SDram_Controller --- Question to Chip? — Parallax Forums
SapiehaSapieha Posts: 2,964
edited 2014-01-16 19:23 in Propeller 2
Hi Chip.
As I don't understand Yours control of SDRAM.
I have one question if You look on posted files and describe how much Yours control difer from that?
Ps This modules don't use Alteras code and use no more that about 350 LTE's
  • cgraceycgracey Posts: 14,286
    edited 2013-12-04 02:22
    Sapieha,
    My laptop is not letting me open those files tonight. Meanwhile, my big, fast desktop has Windows 8 on it, and it has never liked the internet for more than 15 seconds at a time, once every month, or so. I don't even ask why, anymore.
    Would you be able to extract the verilog and put it into a code window in this thread? It shouldn't be more than a page or two of code.
    Thanks.
  • max72max72 Posts: 1,155
    edited 2013-12-04 05:54
    What about downgrading to win7?
    http://support.microsoft.com/kb/2832566
    Massimo
  • AleAle Posts: 2,363
    edited 2013-12-04 06:15
    max72 wrote: »
    Massimo
    I think you mean an Upgrade to more functionality :D.
    The whole SDRAM driver is software-based... HW are only the registered outputs, as far as I know...
  • tonyp12tonyp12 Posts: 1,951
    edited 2013-12-04 06:22
    Maybe it's Windows internal winzip that for security reason don't like some of the filestypes inside those zips.
    use 7zip to open them http://www.7-zip.org/
  • T ChapT Chap Posts: 4,249
    edited 2013-12-04 06:44
    I have win8 on both a toshiba and hp laptop, both download and extract both files no problem. Maybe some virus protection on Chips system.
  • SapiehaSapieha Posts: 2,964
    edited 2013-12-04 10:14
    Hi Chip.
    All files needed to compile it to look as JPG file in first post.
    FILES attached.
    Top file -- sdr_sdram.v
    *  LOGIC CORE:          SDR SDRAM Controller
    *  MODULE NAME:         sdr_sdram()
    *  COMPANY:             Northwest Logic, Inc.
    *                       [URL="http://www.nwlogic.com"]www.nwlogic.com[/URL]
    *  REVISION HISTORY:
    *    Revision 1.0  05/11/2000     Description: Initial Release.
    *             1.1  07/10/2000     Description: change precharge to terminate
    *                                              for full page accesses.
    *  FUNCTIONAL DESCRIPTION:
    *  This module is the top level module for the SDR SDRAM controller.
    *  Copyright Northwest Logic, Inc., 2000.  All rights reserved.
    module sdr_sdram(
            CLK,
            RESET_N,
            ADDR,
            CMD,
            CMDACK,
            DATAIN,
            DATAOUT,
            DM,
            SA,
            BA,
            CS_N,
            CKE,
            RAS_N,
            CAS_N,
            WE_N,
            DQ,
            DQM
    `include        "params.v"
    input                           CLK;                    //System Clock
    input                           RESET_N;                //System Reset
    input   [`ASIZE-1:0]            ADDR;                   //Address for controller requests
    input   [2:0]                   CMD;                    //Controller command
    output                          CMDACK;                 //Controller command acknowledgement
    input   [`DSIZE-1:0]            DATAIN;                 //Data input
    output  [`DSIZE-1:0]            DATAOUT;                //Data output
    input   [`DSIZE/8-1:0]          DM;                     //Data mask input
    output  [11:0]                  SA;                     //SDRAM address output
    output  [1:0]                   BA;                     //SDRAM bank address
    output  [1:0]                   CS_N;                   //SDRAM Chip Selects
    output                          CKE;                    //SDRAM clock enable
    output                          RAS_N;                  //SDRAM Row address Strobe
    output                          CAS_N;                  //SDRAM Column address Strobe
    output                          WE_N;                   //SDRAM write enable
    inout   [`DSIZE-1:0]            DQ;                     //SDRAM data bus
    output  [`DSIZE/8-1:0]          DQM;                    //SDRAM data mask lines
    reg     [11:0]                  SA;                     //SDRAM address output
    reg     [1:0]                   BA;                     //SDRAM bank address
    reg     [1:0]                   CS_N;                   //SDRAM Chip Selects
    reg                             CKE;                    //SDRAM clock enable
    reg                             RAS_N;                  //SDRAM Row address Strobe
    reg                             CAS_N;                  //SDRAM Column address Strobe
    reg                             WE_N;                   //SDRAM write enable
    reg     [`DSIZE-1:0]            DQIN;
    wire    [`DSIZE-1:0]            DQOUT;
    wire    [`DSIZE-1:0]            IDATAOUT;                //Data output
    reg     [`DSIZE-1:0]            DATAOUT;                 //Data output
    wire    [11:0]                  ISA;                     //SDRAM address output
    wire    [1:0]                   IBA;                     //SDRAM bank address
    wire    [1:0]                   ICS_N;                   //SDRAM Chip Selects
    wire                            ICKE;                    //SDRAM clock enable
    wire                            IRAS_N;                  //SDRAM Row address Strobe
    wire                            ICAS_N;                  //SDRAM Column address Strobe
    wire                            IWE_N;                   //SDRAM write enable
    wire    [`ASIZE-1:0]            saddr;
    wire    [1:0]                   sc_cl;
    wire    [1:0]                   sc_rc;
    wire    [3:0]                   sc_rrd;
    wire                            sc_pm;
    wire    [3:0]                   sc_bl;
    wire                            load_mode;
    wire                            nop;
    wire                            reada;
    wire                            writea;
    wire                            refresh;
    wire                            precharge;
    wire                            oe;
    //wire                            CLK133;
    //wire                            CLK133B;
    //wire                         CLK;
    //pll1 PLL1(
    //                .inclock(CLK),
    //                .clock0(CLK133),
    //                .clock1(CLK133B),
    //                .locked(locked)
    control_interface control1 (
                //    .CLK(CLK133),
                    .CLK(CLK),
                    .RESET_N(RESET_N),
                    .CMD(CMD),
                    .ADDR(ADDR),
                    .REF_ACK(ref_ack),
                    .CM_ACK(cm_ack),
                    .NOP(nop),
                    .READA(reada),
                    .WRITEA(writea),
                    .REFRESH(refresh),
                    .PRECHARGE(precharge),
                    .LOAD_MODE(load_mode),
                    .SADDR(saddr),
                    .SC_CL(sc_cl),
                    .SC_RC(sc_rc),
                    .SC_RRD(sc_rrd),
                    .SC_PM(sc_pm),
                    .SC_BL(sc_bl),
                    .REF_REQ(ref_req),
                    .CMD_ACK(CMDACK)
    command command1(
                   // .CLK(CLK133),
                    .CLK(CLK),
                    .RESET_N(RESET_N),
                    .SADDR(saddr),
                    .NOP(nop),
                    .READA(reada),
                    .WRITEA(writea),
                    .REFRESH(refresh),
                    .SC_CL(sc_cl),
                    .SC_RC(sc_rc),
                    .SC_RRD(sc_rrd),
                    .SC_PM(sc_pm),
                    .SC_BL(sc_bl),
                    .REF_REQ(ref_req),
                    .REF_ACK(ref_ack),
                    .CM_ACK(cm_ack),
                    .OE(oe),
                    .SA(ISA),
                    .BA(IBA),
                    .CS_N(ICS_N),
                    .CKE(ICKE),
                    .RAS_N(IRAS_N),
                    .CAS_N(ICAS_N),
                    .WE_N(IWE_N)
    sdr_data_path data_path1(
                    //.CLK(CLK133),
                    .CLK(CLK),
                    .RESET_N(RESET_N),
                    .OE(oe),
                    .DATAIN(DATAIN),
                    .DM(DM),
                    .DATAOUT(IDATAOUT),
                    .DQIN(DQIN),
                    .DQOUT(DQOUT),
                    .DQM(DQM)
    always @(posedge CLK)
    begin
                    SA      <= ISA;
                    BA      <= IBA;
                    CS_N    <= ICS_N;
                    CKE     <= ICKE;
                    RAS_N   <= IRAS_N;
                    CAS_N   <= ICAS_N;
                    WE_N    <= IWE_N;
                    DQIN    <= DQ;
                    DATAOUT <= IDATAOUT;
    end
    assign  DQ = oe ? DQOUT : 32'bz;
    endmodule
    File 2: -- sdr_data_path.v
    *  LOGIC CORE:          SDR Data Path Module
    *  MODULE NAME:         sdr_data_path()
    *                       www.nwlogic.com
    *  REVISION HISTORY:
    *  This module is the data path module for the SDR SDRAM controller.
    module sdr_data_path(
            CLK,
            RESET_N,
            OE,
            DATAIN,
            DM,
            DATAOUT,
            DQIN,
            DQOUT,
            DQM
    `include        "params.v"
    input                           CLK;                    // System Clock
    input                           RESET_N;                // System Reset
    input                           OE;                     // Data output(to the SDRAM) enable
    input   [`DSIZE-1:0]            DATAIN;                 // Data input from the host
    input   [`DSIZE/8-1:0]          DM;                     // byte data masks
    output  [`DSIZE-1:0]            DATAOUT;                // Read data output to host
    input   [`DSIZE-1:0]            DQIN;                   // SDRAM data bus
    output  [`DSIZE-1:0]            DQOUT;
    output  [`DSIZE/8-1:0]          DQM;                    // SDRAM data mask ouputs
    //reg     [`DSIZE-1:0]            DATAOUT;
    reg     [`DSIZE/8-1:0]          DQM;
    // internal
    reg     [`DSIZE-1:0]            DIN1;
    reg     [`DSIZE-1:0]            DIN2;
    reg     [`DSIZE/8-1:0]          DM1;
    reg     [`DSIZE-1:0]            DOUT1;
    reg     [`DSIZE-1:0]            DOUT2;
    // Allign the input and output data to the SDRAM control path
    always @(posedge CLK or negedge RESET_N)
    begin
            if (RESET_N == 0)
            begin
                    DIN1    <= 0;
                    DIN2    <= 0;
                    DM1     <= 0;
                    DOUT1   <= 0;
                    DOUT2   <= 0;
            end
            else
            begin
                    DIN1      <= DATAIN;
                    DIN2      <= DIN1;
                    DM1       <= DM;
                    DQM       <= DM1;
    //                DOUT1     <= DQIN;
    //                DATAOUT   <= DQIN;
            end
    end
    //assign  DQ = OE ? DIN2 : 32'bz;
    assign DQOUT = DIN2;
    assign DATAOUT = DQIN;
    endmodule
    File 3: -- PLL1.V
    // megafunction wizard: %ALTCLKLOCK%
    // GENERATION: STANDARD
    // VERSION: WM1.0
    // MODULE: altclklock
    // File Name: PLL1.v
    // Megafunction Name(s):
    //             altclklock
    // THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
    //Copyright (C) 1991-2000 Altera Corporation
    //Any megafunction design, and related net list (encrypted or decrypted),
    //support information, device programming or simulation file, and any other
    //associated documentation or information provided by Altera or a partner
    //under Altera's Megafunction Partnership Program may be used only to
    //program PLD devices (but not masked PLD devices) from Altera.  Any other
    //use of such megafunction design, net list, support information, device
    //programming or simulation file, or any other related documentation or
    //information is prohibited for any other purpose, including, but not
    //limited to modification, reverse engineering, de-compiling, or use with
    //any other silicon devices, unless such use is explicitly licensed under
    //a separate agreement with Altera or a megafunction partner.  Title to
    //the intellectual property, including patents, copyrights, trademarks,
    //trade secrets, or maskworks, embodied in any such megafunction design,
    //net list, support information, device programming or simulation file, or
    //any other related documentation or information provided by Altera or a
    //megafunction partner, remains with Altera, the megafunction partner, or
    //their respective licensors.  No other licenses, including any licenses
    //needed under any third party's intellectual property, are provided herein.
    `timescale 1 ps / 1 ps
    module pll1 (
        inclock,
        locked,
        clock0,
        clock1);
    /* synthesis black_box */
        input      inclock;
        output      locked;
        output      clock0;
        output      clock1;
    /* synopsys translate_off */
        wire  sub_wire0;
        wire  sub_wire1;
        wire  sub_wire2;
        wire  clock0 = sub_wire0;
        wire  clock1 = sub_wire1;
        wire  locked = sub_wire2;
        altclklock    altclklock_component (
                    .inclock (inclock),
                    .clock0 (sub_wire0),
                    .clock1 (sub_wire1),
                    .locked (sub_wire2));
        defparam
            altclklock_component.inclock_period = 7500,                 /* 133mhz */
    //        altclklock_component.inclock_period = 10000,                /* 100mhz */
            altclklock_component.clock0_boost = 1,
            altclklock_component.clock1_boost = 1,
            altclklock_component.operation_mode = "NORMAL",
            altclklock_component.valid_lock_cycles = 5,
            altclklock_component.invalid_lock_cycles = 5,
            altclklock_component.valid_lock_multiplier = 5,
            altclklock_component.invalid_lock_multiplier = 5,
            altclklock_component.clock0_divide = 1,
            altclklock_component.clock1_divide = 1,
            altclklock_component.outclock_phase_shift = 0;
    /* synopsys translate_on */
    endmodule
    // CNX file retrieval info
    // Retrieval info: PRIVATE: DISPLAY_FREQUENCY STRING "25.0"
    // Retrieval info: PRIVATE: USING_FREQUENCY NUMERIC "0"
    // Retrieval info: PRIVATE: DEVICE_FAMILY NUMERIC "1"
    // Retrieval info: PRIVATE: FEEDBACK_SOURCE NUMERIC "1"
    // Retrieval info: PRIVATE: PHASE_UNIT NUMERIC "0"
    // Retrieval info: PRIVATE: USING_PROGRAMMABLE_PHASE_SHIFT NUMERIC "1"
    // Retrieval info: CONSTANT: INCLOCK_PERIOD NUMERIC "40000"
    // Retrieval info: CONSTANT: CLOCK0_BOOST NUMERIC "1"
    // Retrieval info: CONSTANT: CLOCK1_BOOST NUMERIC "1"
    // Retrieval info: CONSTANT: OPERATION_MODE STRING "NORMAL"
    // Retrieval info: CONSTANT: VALID_LOCK_CYCLES NUMERIC "5"
    // Retrieval info: CONSTANT: INVALID_LOCK_CYCLES NUMERIC "5"
    // Retrieval info: CONSTANT: VALID_LOCK_MULTIPLIER NUMERIC "5"
    // Retrieval info: CONSTANT: INVALID_LOCK_MULTIPLIER NUMERIC "5"
    // Retrieval info: CONSTANT: CLOCK0_DIVIDE NUMERIC "1"
    // Retrieval info: CONSTANT: CLOCK1_DIVIDE NUMERIC "1"
    // Retrieval info: CONSTANT: OUTCLOCK_PHASE_SHIFT NUMERIC "0"
    // Retrieval info: USED_PORT: inclock 0 0 0 0 INPUT NODEFVAL inclock
    // Retrieval info: USED_PORT: locked 0 0 0 0 OUTPUT NODEFVAL locked
    // Retrieval info: USED_PORT: clock0 0 0 0 0 OUTPUT NODEFVAL clock0
    // Retrieval info: USED_PORT: clock1 0 0 0 0 OUTPUT NODEFVAL clock1
    // Retrieval info: CONNECT: @inclock 0 0 0 0 inclock 0 0 0 0
    // Retrieval info: CONNECT: locked 0 0 0 0 @locked 0 0 0 0
    // Retrieval info: CONNECT: clock0 0 0 0 0 @clock0 0 0 0 0
    // Retrieval info: CONNECT: clock1 0 0 0 0 @clock1 0 0 0 0
    File 4: -- control_interface.v
    *  LOGIC CORE:          Control Interface - Top level module
    *  MODULE NAME:         control_interface()
    *                       www.nwlogic.com
    *  REVISION HISTORY:
    *  This module is the command interface module for the SDR SDRAM controller.
    module control_interface(
            CLK,
            RESET_N,
            CMD,
            ADDR,
            REF_ACK,
            CM_ACK,
            NOP,
            READA,
            WRITEA,
            REFRESH,
            PRECHARGE,
            LOAD_MODE,
            SADDR,
            SC_CL,
            SC_RC,
            SC_RRD,
            SC_PM,
            SC_BL,
            REF_REQ,
            CMD_ACK
    `include        "params.v"
    input   [2:0]                   CMD;                    // Command input
    input   [`ASIZE-1:0]            ADDR;                   // Address
    input                           REF_ACK;                // Refresh request acknowledge
    input                           CM_ACK;                 // Command acknowledge
    output                          NOP;                    // Decoded NOP command
    output                          READA;                  // Decoded READA command
    output                          WRITEA;                 // Decoded WRITEA command
    output                          REFRESH;                // Decoded REFRESH command
    output                          PRECHARGE;              // Decoded PRECHARGE command
    output                          LOAD_MODE;              // Decoded LOAD_MODE command
    output  [`ASIZE-1:0]            SADDR;                  // Registered version of ADDR
    output  [1:0]                   SC_CL;                  // Programmed CAS latency
    output  [1:0]                   SC_RC;                  // Programmed RC delay
    output  [3:0]                   SC_RRD;                 // Programmed RRD delay
    output                          SC_PM;                  // programmed Page Mode
    output  [3:0]                   SC_BL;                  // Programmed burst length
    output                          REF_REQ;                // Hidden refresh request
    output                          CMD_ACK;                // Command acknowledge
    reg                             NOP;
    reg                             READA;
    reg                             WRITEA;
    reg                             REFRESH;
    reg                             PRECHARGE;
    reg                             LOAD_MODE;
    reg     [`ASIZE-1:0]            SADDR;
    reg     [1:0]                   SC_CL;
    reg     [1:0]                   SC_RC;
    reg     [3:0]                   SC_RRD;
    reg     [3:0]                   SC_BL;
    reg                             SC_PM;
    reg                             REF_REQ;
    reg                             CMD_ACK;
    // Internal signals
    reg                             LOAD_REG1;
    reg                             LOAD_REG2;
    reg     [15:0]                  REF_PER;
    reg     [15:0]                  timer;
    reg                             timer_zero;
    // Command decode and ADDR register
    begin
            if (RESET_N == 0)
            begin
                    NOP             <= 0;
                    READA           <= 0;
                    WRITEA          <= 0;
                    REFRESH         <= 0;
                    PRECHARGE       <= 0;
                    LOAD_MODE       <= 0;
                    SADDR           <= 0;
            end
            else
            begin
                    SADDR <= ADDR;                                  // register the address to keep proper
        // alignment with the command
                    if (CMD == 3'b000)                              // NOP command
                            NOP <= 1;
                    else
                            NOP <= 0;
                    if (CMD == 3'b001)                              // READA command
                            READA <= 1;
                    else
                            READA <= 0;
                    if (CMD == 3'b010)                              // WRITEA command
                            WRITEA <= 1;
                    else
                            WRITEA <= 0;
                    if (CMD == 3'b011)                              // REFRESH command
                            REFRESH <= 1;
                    else
                            REFRESH <= 0;
                    if (CMD == 3'b100)                              // PRECHARGE command
                            PRECHARGE <= 1;
                    else
                            PRECHARGE <= 0;
                    if (CMD == 3'b101)                              // LOAD_MODE command
                            LOAD_MODE <= 1;
                    else
                            LOAD_MODE <= 0;
                    if ((CMD == 3'b110) & (LOAD_REG1 == 0) & (CMD_ACK == 0))                              //LOAD_REG1 command
                            LOAD_REG1 <= 1;
                    else
                            LOAD_REG1 <= 0;
                    if ((CMD == 3'b111) & (LOAD_REG2 == 0) & (CMD_ACK == 0))                              //LOAD_REG2 command
                            LOAD_REG2 <= 1;
                    else
                            LOAD_REG2 <= 0;
            end
    end
    // register configuration information if LOAD_REG1 or LOAD_REG2 is
    // asserted.
    begin
            if (RESET_N == 0)
            begin
                    SC_CL   <= 0;
                    SC_RC   <= 0;
                    SC_RRD  <= 0;
                    SC_PM   <= 0;
                    SC_BL   <= 0;
                    REF_PER <= 0;
            end
            else
            begin
                    if (LOAD_REG1 == 1)
                    begin
                            SC_CL   <= SADDR[1:0];                   // CAS Latency
                            SC_RC   <= SADDR[3:2];                   // RC delay
                            SC_RRD  <= SADDR[7:4];                   // RRD delay
                            SC_PM   <= SADDR[8];                     // Page Mode
                            SC_BL   <= SADDR[12:9];                  // Burst length
                    end
                    if (LOAD_REG2 == 1)
                            REF_PER <= SADDR[15:0];                  // REFRESH Period
            end
    end
    //  Generate CMD_ACK
    begin
            if (RESET_N == 0)
                    CMD_ACK <= 0;
            else
                    if (((CM_ACK == 1) | (LOAD_REG1 == 1) | (LOAD_REG2 == 1)) & (CMD_ACK == 0))
                            CMD_ACK <= 1;
                    else
                            CMD_ACK <= 0;
    end
    // refresh timer
    always @(posedge CLK or negedge RESET_N) begin
            if (RESET_N == 0)
            begin
                    timer           <= 0;
                    timer_zero      <= 0;
                    REF_REQ         <= 0;
            end
            else
            begin
                    if (timer_zero == 1)
                            timer <= REF_PER;
                    else if (SC_BL != 0)
                            timer <= timer - 1;
                    if ((timer==0) & (SC_BL != 0))
                    begin
                            timer_zero <= 1;
                            REF_REQ    <= 1;
                    end
                    else
                    if (REF_ACK == 1)
                    begin
                            timer_zero <= 0;
                            REF_REQ    <= 0;
                    end
            end
    end
    endmodule
    File 5: -- altclklock.v
    // VERSION: WM1.0
    //             altclklock
    module altclklock (
        inclock,
    //    inclocken,
    //    fbin,
        locked,
        clock0,
        clock1);
        input      inclock;
    //    input      inclocken;
    //    input      fbin;
        output      locked;
        output      clock0;
        output      clock1;
    /* synopsys translate_off*/
    parameter inclock_period=7500;                    // 133mhz
    //parameter inclock_period=10000;                    // 100mhz
    parameter inclock_settings = "UNUSED";
    parameter valid_lock_cycles = 3;
    parameter invalid_lock_cycles = 3;
    parameter valid_lock_multiplier = 1;
    parameter invalid_lock_multiplier = 1;
    parameter operation_mode = "NORMAL";
    parameter clock0_boost = 2;
    parameter clock0_divide = 1;
    parameter clock1_boost = 1;
    parameter clock1_divide = 1;
    parameter clock0_settings = "UNUSED";
    parameter clock1_settings = "UNUSED";
    parameter outclock_phase_shift = 0;
    reg clock0, clock1, locked;
    reg new_clock0, new_clock1, locked_int;
    reg start_new_clock0, start_new_clock1, outclock_start_edge;
    reg first_clock0_cycle, first_clock1_cycle;
    reg prev_inclock;
    wire inclocken;
    // internal reg
    integer pll0_half_period, pll1_half_period, phase_delay0, phase_delay1;
    integer inclock_edge_count;
    real lowcycle, highcycle;
    reg  cycleviolation;
    initial
    begin
      locked_int = 0;
      inclock_edge_count = 0;
      first_clock0_cycle = 1;
      first_clock1_cycle = 1;
      lowcycle = 0;
      highcycle = 0;
      cycleviolation = 0;
    end
    assign inclocken = 1;
    always @ (inclock /*or inclocken*/)
    begin
       if (locked_int == 0) begin
          pll0_half_period = (inclock_period * clock0_divide)/(2 * clock0_boost);
          pll1_half_period = (inclock_period * clock1_divide)/(2 * clock1_boost);
    //      if (outclock_phase_shift < 180.000) begin
             outclock_start_edge = 1;
    //         phase_delay0 = (0.500 - (outclock_phase_shift/360.000)) * (2.000 * pll0_half_period);
    //         phase_delay1 = (0.500 - (outclock_phase_shift/360.000)) * (2.000 * pll1_half_period);
    //     end
    //      else if (outclock_phase_shift == 180.000) begin
    //         outclock_start_edge = 0;
    //         phase_delay0 = (outclock_phase_shift/360.000) * (2.000 * pll0_half_period);
     //        phase_delay1 = (outclock_phase_shift/360.000) * (2.000 * pll1_half_period);
      //    end
       //   else begin
         //    phase_delay0 = ((outclock_phase_shift/360.000) - 0.500) * (2.000 * pll0_half_period);
          //   phase_delay1 = ((outclock_phase_shift/360.000) - 0.500) * (2.000 * pll1_half_period);
       //   end
          phase_delay0 = outclock_phase_shift;
          phase_delay1 = outclock_phase_shift;
          start_new_clock0 = outclock_start_edge;
          start_new_clock1 = !outclock_start_edge;
       end
       if ((inclocken == 0) || (cycleviolation == 1)) begin
          locked_int = 0;
          locked = 0;
       end
       else if  (inclock != prev_inclock) begin // inclock edge detected
          if (inclock == 1) begin
             if (($realtime - lowcycle) != (inclock_period/2)) begin
                $display ($time, "Error: Duty Cycle violation");
                cycleviolation = 1;
             end
             highcycle = $realtime;
          end
          if (inclock == 0) begin
             if (($realtime - highcycle) != (inclock_period/2)) begin
                cycleviolation = 1;
             end
             lowcycle = $realtime;
          end
          inclock_edge_count = inclock_edge_count + 1;
          if (inclock_edge_count == valid_lock_cycles) begin
             cycleviolation = 0;
             locked_int = 1;
             locked = 1;
          end
       end
        prev_inclock = inclock;
    end
    always @ (new_clock0 or locked_int)
    begin
          if (locked_int == 1) begin
             if (first_clock0_cycle == 1) begin
                clock0 = start_new_clock0;
                 # phase_delay0 new_clock0 <= ~start_new_clock0 ;
             end
             else begin
                clock0 = new_clock0;
                # (pll0_half_period) new_clock0 <= ~new_clock0 ;
             end
             first_clock0_cycle = 0;
          end
          else begin
          end
    end
    always @ (new_clock1 or locked_int)
    begin
             if (first_clock1_cycle == 1) begin
                clock1 = start_new_clock1;
                #phase_delay1 new_clock1 <= ~start_new_clock1 ;
             end
             else begin
                clock1 = new_clock1;
                # (pll1_half_period) new_clock1 <= ~new_clock1 ;
             end
             first_clock1_cycle = 0;
          end
          else begin
          end
    end
    //synopsys translate_on
    endmodule
    // Retrieval info: PRIVATE: USING_PROGRAMMABLE_PHASE_SHIFT NUMERIC "0"
    // Retrieval info: CONSTANT: OPERATION_MODE STRING "EXTERNAL_FEEDBACK"
    // Retrieval info: USED_PORT: inclocken 0 0 0 0 INPUT NODEFVAL inclocken
    // Retrieval info: USED_PORT: fbin 0 0 0 0 INPUT NODEFVAL fbin
    // Retrieval info: CONNECT: @inclocken 0 0 0 0 inclocken 0 0 0 0
    // Retrieval info: CONNECT: @fbin 0 0 0 0 fbin 0 0 0 0
    File 6: -- Command.v
    *  LOGIC CORE:          Command module
    *  MODULE NAME:         command()
    *  COMPANY:             Northwest Logic Design, Inc.
    *                       www.nwlogic.com
    *  REVISION HISTORY:
    *  This module is the command processor module for the SDR SDRAM controller.
    module command(
            CLK,
            RESET_N,
            SADDR,
            NOP,
            READA,
            WRITEA,
            REFRESH,
            PRECHARGE,
            LOAD_MODE,
            SC_CL,
            SC_RC,
            SC_RRD,
            SC_PM,
            SC_BL,
            REF_REQ,
            REF_ACK,
            CM_ACK,
            OE,
            SA,
            BA,
            CS_N,
            CKE,
            RAS_N,
            CAS_N,
            WE_N
    `include        "params.v"
    input   [`ASIZE-1:0]            SADDR;                  // Address
    input                           NOP;                    // Decoded NOP command
    input                           READA;                  // Decoded READA command
    input                           WRITEA;                 // Decoded WRITEA command
    input                           REFRESH;                // Decoded REFRESH command
    input                           PRECHARGE;              // Decoded PRECHARGE command
    input                           LOAD_MODE;              // Decoded LOAD_MODE command
    input   [1:0]                   SC_CL;                  // Programmed CAS latency
    input   [1:0]                   SC_RC;                  // Programmed RC delay
    input   [3:0]                   SC_RRD;                 // Programmed RRD delay
    input                           SC_PM;                  // programmed Page Mode
    input   [3:0]                   SC_BL;                  // Programmed burst length
    input                           REF_REQ;                // Hidden refresh request
    output                          REF_ACK;                // Refresh request acknowledge
    output                          CM_ACK;                 // Command acknowledge
    output                          OE;                     // OE signal for data path module
    output  [11:0]                  SA;                     // SDRAM address
    output  [1:0]                   BA;                     // SDRAM bank address
    output  [1:0]                   CS_N;                   // SDRAM chip selects
    output                          CKE;                    // SDRAM clock enable
    output                          RAS_N;                  // SDRAM RAS
    output                          CAS_N;                  // SDRAM CAS
    output                          WE_N;                   // SDRAM WE_N
    reg                             CM_ACK;
    reg                             REF_ACK;
    reg                             OE;
    reg     [11:0]                  SA;
    reg     [1:0]                   BA;
    reg     [1:0]                   CS_N;
    reg                             CKE;
    reg                             RAS_N;
    reg                             CAS_N;
    reg                             WE_N;
    // Internal signals
    reg                             do_nop;
    reg                             do_reada;
    reg                             do_writea;
    reg                             do_writea1;
    reg                             do_refresh;
    reg                             do_precharge;
    reg                             do_load_mode;
    reg                             command_done;
    reg     [7:0]                   command_delay;
    reg     [3:0]                   rw_shift;
    reg                             do_act;
    reg                             rw_flag;
    reg                             do_rw;
    reg     [7:0]                   oe_shift;
    reg                             oe1;
    reg                             oe2;
    reg                             oe3;
    reg                             oe4;
    reg     [3:0]                   rp_shift;
    reg                             rp_done;
    wire    [`ROWSIZE - 1:0]        rowaddr;
    wire    [`COLSIZE - 1:0]        coladdr;
    wire    [`BANKSIZE - 1:0]       bankaddr;
    assign   rowaddr   = SADDR[`ROWSTART + `ROWSIZE - 1: `ROWSTART];          // assignment of the row address bits from SADDR
    assign   coladdr   = SADDR[`COLSTART + `COLSIZE - 1:`COLSTART];           // assignment of the column address bits
    assign   bankaddr  = SADDR[`BANKSTART + `BANKSIZE - 1:`BANKSTART];        // assignment of the bank address bits
    // This always block monitors the individual command lines and issues a command
    // to the next stage if there currently another command already running.
    begin
            if (RESET_N == 0)
            begin
                    do_nop          <= 0;
                    do_reada        <= 0;
                    do_writea       <= 0;
                    do_refresh      <= 0;
                    do_precharge    <= 0;
                    do_load_mode    <= 0;
                    command_done    <= 0;
                    command_delay   <= 0;
                    rw_flag         <= 0;
                    rp_shift        <= 0;
                    rp_done         <= 0;
            end
            else
            begin
    //  Issue the appropriate command if the sdram is not currently busy
                    if ((REF_REQ == 1 | REFRESH == 1) & command_done == 0 & do_refresh == 0 & rp_done == 0         // Refresh
                            & do_reada == 0 & do_writea == 0)
                            do_refresh <= 1;
                    else
                            do_refresh <= 0;
                    if ((READA == 1) & (command_done == 0) & (do_reada == 0) & (rp_done == 0) & (REF_REQ == 0))    // READA
                            do_reada <= 1;
                    else
                            do_reada <= 0;
                    if ((WRITEA == 1) & (command_done == 0) & (do_writea == 0) & (rp_done == 0) & (REF_REQ == 0))  // WRITEA
                    begin
                            do_writea <= 1;
                            do_writea1 <= 1;
                    end
                    else
                    begin
                            do_writea <= 0;
                            do_writea1 <= 0;
                    end
                    if ((PRECHARGE == 1) & (command_done == 0) & (do_precharge == 0))                              // PRECHARGE
                            do_precharge <= 1;
                    else
                            do_precharge <= 0;
                    if ((LOAD_MODE == 1) & (command_done == 0) & (do_load_mode == 0))                              // LOADMODE
                            do_load_mode <= 1;
                    else
                            do_load_mode <= 0;
    // set command_delay shift register and command_done flag
    // The command delay shift register is a timer that is used to ensure that
    // the SDRAM devices have had sufficient time to finish the last command.
                    if ((do_refresh == 1) | (do_reada == 1) | (do_writea == 1) | (do_precharge == 1)
                         | (do_load_mode))
                    begin
                            command_delay <= 8'b11111111;
                            command_done  <= 1;
                            rw_flag <= do_reada;
                    end
                    else
                    begin
                            command_done        <= command_delay[0];                // the command_delay shift operation
                            command_delay[6:0]  <= command_delay[7:1];
                            command_delay[7]    <= 0;
                    end
     // start additional timer that is used for the refresh, writea, reada commands
                    if (command_delay[0] == 0 & command_done == 1)
                    begin
                            rp_shift <= 4'b1111;
                            rp_done <= 1;
                    end
                    else
                    begin
                            rp_done         <= rp_shift[0];
                            rp_shift[2:0]   <= rp_shift[3:1];
                            rp_shift[3]     <= 0;
                    end
            end
    end
    // logic that generates the OE signal for the data path module
    // For normal burst write he duration of OE is dependent on the configured burst length.
    // For page mode accesses(SC_PM=1) the OE signal is turned on at the start of the write command
    // and is left on until a PRECHARGE(page burst terminate) is detected.
    begin
            if (RESET_N == 0)
            begin
                    oe_shift <= 0;
                    oe1      <= 0;
                    oe2      <= 0;
                    OE       <= 0;
            end
            else
            begin
                    if (SC_PM == 0)
                    begin
                            if (do_writea1 == 1)
                            begin
                                    if (SC_BL == 1)                       //  Set the shift register to the appropriate
                                            oe_shift <= 0;                // value based on burst length.
                                    else if (SC_BL == 2)
                                            oe_shift <= 1;
                                    else if (SC_BL == 4)
                                            oe_shift <= 7;
                                    else if (SC_BL == 8)
                                            oe_shift <= 127;
                                    oe1 <= 1;
                            end
                            else
                            begin
                                    oe_shift[6:0] <= oe_shift[7:1];       // Do the shift operation
                                    oe_shift[7]   <= 0;
                                    oe1  <= oe_shift[0];
                                    oe2  <= oe1;
                                    oe3  <= oe2;
                                    oe4   <= oe3;
                                    if (SC_RC == 2)
                                            OE <= oe3;
                                    else
                                            OE <= oe4;
                            end
                    end
                    else
                    begin
                            if (do_writea1 == 1)                                    // OE generation for page mode accesses
                                    oe4   <= 1;
                            else if (do_precharge == 1 | do_reada == 1 | do_refresh)
                                    oe4   <= 0;
                            OE <= oe4;
                    end
            end
    end
    // This always block tracks the time between the activate command and the
    // subsequent WRITEA or READA command, RC.  The shift register is set using
    // the configuration register setting SC_RC. The shift register is loaded with
    // a single '1' with the position within the register dependent on SC_RC.
    // When the '1' is shifted out of the register it sets so_rw which triggers
    // a writea or reada command
    begin
            if (RESET_N == 0)
            begin
                    rw_shift <= 0;
                    do_rw    <= 0;
            end
            else
            begin
                    if ((do_reada == 1) | (do_writea == 1))
                    begin
                            if (SC_RC == 1)                          // Set the shift register
                                    do_rw <= 1;
                            else if (SC_RC == 2)
                                    rw_shift <= 1;
                            else if (SC_RC == 3)
                                    rw_shift <= 2;
                    end
                    else
                    begin
                            rw_shift[2:0] <= rw_shift[3:1];          // perform the shift operation
                            rw_shift[3]   <= 0;
                            do_rw         <= rw_shift[0];
                    end
            end
    end
    // This always block generates the command acknowledge, CM_ACK, signal.
    // It also generates the acknowledge signal, REF_ACK, that acknowledges
    // a refresh request that was generated by the internal refresh timer circuit.
    begin
            if (RESET_N == 0)
            begin
                    CM_ACK   <= 0;
                    REF_ACK  <= 0;
            end
            else
            begin
                    if (do_refresh == 1 & REF_REQ == 1)                   // Internal refresh timer refresh request
                            REF_ACK <= 1;
                    else if ((do_refresh == 1) | (do_reada == 1) | (do_writea == 1) | (do_precharge == 1)   // externa  commands
                             | (do_load_mode))
                            CM_ACK <= 1;
                    else
                    begin
                            REF_ACK <= 0;
                            CM_ACK  <= 0;
                    end
            end
    end
    // This always block generates the address, cs, cke, and command signals(ras,cas,wen)
    always @(posedge CLK ) begin
            if (RESET_N==0) begin
                    SA    <= 0;
                    BA    <= 0;
                    CS_N  <= 1;
                    RAS_N <= 1;
                    CAS_N <= 1;
                    WE_N  <= 1;
                    CKE   <= 0;
            end
            else begin
                    CKE <= 1;
    // Generate SA
                    if (do_writea == 1 | do_reada == 1)    // ACTIVATE command is being issued, so present the row address
                            SA <= rowaddr;
                    else
                            SA <= coladdr;                 // else alway present column address
                    if ((do_rw==1) | (do_precharge))
                            SA[10] <= !SC_PM;              // set SA[10] for autoprecharge read/write or for a precharge all command
                                                           // don't set it if the controller is in page mode.
                    if (do_precharge==1 | do_load_mode==1)
                            BA <= 0;                       // Set BA=0 if performing a precharge or load_mode command
                    else
                            BA <= bankaddr[1:0];           // else set it with the appropriate address bits
                    if (do_refresh==1 | do_precharge==1 | do_load_mode==1)
                            CS_N <= 0;                                    // Select both chip selects if performing
                    else                                                  // refresh, precharge(all) or load_mode
                    begin
                            CS_N[0] <= SADDR[`ASIZE-1];                   // else set the chip selects based off of the
                            CS_N[1] <= ~SADDR[`ASIZE-1];                  // msb address bit
                    end
    //Generate the appropriate logic levels on RAS_N, CAS_N, and WE_N
    //depending on the issued command.
                    if (do_refresh==1) begin                        // Refresh: S=00, RAS=0, CAS=0, WE=1
                            RAS_N <= 0;
                            CAS_N <= 0;
                            WE_N  <= 1;
                    end
                    else if ((do_precharge==1) & ((oe4 == 1) | (rw_flag == 1))) begin      // burst terminate if write is active
                            RAS_N <= 1;
                            CAS_N <= 1;
                            WE_N  <= 0;
                    end
                    else if (do_precharge==1) begin                 // Precharge All: S=00, RAS=0, CAS=1, WE=0
                            RAS_N <= 0;
                            CAS_N <= 1;
                            WE_N  <= 0;
                    end
                    else if (do_load_mode==1) begin                 // Mode Write: S=00, RAS=0, CAS=0, WE=0
                            RAS_N <= 0;
                            CAS_N <= 0;
                            WE_N  <= 0;
                    end
                    else if (do_reada == 1 | do_writea == 1) begin  // Activate: S=01 or 10, RAS=0, CAS=1, WE=1
                            RAS_N <= 0;
                            CAS_N <= 1;
                            WE_N  <= 1;
                    end
                    else if (do_rw == 1) begin                      // Read/Write: S=01 or 10, RAS=1, CAS=0, WE=0 or 1
                            RAS_N <= 1;
                            CAS_N <= 0;
                            WE_N  <= rw_flag;
                    end
                    else begin                                      // No Operation: RAS=1, CAS=1, WE=1
                            RAS_N <= 1;
                            CAS_N <= 1;
                            WE_N  <= 1;
                    end
            end
    end
    endmodule
    I_File : -- Params.v
    *  LOGIC CORE:          SDR SDRAM Controller - Global Constants
    *  MODULE NAME:         params()
    *  REVISION HISTORY:
    *    Revision 1.0  03/24/2000
    *    Description: Initial Release.
    *  This file defines a number of global constants used throughout
    *  the SDR SDRAM Controller.
    // Address Space Parameters
    `define ROWSTART        9
    `define ROWSIZE         12
    `define COLSTART        0
    `define COLSIZE         9
    `define BANKSTART       20
    `define BANKSIZE        2
    // Address and Data Bus Sizes
    `define  ASIZE           23      // total address width of the SDRAM
    `define  DSIZE           16      // Width of data bus to SDRAMS
    compile_all.v
    `include "command.v"
    `include "sdr_sdram.v"
    `include "control_interface.v"
    `include "sdr_data_path.v"
    `include "pll1.v"
    `include "altclklock.v"
    Hi Chip.
    In another thread I postulated use 1.5 frequency divider for SDRAM-
    You said that can give problems with synthesies.
    So I have question if that solution still can give problems?
    First divide Frequency by - 3 --- Then multiply it by 2 with that circuity I post as attachment.
    // Verilog file generated by X-HDL - Revision 3.2.52  Mar. 28, 2005
    // Wed Dec  3 20:51:16 2008
    //      Input file         : E:/Twice /twice .vhd
    //      Design name        : twice
    //      Author             :
    //      Company            :
    //      Description        :  Frequency dabbler
    module twice (    clk,
                    //rst,
                    clk_out
                    //test
                    //d_out,
                    //d_outn,
                    //clk_temp
       input clk;
       //input rst;
       output clk_out;
      // output d_out,d_outn,clk_temp;
    wire    clk_temp;
    wire    d_outn;
    reg        d_out;
    assign clk_temp = clk ^ d_out ;
    assign clk_out = clk_temp ;
    assign d_outn = ~d_out ;
    always@(posedge clk_temp)
    begin
        //if (rst)
            //d_out = 1'b0 ;
        //else
            d_out = d_outn ;
    end
    endmodule
    812 x 172 - 27K
