Propeller II update - BLOG - Page 142 — Parallax Forums
1139140142144145223
    edited 2013-12-17 05:14
    David Betz wrote: »
    Even though it doesn't say so, I assume that all of these instructions wait for a hub slot. Is that correct? Or is there some sort of data cache between to allow them to continue without waiting?
    CALLA's, CALLB's, RETA's, and RETB's must wait for the next hub slot to push or pop the address as a long. There are also PUSHA/PUSHB/POPA/POPB instructions which are just aliases for WRLONG/RDLONG.
    edited 2013-12-17 06:29
    From a quick glance - LOOKS GREAT!
    I'll read the .txt file carefully today.
    Here is the latest instruction set:
    Attachment not found.
    There are now 16-bit immediate jumps and calls that can be relative or absolute. The jumps and calls that end in an underscore ("_") toggle hub execution mode. If you are running in the cog, a CALL_ #address will jump to hub memory. When that routine does a RET, it will return to cog memory. It works the other way, too. A CALL or JMP without an underscore stays in the cog or hub.
    The JMPSW/JMPSWD instruction can be used to switch among threads. It will store {hubmode,Z,C,PC} into D and and load {hubmode,Z,C,PC} from S. So, it tracks threads wherever they are executing. All CALLs and RETs save and restore {hubmode,Z,C,PC}. PC is 16 bits so that it can span the entire 64K longs in the 256KB hub memory.
    Here is the list:
    ZCDS (for D column: W=write, M=modify, R=read, L=read/immediate)
    ZCWS		0000000 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDBYTE	D,S/PTRA/PTRB		(waits for hub)
    ZCWS		0000001 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDBYTEC	D,S/PTRA/PTRB		(waits for hub if cache miss)
    ZCWS		0000010 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDWORD	D,S/PTRA/PTRB		(waits for hub)
    ZCWS		0000011 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDWORDC	D,S/PTRA/PTRB		(waits for hub if cache miss)
    ZCWS		0000100 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDLONG	D,S/PTRA/PTRB		(waits for hub)
    ZCWS		0000101 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDLONGC	D,S/PTRA/PTRB		(waits for hub if cache miss)
    ZCWS		0000110 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDAUX	D,S/#0..$FF/PTRX/PTRY
    ZCWS		0000111 ZC I CCCC DDDDDDDDD SSSSSSSSS		RDAUXR	D,S/#0..$FF/PTRX/PTRY
    ZCMS		0001000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ISOB	D,S/#
    ZCMS		0001001 ZC I CCCC DDDDDDDDD SSSSSSSSS		NOTB	D,S/#
    ZCMS		0001010 ZC I CCCC DDDDDDDDD SSSSSSSSS		CLRB	D,S/#
    ZCMS		0001011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETB	D,S/#
    ZCMS		0001100 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBC	D,S/#
    ZCMS		0001101 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBNC	D,S/#
    ZCMS		0001110 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBZ	D,S/#
    ZCMS		0001111 ZC I CCCC DDDDDDDDD SSSSSSSSS		SETBNZ	D,S/#
    ZCMS		0010000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ANDN	D,S/#
    ZCMS		0010001 ZC I CCCC DDDDDDDDD SSSSSSSSS		AND	D,S/#
    ZCMS		0010010 ZC I CCCC DDDDDDDDD SSSSSSSSS		OR	D,S/#
    ZCMS		0010011 ZC I CCCC DDDDDDDDD SSSSSSSSS		XOR	D,S/#
    ZCMS		0010100 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXC	D,S/#
    ZCMS		0010101 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXNC	D,S/#
    ZCMS		0010110 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXZ	D,S/#
    ZCMS		0010111 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUXNZ	D,S/#
    ZCMS		0011000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ROR	D,S/#
    ZCMS		0011001 ZC I CCCC DDDDDDDDD SSSSSSSSS		ROL	D,S/#
    ZCMS		0011010 ZC I CCCC DDDDDDDDD SSSSSSSSS		SHR	D,S/#
    ZCMS		0011011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SHL	D,S/#
    ZCMS		0011100 ZC I CCCC DDDDDDDDD SSSSSSSSS		RCR	D,S/#
    ZCMS		0011101 ZC I CCCC DDDDDDDDD SSSSSSSSS		RCL	D,S/#
    ZCMS		0011110 ZC I CCCC DDDDDDDDD SSSSSSSSS		SAR	D,S/#
    ZCMS		0011111 ZC I CCCC DDDDDDDDD SSSSSSSSS		REV	D,S/#
    ZCWS		0100000 ZC I CCCC DDDDDDDDD SSSSSSSSS		MOV	D,S/#
    ZCWS		0100001 ZC I CCCC DDDDDDDDD SSSSSSSSS		NOT	D,S/#
    ZCWS		0100010 ZC I CCCC DDDDDDDDD SSSSSSSSS		ABS	D,S/#
    ZCWS		0100011 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEG	D,S/#
    ZCWS		0100100 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGC	D,S/#
    ZCWS		0100101 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGNC	D,S/#
    ZCWS		0100110 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGZ	D,S/#
    ZCWS		0100111 ZC I CCCC DDDDDDDDD SSSSSSSSS		NEGNZ	D,S/#
    ZCMS		0101000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADD	D,S/#
    ZCMS		0101001 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUB	D,S/#
    ZCMS		0101010 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDX	D,S/#
    ZCMS		0101011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBX	D,S/#
    ZCMS		0101100 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDS	D,S/#
    ZCMS		0101101 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBS	D,S/#
    ZCMS		0101110 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDSX	D,S/#
    ZCMS		0101111 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBSX	D,S/#
    ZCMS		0110000 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMC	D,S/#
    ZCMS		0110001 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMNC	D,S/#
    ZCMS		0110010 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMZ	D,S/#
    ZCMS		0110011 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUMNZ	D,S/#
    ZCMS		0110100 ZC I CCCC DDDDDDDDD SSSSSSSSS		MIN	D,S/#
    ZCMS		0110101 ZC I CCCC DDDDDDDDD SSSSSSSSS		MAX	D,S/#
    ZCMS		0110110 ZC I CCCC DDDDDDDDD SSSSSSSSS		MINS	D,S/#
    ZCMS		0110111 ZC I CCCC DDDDDDDDD SSSSSSSSS		MAXS	D,S/#
    ZCMS		0111000 ZC I CCCC DDDDDDDDD SSSSSSSSS		ADDABS	D,S/#
    ZCMS		0111001 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBABS	D,S/#
    ZCMS		0111010 ZC I CCCC DDDDDDDDD SSSSSSSSS		INCMOD	D,S/#
    ZCMS		0111011 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECMOD	D,S/#
    ZCMS		0111100 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPSUB	D,S/#
    ZCMS		0111101 ZC I CCCC DDDDDDDDD SSSSSSSSS		SUBR	D,S/#
    ZCMS		0111110 ZC I CCCC DDDDDDDDD SSSSSSSSS		MUL	D,S/#			(waits one clock)
    ZCMS		0111111 ZC I CCCC DDDDDDDDD SSSSSSSSS		SCL	D,S/#			(waits one clock)
    ZCWS		1000000 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD2	D,S/#
    ZCWS		1000001 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD3	D,S/#
    ZCWS		1000010 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD4	D,S/#
    ZCWS		1000011 ZC I CCCC DDDDDDDDD SSSSSSSSS		DECOD5	D,S/#
    Z-WS		1000100 Z0 I CCCC DDDDDDDDD SSSSSSSSS		ENCOD	D,S/#
    Z-WS		1000100 Z1 I CCCC DDDDDDDDD SSSSSSSSS		BLMASK	D,S/#
    Z-WS		1000101 Z0 I CCCC DDDDDDDDD SSSSSSSSS		ONECNT	D,S/#			(waits one clock)
    Z-WS		1000101 Z1 I CCCC DDDDDDDDD SSSSSSSSS		ZERCNT	D,S/#			(waits one clock)
    -CWS		1000110 0C I CCCC DDDDDDDDD SSSSSSSSS		INCPAT	D,S/#
    -CWS		1000110 1C I CCCC DDDDDDDDD SSSSSSSSS		DECPAT	D,S/#
    --WS		1000111 00 I CCCC DDDDDDDDD SSSSSSSSS		SPLITB	D,S/#			(also MERGEN)
    --WS		1000111 01 I CCCC DDDDDDDDD SSSSSSSSS		MERGEB	D,S/#			(also SPLITN)
    --WS		1000111 10 I CCCC DDDDDDDDD SSSSSSSSS		SPLITW	D,S/#
    --WS		1000111 11 I CCCC DDDDDDDDD SSSSSSSSS		MERGEW	D,S/#
    --MS		10010nn n0 I CCCC DDDDDDDDD SSSSSSSSS		GETNIB	D,S/#,#0..7
    --MS		10010nn n1 I CCCC DDDDDDDDD SSSSSSSSS		SETNIB	D,S/#,#0..7
    --MS		1001100 n0 I CCCC DDDDDDDDD SSSSSSSSS		GETWORD	D,S/#,#0..1
    --MS		1001100 n1 I CCCC DDDDDDDDD SSSSSSSSS		SETWORD	D,S/#,#0..1
    --MS		1001101 00 I CCCC DDDDDDDDD SSSSSSSSS		STWORDS	D,S/#
    --MS		1001101 01 I CCCC DDDDDDDDD SSSSSSSSS		ROLNIB	D,S/#
    --MS		1001101 10 I CCCC DDDDDDDDD SSSSSSSSS		ROLBYTE	D,S/#
    --MS		1001101 11 I CCCC DDDDDDDDD SSSSSSSSS		ROLWORD	D,S/#
    --MS		1001110 00 I CCCC DDDDDDDDD SSSSSSSSS		SETS	D,S/#
    --MS		1001110 01 I CCCC DDDDDDDDD SSSSSSSSS		SETD	D,S/#
    --MS		1001110 10 I CCCC DDDDDDDDD SSSSSSSSS		SETX	D,S/#
    --MS		1001110 11 I CCCC DDDDDDDDD SSSSSSSSS		SETI	D,S/#
    -CMS		1001111 0C I CCCC DDDDDDDDD SSSSSSSSS		COGNEW	D,S/#			(waits for hub)
    -CMS		1001111 1C I CCCC DDDDDDDDD SSSSSSSSS		WAITCNT	D,S/#			(waits for CNT, +CNTX if WC)
    --MS		101000n n0 I CCCC DDDDDDDDD SSSSSSSSS		GETBYTE	D,S/#,#0..3
    --MS		101000n n1 I CCCC DDDDDDDDD SSSSSSSSS		SETBYTE	D,S/#,#0..3
    --WS		1010010 00 I CCCC DDDDDDDDD SSSSSSSSS		STBYTES	D,S/#
    --MS		1010010 01 I CCCC DDDDDDDDD SSSSSSSSS		SWBYTES	D,S/#			(switch/copy bytes in D, S = %11_10_01_00 = D same)
    --MS		1010010 10 I CCCC DDDDDDDDD SSSSSSSSS		PACKRGB	D,S/#			(S 8:8:8 -> D 5:5:5 << 16 | D >> 16)
    --WS		1010010 11 I CCCC DDDDDDDDD SSSSSSSSS		UNPKRGB	D,S/#			(S 5:5:5 -> D 8:8:8)
    --MS		1010011 00 I CCCC DDDDDDDDD SSSSSSSSS		ADDPIX	D,S/#			(waits one clock)
    --MS		1010011 01 I CCCC DDDDDDDDD SSSSSSSSS		MULPIX	D,S/#			(waits one clock)
    --MS		1010011 10 I CCCC DDDDDDDDD SSSSSSSSS		BLNPIX	D,S/#			(waits one clock)
    --MS		1010011 11 I CCCC DDDDDDDDD SSSSSSSSS		MIXPIX	D,S/#			(waits one clock)
    ZCMS		1010100 ZC I CCCC DDDDDDDDD SSSSSSSSS		JMPSW	D,S/#
    ZCMS		1010101 ZC I CCCC DDDDDDDDD SSSSSSSSS		JMPSWD	D,S/#
    --MS		1010110 00 I CCCC DDDDDDDDD SSSSSSSSS		IJZ	D,S/#
    --MS		1010110 01 I CCCC DDDDDDDDD SSSSSSSSS		IJZD	D,S/#
    --MS		1010110 10 I CCCC DDDDDDDDD SSSSSSSSS		IJNZ	D,S/#
    --MS		1010110 11 I CCCC DDDDDDDDD SSSSSSSSS		IJNZD	D,S/#
    --MS		1010111 00 I CCCC DDDDDDDDD SSSSSSSSS		DJZ	D,S/#
    --MS		1010111 01 I CCCC DDDDDDDDD SSSSSSSSS		DJZD	D,S/#
    --MS		1010111 10 I CCCC DDDDDDDDD SSSSSSSSS		DJNZ	D,S/#
    --MS		1010111 11 I CCCC DDDDDDDDD SSSSSSSSS		DJNZD	D,S/#
    ZCRS		1011000 ZC I CCCC DDDDDDDDD SSSSSSSSS		TESTB	D,S/#
    ZCRS		1011001 ZC I CCCC DDDDDDDDD SSSSSSSSS		TESTN	D,S/#
    ZCRS		1011010 ZC I CCCC DDDDDDDDD SSSSSSSSS		TEST	D,S/#
    ZCRS		1011011 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMP	D,S/#
    ZCRS		1011100 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPX	D,S/#
    ZCRS		1011101 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPS	D,S/#
    ZCRS		1011110 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPSX	D,S/#
    ZCRS		1011111 ZC I CCCC DDDDDDDDD SSSSSSSSS		CMPR	D,S/#
    --RS		11000nn n0 I CCCC DDDDDDDDD SSSSSSSSS		COGINIT	D,S/#,#0..7		(waits for hub) (SETNIB :coginit,cog,#6)
    ---S		11000nn n1 I CCCC nnnnnnnnn SSSSSSSSS		WAITVID	#0..$DFF,S/#		(waits for vid if single-task, loops if multi-task)
    --RS		1100011 11 I CCCC DDDDDDDDD SSSSSSSSS		WAITVID	D,S/#			(waits for vid if single-task, loops if multi-task)
    -CRS		110010n nC I CCCC DDDDDDDDD SSSSSSSSS		WAITPEQ	D,S/#,#0..3		(waits for pins, plus CNT if WC)
    -CRS		110011n nC I CCCC DDDDDDDDD SSSSSSSSS		WAITPNE	D,S/#,#0..3		(waits for pins, plus CNT if WC)
    --LS		1101000 0L I CCCC DDDDDDDDD SSSSSSSSS		WRBYTE	D/#,S/PTRA/PTRB		(waits for hub)
    --LS		1101000 1L I CCCC DDDDDDDDD SSSSSSSSS		WRWORD	D/#,S/PTRA/PTRB		(waits for hub)
    --LS		1101001 0L I CCCC DDDDDDDDD SSSSSSSSS		WRLONG	D/#,S/PTRA/PTRB		(waits for hub)
    --LS		1101001 1L I CCCC DDDDDDDDD SSSSSSSSS		FRAC	D/#,S/#
    --LS		1101010 0L I CCCC DDDDDDDDD SSSSSSSSS		WRAUX	D/#,S/#0..$FF/PTRX/PTRY
    --LS		1101010 1L I CCCC DDDDDDDDD SSSSSSSSS		WRAUXR	D/#,S/#0..$FF/PTRX/PTRY
    --LS		1101011 0L I CCCC DDDDDDDDD SSSSSSSSS		SETACCA	D/#,S/#
    --LS		1101011 1L I CCCC DDDDDDDDD SSSSSSSSS		SETACCB	D/#,S/#
    --LS		1101100 0L I CCCC DDDDDDDDD SSSSSSSSS		MACA	D/#,S/#
    --LS		1101100 1L I CCCC DDDDDDDDD SSSSSSSSS		MACB	D/#,S/#
    --LS		1101101 0L I CCCC DDDDDDDDD SSSSSSSSS		MUL32	D/#,S/#
    --LS		1101101 1L I CCCC DDDDDDDDD SSSSSSSSS		MUL32U	D/#,S/#
    --LS		1101110 0L I CCCC DDDDDDDDD SSSSSSSSS		DIV32	D/#,S/#
    --LS		1101110 1L I CCCC DDDDDDDDD SSSSSSSSS		DIV32U	D/#,S/#
    --LS		1101111 0L I CCCC DDDDDDDDD SSSSSSSSS		DIV64	D/#,S/#
    --LS		1101111 1L I CCCC DDDDDDDDD SSSSSSSSS		DIV64U	D/#,S/#
    --LS		1110000 0L I CCCC DDDDDDDDD SSSSSSSSS		SQRT64	D/#,S/#
    --LS		1110000 1L I CCCC DDDDDDDDD SSSSSSSSS		QSINCOS	D/#,S/#
    --LS		1110001 0L I CCCC DDDDDDDDD SSSSSSSSS		QARCTAN	D/#,S/#
    --LS		1110001 1L I CCCC DDDDDDDDD SSSSSSSSS		QROTATE	D/#,S/#
    --LS		1110010 0L I CCCC DDDDDDDDD SSSSSSSSS		SETSERA	D/#,S/#			(config,baud)
    --LS		1110010 1L I CCCC DDDDDDDDD SSSSSSSSS		SETSERB	D/#,S/#			(config,baud)
    --LS		1110011 0L I CCCC DDDDDDDDD SSSSSSSSS		SETCTRS	D/#,S/#			(ctrb,ctra)
    --LS		1110011 1L I CCCC DDDDDDDDD SSSSSSSSS		SETWAVS	D/#,S/#			(ctrb,ctra)
    --LS		1110100 0L I CCCC DDDDDDDDD SSSSSSSSS		SETFRQS	D/#,S/#			(ctrb,ctra)
    --LS		1110100 1L I CCCC DDDDDDDDD SSSSSSSSS		SETPHSS	D/#,S/#			(ctrb,ctra)
    --LS		1110101 0L I CCCC DDDDDDDDD SSSSSSSSS		ADDPHSS	D/#,S/#			(ctrb,ctra)
    --LS		1110101 1L I CCCC DDDDDDDDD SSSSSSSSS		SUBPHSS	D/#,S/#			(ctrb,ctra)
    --LS		1110110 0L I CCCC DDDDDDDDD SSSSSSSSS		JP	D/#,S/#
    --LS		1110110 1L I CCCC DDDDDDDDD SSSSSSSSS		JPD	D/#,S/#
    --LS		1110111 0L I CCCC DDDDDDDDD SSSSSSSSS		JNP	D/#,S/#
    --LS		1110111 1L I CCCC DDDDDDDDD SSSSSSSSS		JNPD	D/#,S/#
    --LS		111100n nL I CCCC DDDDDDDDD SSSSSSSSS		CFGPINS	D/#,S/#,#0..2		(waits for alt)
    --LS		1111001 1L I CCCC DDDDDDDDD SSSSSSSSS		JMPTASK	D/#,S/#			(mode:mask,address)
    --LS		1111010 0L I CCCC DDDDDDDDD SSSSSSSSS		SETXFR	D/#,S/#
    --LS		1111010 1L I CCCC DDDDDDDDD SSSSSSSSS		SETMIX	D/#,S/#
    --LS		1111011 0L I CCCC DDDDDDDDD SSSSSSSSS		<empty>	D/#,S/#
    --LS		1111011 1L I CCCC DDDDDDDDD SSSSSSSSS		<empty>	D/#,S/#
    --RS		1111100 00 I CCCC DDDDDDDDD SSSSSSSSS		JZ	D,S/#
    --RS		1111100 01 I CCCC DDDDDDDDD SSSSSSSSS		JZD	D,S/#
    --RS		1111100 10 I CCCC DDDDDDDDD SSSSSSSSS		JNZ	D,S/#
    --RS		1111100 11 I CCCC DDDDDDDDD SSSSSSSSS		JNZD	D,S/#
    ----		1111101 00 n nnnn nnnnnnnnn nnnnnnnnn		AUGI	#23bits			(appends n to upper bits of next S or D immediate)
    ----		1111101 01 0 nnnn nnnnnnnnn nnniiiiii		REPS	#1..$10000,#1..64
    ----		1111101 01 1 BBAA ddddddddd sssssssss		FIXINDA #d,#s / FIXINDB #d,#s / FIXINDS #d,#s / SETINDA #s / SETINDB #d / SETINDS #d,#s
    ----		1111101 10 0 CCCC 00 nnnnnnnnnnnnnnnn		JMP	#abs
    ----		1111101 10 0 CCCC 01 nnnnnnnnnnnnnnnn		JMP_	#abs
    ----		1111101 10 0 CCCC 10 nnnnnnnnnnnnnnnn		JMP	@rel
    ----		1111101 10 0 CCCC 11 nnnnnnnnnnnnnnnn		JMP_	@rel
    ----		1111101 10 1 CCCC 00 nnnnnnnnnnnnnnnn		JMPD	#abs
    ----		1111101 10 1 CCCC 01 nnnnnnnnnnnnnnnn		JMPD_	#abs
    ----		1111101 10 1 CCCC 10 nnnnnnnnnnnnnnnn		JMPD	@rel
    ----		1111101 10 1 CCCC 11 nnnnnnnnnnnnnnnn		JMPD_	@rel
    ----		1111101 11 0 CCCC 00 nnnnnnnnnnnnnnnn		CALL	#abs
    ----		1111101 11 0 CCCC 01 nnnnnnnnnnnnnnnn		CALL_	#abs
    ----		1111101 11 0 CCCC 10 nnnnnnnnnnnnnnnn		CALL	@rel
    ----		1111101 11 0 CCCC 11 nnnnnnnnnnnnnnnn		CALL_	@rel
    ----		1111101 11 1 CCCC 00 nnnnnnnnnnnnnnnn		CALLD	#abs
    ----		1111101 11 1 CCCC 01 nnnnnnnnnnnnnnnn		CALLD_	#abs
    ----		1111101 11 1 CCCC 10 nnnnnnnnnnnnnnnn		CALLD	@rel
    ----		1111101 11 1 CCCC 11 nnnnnnnnnnnnnnnn		CALLD_	@rel
    ----		1111110 00 0 CCCC 00 nnnnnnnnnnnnnnnn		CALLA	#abs
    ----		1111110 00 0 CCCC 01 nnnnnnnnnnnnnnnn		CALLA_	#abs
    ----		1111110 00 0 CCCC 10 nnnnnnnnnnnnnnnn		CALLA	@rel
    ----		1111110 00 0 CCCC 11 nnnnnnnnnnnnnnnn		CALLA_	@rel
    ----		1111110 00 1 CCCC 00 nnnnnnnnnnnnnnnn		CALLAD	#abs
    ----		1111110 00 1 CCCC 01 nnnnnnnnnnnnnnnn		CALLAD_	#abs
    ----		1111110 00 1 CCCC 10 nnnnnnnnnnnnnnnn		CALLAD	@rel
    ----		1111110 00 1 CCCC 11 nnnnnnnnnnnnnnnn		CALLAD_	@rel
    ----		1111110 01 0 CCCC 00 nnnnnnnnnnnnnnnn		CALLB	#abs
    ----		1111110 01 0 CCCC 01 nnnnnnnnnnnnnnnn		CALLB_	#abs
    ----		1111110 01 0 CCCC 10 nnnnnnnnnnnnnnnn		CALLB	@rel
    ----		1111110 01 0 CCCC 11 nnnnnnnnnnnnnnnn		CALLB_	@rel
    ----		1111110 01 1 CCCC 00 nnnnnnnnnnnnnnnn		CALLBD	#abs
    ----		1111110 01 1 CCCC 01 nnnnnnnnnnnnnnnn		CALLBD_	#abs
    ----		1111110 01 1 CCCC 10 nnnnnnnnnnnnnnnn		CALLBD	@rel
    ----		1111110 01 1 CCCC 11 nnnnnnnnnnnnnnnn		CALLBD_	@rel
    ----		1111110 10 0 CCCC 00 nnnnnnnnnnnnnnnn		CALLX	#abs
    ----		1111110 10 0 CCCC 01 nnnnnnnnnnnnnnnn		CALLX_	#abs
    ----		1111110 10 0 CCCC 10 nnnnnnnnnnnnnnnn		CALLX	@rel
    ----		1111110 10 0 CCCC 11 nnnnnnnnnnnnnnnn		CALLX_	@rel
    ----		1111110 10 1 CCCC 00 nnnnnnnnnnnnnnnn		CALLXD	#abs
    ----		1111110 10 1 CCCC 01 nnnnnnnnnnnnnnnn		CALLXD_	#abs
    ----		1111110 10 1 CCCC 10 nnnnnnnnnnnnnnnn		CALLXD	@rel
    ----		1111110 10 1 CCCC 11 nnnnnnnnnnnnnnnn		CALLXD_	@rel
    ----		1111110 11 0 CCCC 00 nnnnnnnnnnnnnnnn		CALLY	#abs
    ----		1111110 11 0 CCCC 01 nnnnnnnnnnnnnnnn		CALLY_	#abs
    ----		1111110 11 0 CCCC 10 nnnnnnnnnnnnnnnn		CALLY	@rel
    ----		1111110 11 0 CCCC 11 nnnnnnnnnnnnnnnn		CALLY_	@rel
    ----		1111110 11 1 CCCC 00 nnnnnnnnnnnnnnnn		CALLYD	#abs
    ----		1111110 11 1 CCCC 01 nnnnnnnnnnnnnnnn		CALLYD_	#abs
    ----		1111110 11 1 CCCC 10 nnnnnnnnnnnnnnnn		CALLYD	@rel
    ----		1111110 11 1 CCCC 11 nnnnnnnnnnnnnnnn		CALLYD_	@rel
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000000		COGID	D			(waits for hub) (doesn't write D if WC)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000001		LOCKNEW	D			(waits for hub)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000010		GETPC	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000011		GETLFSR	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000100		GETCNT	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000101		GETCNTX	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000110		GETACAL	D			(waits for mac)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000000111		GETACAH	D			(waits for mac)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001000		GETACBL	D			(waits for mac)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001001		GETACBH	D			(waits for mac)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001010		GETPTRA	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001011		GETPTRB	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001100		GETPTRX	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001101		GETPTRY	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001110		SERINA	D			(waits for rx if single-task, loops if multi-task, releases if WC)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000001111		SERINB	D			(waits for rx if single-task, loops if multi-task, releases if WC)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010000		GETMULL	D			(waits for mul if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010001		GETMULH	D			(waits for mul if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010010		GETDIVQ	D			(waits for div if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010011		GETDIVR	D			(waits for div if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010100		GETSQRT	D			(waits for sqrt if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010101		GETQX	D			(waits for cordic if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010110		GETQY	D			(waits for cordic if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000010111		GETQZ	D			(waits for cordic if single-task, loops if multi-task)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011000		GETPHSA	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011001		GETPHZA	D			(clears phsa)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011010		GETCOSA	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011011		GETSINA	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011100		GETPHSB	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011101		GETPHZB	D			(clears phsb)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011110		GETCOSB	D
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000011111		GETSINB	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100000		PUSHZC	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100001		POPZC	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100010		SUBCNT	D			(subtracts D from CNT, then CNTX if same thread)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100011		GETPIX	D			(takes 3 clocks, needs 3 clocks per two prior stages, no condition allowed)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100100		BINBCD	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100101		BCDBIN	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100110		BINGRY	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000100111		GRYBIN	D			(waits one clock)
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101000		ESWAP4	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101001		ESWAP8	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101010		SEUSSF	D
    ZCM-		1111111 ZC 0 CCCC DDDDDDDDD 000101011		SEUSSR	D
    Z-M-		1111111 ZC 0 CCCC DDDDDDDDD 000101100		INCD	D			(D += $200)
    Z-M-		1111111 ZC 0 CCCC DDDDDDDDD 000101101		DECD	D			(D -= $200)
    Z-M-		1111111 ZC 0 CCCC DDDDDDDDD 000101110		INCDS	D			(D += $201)
    Z-M-		1111111 ZC 0 CCCC DDDDDDDDD 000101111		DECDS	D			(D -= $201)
    ZCW-		1111111 ZC 0 CCCC DDDDDDDDD 000110000		POP	D			(pops from task's tiny stack)
    --L-		1111111 00 L CCCC DDDDDDDDD 001iiiiii		REPD	D/#1..512,#1..64	(REPD $1FF,#1..64 = infinite repeat, can use REPD #i)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000000		CLKSET	D/#			(waits for hub)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000001		COGSTOP	D/#			(waits for hub)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010000010		LOCKSET	D/#			(waits for hub)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010000011		LOCKCLR	D/#			(waits for hub)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000100		LOCKRET	D/#			(waits for hub)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000101		RDWIDEC	D/PTRA/PTRB		(waits for hub if cache miss)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000110		RDWIDE	D/PTRA/PTRB		(waits for hub)
    --L-		1111111 00 L CCCC DDDDDDDDD 010000111		WRWIDE	D/PTRA/PTRB		(waits for hub)
    ZCL-		1111111 ZC L CCCC DDDDDDDDD 010001000		GETP	D/#			(pin into !Z/C via WZ/WC)
    ZCL-		1111111 ZC L CCCC DDDDDDDDD 010001001		GETNP	D/#			(pin into Z/!C via WZ/WC)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001010		SEROUTA	D/#			(waits for tx if single-task, loops if multi-task, releases if WC)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001011		SEROUTB	D/#			(waits for tx if single-task, loops if multi-task, releases if WC)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001100		CMPCNT	D/#			(subtracts D from CNT, then CNTX if same thread)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001101		WAITPX	D/#			(waits for any edge, +CNT if WC)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001110		WAITPR	D/#			(waits for pos edge, +CNT if WC)
    -CL-		1111111 0C L CCCC DDDDDDDDD 010001111		WAITPF	D/#			(waits for neg edge, +CNT if WC)
    ZCL-		1111111 ZC L CCCC DDDDDDDDD 010010000		SETZC	D/#			(D[1:0] into Z/C via WZ/WC)
    --L-		1111111 00 L CCCC DDDDDDDDD 010010001		SETMAP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010010010		SETXCH	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010010011		SETTASK	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010010100		SETRACE	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010010101		SARACCA	D/#			(waits for mac)
    --L-		1111111 00 L CCCC DDDDDDDDD 010010110		SARACCB	D/#			(waits for mac)
    --L-		1111111 00 L CCCC DDDDDDDDD 010010111		SARACCS	D/#			(waits for mac)
    --L-		1111111 00 L CCCC DDDDDDDDD 010011000		SETPTRA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011001		SETPTRB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011010		ADDPTRA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011011		ADDPTRB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011100		SUBPTRA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011101		SUBPTRB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011110		SETWIDE	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010011111		SETWIDZ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100000		SETPTRX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100001		SETPTRY	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100010		ADDPTRX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100011		ADDPTRY	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100100		SUBPTRX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100101		SUBPTRY	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010100110		PASSCNT	D/#			(loops if (CNT - D) msb set)
    --L-		1111111 00 L CCCC DDDDDDDDD 010100111		WAIT	D/#			(waits 1+ clocks, 0 same as 1)
    --L-		1111111 00 L CCCC DDDDDDDDD 010101000		OFFP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101001		NOTP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101010		CLRP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101011		SETP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101100		SETPC	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101101		SETPNC	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101110		SETPZ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010101111		SETPNZ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110000		DIV64D	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110001		SQRT32	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110010		QLOG	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110011		QEXP	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110100		SETQI	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110101		SETQZ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110110		CFGDACS	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010110111		SETDACS	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111000		CFGDAC0	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111001		CFGDAC1	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111010		CFGDAC2	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111011		CFGDAC3	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111100		SETDAC0	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111101		SETDAC1	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111110		SETDAC2	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 010111111		SETDAC3	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000000		SETCTRA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000001		SETWAVA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000010		SETFRQA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000011		SETPHSA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000100		ADDPHSA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000101		SUBPHSA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000110		SETVID	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011000111		SETVIDY	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001000		SETCTRB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001001		SETWAVB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001010		SETFRQB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001011		SETPHSB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001100		ADDPHSB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001101		SUBPHSB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001110		SETVIDI	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011001111		SETVIDQ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010000		SETPIX	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010001		SETPIXZ	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010010		SETPIXU	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010011		SETPIXV	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010100		SETPIXA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010101		SETPIXR	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010110		SETPIXG	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011010111		SETPIXB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011011000		SETPORA	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011011001		SETPORB	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011011010		SETPORC	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011011011		SETPORD	D/#
    --L-		1111111 00 L CCCC DDDDDDDDD 011011100		PUSH	D/#			(pushes into task's tiny stack)
    --R-		1111111 00 0 CCCC DDDDDDDDD 011100110		JMPREL	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011100111		JMPRELD	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011101000		JMP	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011101001		JMP_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011101010		JMPD	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011101011		JMPD_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011101100		CALL	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011101101		CALL_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011101110		CALLD	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011101111		CALLD_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011110000		CALLA	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011110001		CALLA_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011110010		CALLAD	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011110011		CALLAD_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011110100		CALLB	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011110101		CALLB_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011110110		CALLBD	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011110111		CALLBD_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011111000		CALLX	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011111001		CALLX_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011111010		CALLXD	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011111011		CALLXD_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011111100		CALLY	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011111101		CALLY_	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011111110		CALLYD	D
    --R-		1111111 00 0 CCCC DDDDDDDDD 011111111		CALLYD_	D
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100000000		RETA
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100000001		RETAD
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100000010		RETB
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100000011		RETBD
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100000100		RETX
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100000101		RETXD
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100000110		RETY
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100000111		RETYD
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100001000		RET
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100001001		RETD
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100001010		POLCTRA				(ctra-rollover into !Z/C)
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100001011		POLCTRB				(ctra-rollover into !Z/C)
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100001100		POLVID				(vid-ready into !Z/C)
    ----		1111111 00 x CCCC xxxxxxxxx 100001101		CAPCTRA
    ----		1111111 00 x CCCC xxxxxxxxx 100001110		CAPCTRB
    ----		1111111 00 x CCCC xxxxxxxxx 100001111		CAPCTRS
    ----		1111111 00 x CCCC xxxxxxxxx 100010000		CACHEX
    ----		1111111 00 x CCCC xxxxxxxxx 100010001		CLRACCA
    ----		1111111 00 x CCCC xxxxxxxxx 100010010		CLRACCB
    ----		1111111 00 x CCCC xxxxxxxxx 100010011		CLRACCS
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100010100		CHKPTRX
    ZC--		1111111 ZC x CCCC xxxxxxxxx 100010101		CHKPTRY
    ----		1111111 00 x CCCC xxxxxxxxx 100010110		SYNCTRA				(waits for ctra if single-task, loops if multi-task))
    ----		1111111 00 x CCCC xxxxxxxxx 100010111		SYNCTRB				(waits for ctrb if single-task, loops if multi-task))
    ----		1111111 00 x CCCC xxxxxxxxx 100011000		SETPIXW
    x = don't care, use 0
    Z	effect
    0	<none>
    1	wz
    C	effect
    0	<none>
    1	wc
    L	DDDDDDDDD	destination operand
    0/na	DDDDDDDDD	register
    1	#DDDDDDDDD	immediate, zero-extended
    I	SSSSSSSSS	source operand
    0/na	SSSSSSSSS	register
    1	#SSSSSSSSS	immediate, zero-extended
    CCCC	condition	(easier-to-read list)
    0000	never		1111	always			(default)
    0001	nc  &  nz	1100	if_c						if_b
    0010	nc  &  z	0011	if_nc						if_ae
    0011	nc		1010	if_z						if_e
    0100	 c  &  nz	0101	if_nz						if_ne
    0101	nz		1000	if_c_and_z		if_z_and_c
    0110	 c  <> z	0100	if_c_and_nz		if_nz_and_c
    0111	nc  |  nz	0010	if_nc_and_z		if_z_and_nc
    1000	 c  &  z	0001	if_nc_and_nz		if_nz_and_nc		if_a
    1001	 c  =  z	1110	if_c_or_z		if_z_or_c		if_be
    1010	 z		1101	if_c_or_nz		if_nz_or_c
    1011	nc  |  z	1011	if_nc_or_z		if_z_or_nc
    1100	 c		0111	if_nc_or_nz		if_nz_or_nc
    1101	 c  |  nz	1001	if_c_eq_z		if_z_eq_c
    1110	 c  |  z	0110	if_c_ne_z		if_z_ne_c
    1111	always		0000	never
    CCCC	inda/indb - CCCC=1111 after stage 2 of pipeline if inda/indb used (indx=inda/indb)
    xx00	source indx
    xx01	source indx++
    xx10	source indx--
    xx11	source ++indx
    00xx	destination indx
    01xx	destination indx++
    10xx	destination indx--
    11xx	destination ++indx
    I'm getting all these changes into PNut.exe now. It's taking a while because the assembler must be made to work in hub space, plus all the branches work differently now.
  • David BetzDavid Betz Posts: 14,526
    edited 2013-12-17 06:48
    I've been thinking about all of the CALL / CALL_ pairs and am wondering if it might be better to just use the "_" bit to select directly between COG addresses and hub addresses. That way you don't need to know what mode you're in, you just need to know what kind of address you're calling. That seems easier to understand than a toggle.
    Also, I notice you now have enough address space for up to 64k of COG memory! :-)
  • AribaAriba Posts: 2,694
    Reading the description of JMPSW (jmpret), is this not what GCC can use for the function-Calls?
        jmpsw LR,#FunctAddr   'call function, returnAddr to LR
    NonLeafFunction:
        pusha LR
        reta    'return
    LeafFunction:
        jmp  LR    'return
    No need to implement special instructions or alternativ modes for existing instructions.
    Or do I just not get the real problem?
    Andy
    edited 2013-12-17 06:51
    Ariba wrote: »
    NonLeafFunction:
        pusha LR
        reta    'return
    LeafFunction:
        jmp  LR    'return
    Andy
    The problem is that JMPSW only has a 9 bit S field and it only writes 9 PC bits into the S field of the corresponding RET instruction.
    edited 2013-12-17 06:53
    Sorry for all of the questions but did the "BIG" prefix/suffix go away?
    Edit: Never mind. I see it's there as "AUG". Perfect!
    edited 2013-12-17 07:04
    David Betz wrote: »
    I started out thinking about different instructions for hub and cog branching and came to the notion that it was best just to toggle. And you don't need to worry about what mode you're in. It'll be obvious. If your cog code is running, you're in the cog. If your hub code is running, you're in the hub. Programs will be assembled differently, in the sense that cog code is limited to a map of 512 and hub code lives in a 64K instruction space.
    edited 2013-12-17 07:06
    David Betz wrote: »
    It's only 9 bits when immediate. If it's an S register, it has {hubmode,Z,C,PC[15:0]}, which is everything. The bugaboo is getting a 16-bit address called out efficiently.
    By the way, JMPSW/JMPSWD writes the whole D long, not just the lower bits. The top bits are cleared to 0. So, the old subroutine_RET labeling is history.
    edited 2013-12-17 07:09
    Here's a good idea. You could make P2 into a 36 bit architecture like the old DEC PDP-10. That would give you some extra bits to play with! :-)
    In case you do that, please add PUSHJ and POPJ as well has the highly intuitive opcodes HLRZ and JFCL.
    edited 2013-12-17 07:16
    David Betz wrote: »
    In hardware ways, it would be easy to go to 36 bits. The trouble is that you'd need to make hub memory the same if you wanted hub execution. And that wouldn't be that hard, either, but then there's the strangeness of memory not being size compatible with just about everything else in the world. Consider SDRAM, for example.
    Added: Dave, what do PUSHJ/POPJ/HLRZ/JFCL do?
    edited 2013-12-17 07:20
    I guess PIC chips have odd sized instructions. In any case, I wasn't really serious. The PDP-10 used 7 bit bytes normally for ASCII data and had funky variable-width byte pointer instructions where a "byte" could be anywhere between 1 bit and 36 bits. While I have fond memories of the PDP-10, I think it would be a poor choice for a modern chip. It worked well for Lisp though.
    HLRZ (half word left to right and zero the other half word) == car
    HRRZ (half word right to right and zero the other half word) == cdr
    edited 2013-12-17 07:23
    David Betz wrote: »
    I don't understand HLRZ/HRRZ. Do you mean 'halve' the word? What does it do?
    edited 2013-12-17 07:30
    Memory in the PDP-10 was addressed in 36 bit words. Other than the funky byte pointers that I mentioned, there was no way to directly address anything smaller than 36 bits. The "half word" instructions manipulated the upper 18 bits of a word as the "left" half word and the lower 18 bits as the "right" half word. Since the address space was limited to 256K 36 bit words, an address fit in one of these half words so a single 36 bit word could hold two addresses. This is perfect for Lisp since a CONS consists of two parts, the CAR and the CDR. That meant that the primary Lisp data structure, the CONS, could be represented as a single PDP-10 36 bit word.
    So, HLRZ would take the left 18 bits of the source address and write it to the right 18 bits of the destination address and zero the high 18 bits.
    JFCL was really only used as a NOP although it stands for "Jump on Flag and Clear". The NOP happened when you didn't specify a flag.
    Note: I don't recommend adding any of these instructions to the P2! :-)
    edited 2013-12-17 07:42
    David Betz wrote: »
    Thanks for the explanation. We could definitely do that in Prop3.
    edited 2013-12-17 07:45
    Actually, in thinking about it, something like PDP-10 byte pointers could be handy for parsing bit sequences where the fields don't align on byte boundaries. I'm not suggesting adding these instructions but they might be useful in a future chip. The PDP-10 byte pointer had a number of fields. The first was just the address of the currently addressed 36 bit word. Another field was the bit number in that 36 bit word that would be consumed next when the byte pointer was dereferenced. Lastly, there was a field indicating the number of bits in the byte being fetched. That let you walk through memory fetching bytes of an odd size like 6 or 7 bits without having to do complicated pointer arithmetic and shifting and masking to isolate the required bits. The problem was that it only worked well if all bytes in a string were the same size. I could see having a byte pointer concept where the pointer contains just the address of the next byte or long and the bit number of the next bit to consume but where the LOAD_BYTE instruction specifies the width of the byte to fetch. That way you could parse along a non-byte aligned sequence of fields and fetch fields of different widths without regard to how they are positioned in the byte or even if they cross byte boundaries.
    Anyway, not a P2 feature!
    edited 2013-12-17 08:41
    David Betz wrote: »
    Hmm... would not
    Reads:
    CAR = GETWORD D,S,#1
    CDR = GETWORD D,S,#0
    Writes:
    CAR = SETWORD D,S,#1
    CDR = SETWORD D,S,#0
    work???
    It would probably require a second SETWORD with source #0 to clear the other half, but pretty close...
    edited 2013-12-17 08:47
    Hmm... would not
    Reads:
    Writes:
    work???
    Yes that would probably work although I think you'll find that there will be fewer takers for Lisp on the Propeller than Forth! :-)
  • AntoineDoinelAntoineDoinel Posts: 312
    edited 2013-12-17 09:26
    David Betz wrote: »
    <semi-serious>
    Please, don't!
    PIC = harvard
    harvard = separate data spaces / can't exec "data"
    can't exec data = much harder tricks to play overlay code, HUB as software controlled L2, etc
    ergo...
    OMG!!! once you take that path, it ultimately leads to... integrated flash, and one more "mission to bathroom" launch window at every F10 press! :frown:
    harvard = EVIL!!! :lol:
    </semi-serious>
    edited 2013-12-17 09:30
    <semi-serious>
    Please, don't!
    PIC = harvard
    ergo...
    </semi-serious>
    Good point about separate instruction and data address spaces on the PIC. In any case, I wasn't seriously suggesting going to 36 bit instructions unless we also go to 36 bit data! :-)
    Really, I wasn't serious at all. Just a silly response to Chip saying it was hard to find space for a 16 bit immediate field in 32 bit instructions. In fact, 4 bits more probably wouldn't be enough to help anyway.
    Now I really need to stop yapping and get to work on implementing Chip's new instruction set in GCC!
  • ersmithersmith Posts: 6,226
    edited 2013-12-17 09:51
    I'm not quite so sure about this. It seems like some automatic tools might not necessarily know which mode they're in when generating code. My feeling is that you're more likely to know where the destination is (in HUB or COG). Actually you need to know that anyway in order to use the toggle properly... so the advantage of the "CALLHUB/CALLCOG" versions is that you only need to know the destination mode, you don't need to know the current mode (whereas for the toggle version you need to know both).
    Eric
  • SeairthSeairth Posts: 2,474
    edited 2013-12-17 11:01
    I may have missed this somewhere. When in HUB mode, are all addresses referencing the HUB memory? Does this mean that access to PINx will require switching to COG mode?
    edited 2013-12-17 11:11
    Seairth wrote: »
    I'm not positive about this but I think the hub vs. COG bit only applies to CALL/RET/JMP instructions, not to data references.
    edited 2013-12-17 11:25
    David,
    Lisp? I'm sure I heard you say Lisp.
    I'd go for Scheme.
    edited 2013-12-17 11:40
    Heater. wrote: »
    David,
    I'd go for Scheme.
    Lisp, Scheme, what's the difference? Just dialects of the same language. Actually, Ken Rose told me recently that he was thinking of porting Hedgehog Lisp to the P1.
  • jmgjmg Posts: 15,194
    edited 2013-12-17 11:43
    David Betz wrote: »
    So this would map to the bottom 256k of hub memory, for exec hub mode ?
    Has the COG reach expanded > 512, or is that only on CALL ? ( If if it is only on CALLs that would make any extended COG memory the most costly place to run code ?)
    A better way to gain some 'free' COG memory ? :
    Is there opcode room, to move the peripheral config and control registers (SFR), to > 512 to allow all 512 as VAR/CODE space ?
    Peripheral config and control registers have less useful access modes than VAR/CODE memory, which makes them expensive in memory stealing terms.
    If this 'fits' there is no source code change, the assembler just senses a SFR address, and sets whichever bit determines physical space access.
    edited 2013-12-17 12:56
    jmg wrote: »
    This hub exec mode has only to do with the tasks' PCs and where they're getting instructions from. All D/S register references are to within the cog that is executing. Just the program space gets bigger and instructions can be fetched from the hub, instead of the cog, only. All the 9-bit D and S fields within the opcodes still reference the cogs internal registers. There are no more address bits for expanding cog register space. Hub exec mode is just like running normal cog code, except the 32-bit instructions are coming from the hub via a caching system, instead of from the cog RAM.
    I just realized that since all instructions during hub execution come from the hub, the cog RAM instruction fetching is still going on, but it's being ignored. We could stuff some other address in the instruction-read-address of the cog RAM and get any long out of cog RAM we want. I wonder if there is something useful that can be done by repurposing the cog's internal instruction fetch. It's a free cog RAM read on every hub exec instruction.
    edited 2013-12-17 13:22
    So in hubexec mode we could have ~500 registers available, is there any way to make this useful for optimization in GCC?
    C.W.
    edited 2013-12-17 13:27
    ctwardell wrote: »
    C.W.
    Yes, we can increase the number of registers available to GCC and we can also use some of COG memory for library functions that we want to run really fast. It won't be wasted! :-)
    edited 2013-12-17 13:30
    It would need to go to some holding register, which takes the same opcode size/time to read, as any other register ?, so there seems little to be gained data-flow wise ?
    But there may be DEBUG uses for this ?
    If it is a read, that might include compare with PC-Val for two 'hardware' breakpoints ?
    Two PC compare values would neatly fit into one 32 bit, with some simple choices of
    * Break on either match
    and maybe even
    * Break if inside the Range
    * Break if outside the Range
    or a split of that 16,16 into one PC, and a pass-counter.
    PC match incs the counter half, and a separate tiny thread manages almost-real-time debug.
    edited 2013-12-17 13:51
    Alternate way of feeding the video engine?
