5mhz crystal is a must, nearly everything in obex have that as default value.
    And having crashes due to forgetting to change the clkfreq when you trying a few demo codes is not fun.
    I'm checking mouser/digikey once a month to see if that 7x4mm 5mhz crystal will show up one day, if it does I will post it.
    edited 2013-12-17 20:31
    tonyp12 wrote:
    For a beginner demo board I think a 5mhz crystal is a must, nearly everything in obex have that as default value. ...
    That's why I wrote clkset.spin:
    │                          CLKSET                          │
    │(c) Copyright 2009 Philip C. Pilgrim (propeller@phipi.com)│
    │            See end of file for terms of use.             │
    This object determines whether a 5MHz or 10MHz crystal is
    being used and sets the PLL accordingly for 80MHz operation.
    The main program should use the following settings:
    CON
      _clkmode      = xtal1 + pll8x
      _xinfreq      = 10_000_000
    OBJ
      clk   : "clkset"
    Then clk.set should be called first in the toplevel program.
    If the crystal is determined to be 5MHz, the clkmode will be
    changed to xtal1 + pll16x. clkfreq will still return 80_000_000.
    Version History
    2009.05.23: WARNING: Trial, tentative, very alpha release!
    PUB  set
    '' Automatically set the pll mode for a 5MHz or 10MHz crystal.
      cognew(@setpll, 0)
    DAT
                  org       0
    setpll        movi      ctra,#%0_00001_011      'Set ctra for pll on no pin at x1.
                  movi      frqa,#%0100_0000_0      'Set frqa for clk / 4 (= 20MHz w/ 10MHz crystal, i.e. too high).
                  add       x,cnt                   'Give PLL time to lock (if it can) and stabilize.
                  waitcnt   x,#0
                  movi      vcfg,#$40               'Configure video for discrete pins, but no pins enabled.
                  mov       vscl,#$10               'Set for 16 clocks per frame.
                  waitvid   0,0                     'Wait once to clear time.
                  neg       x,cnt                   'Read -cnt.
                  waitvid   0,0                     'Wait 16 pll clocks = 64 processor clks.
                  add       x,cnt                   'Compute elapsed time.
                  cmp       x,#$40 wz               'Is it really 64 clocks?
            if_z  mov       x,#$6f                  '  Yes: Crystal is 5MHz. Set clock mode to XTAL1 and PLL16X.
            if_z  clkset    x
                  cogid     x                       'Stop the cog: we're done.
                  cogstop   x
    x             long      $1_0000                 '65536 clks for pll to stabilize.
    │                                                   TERMS OF USE: MIT License                                                  │
    │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation    │
    │files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,    │
    │modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│
    │is furnished to do so, subject to the following conditions:        │
    │The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│
    │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE          │
    │WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR         │
    │COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,   │
    │ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.                         │
    It allows you to use either a 5 MHz or 10 MHz crystal and handles the details of figuring which crystal is being used and doing the appropriate clock settings. No other programmer or user intervention is required.
    edited 2013-12-17 20:46
    Nice idea Phil.
  • Mark_TMark_T Posts: 1,981
    edited 2013-12-18 04:34
    jmg wrote: »
    Hundreds of times lower accuracy than a quartz crystal - I'd never choose a ceramic resonator myself, there are
    many things that want accurate frequencies and low jitter.
    Ceramic resonator - +/-5000 ppm typical spec (0.5%, 7 minutes a day, sensitive to temperature)
    Quartz crystal - +/-30ppm typical spec. (0.003%, 3 secs/day)
    TCXO - +/- 2ppm typical spec. (0.0002%)
    edited 2013-12-18 06:40
    I'll have to take a look at 10mhz crystals... didnt know they were an option, thanks phil! :)
    Peter can you give a link or product number for the 5x3mm SMD packs? I would like to look at those, that size is just perfect.
    edited 2013-12-18 09:07
    Oh, sorry, my 5x7mm 5MHz/20pF crystals were special order full reel from Jauch. A couple of other companies I talked to could not do that combination, but they could start at 6 or 6.25MHz in the 5x7 package. 6.25MHz is nice (as Bill Henning showed) because the Prop can then operate at 100MHz.
    The official range for the crystal is 4 to 8 MHz, which gives PLL operation from 64 to 128MHz. 10MHz is a bit outside that range, PLL at 160MHz and prop operation at 80MHz on PLL8. It seems to be working okay for many designs now, but I wonder about extended temperature ranges. Has anyone been using them at extreme temperatures?
    JBWolf wrote: »
    I've used a couple of different ones, here are some links to Digikey.
    10MHz 12pF 30ppm 48c @100
    10MHz 8pF 50ppm 48c @100
