Problem with Forum Editor? (When using Google Chrome)
skylight
There seems to be a problem with the editor(s) both simple and advanced, when trying to edit a post the editor window comes up blank, so at the moment there is no way to edit a previous post.
Anyone else having problems?
Have also posted in the test forum, sorry for cross posting but had to test what was wrong first, unfortunately because of the problem am unable to delete those posts.
Edited using Firefox: Changed title to be more specific about editor issue with Chrome.
Will try other browsers editing this post.
Firefox Ok.
Exploder Ok.
Advanced editor Ok.
1) The "Reply To Post" button hangs forever. I have to right click and select "open in new tab" to get to to the editor.
2) There are no "code", "quote" etc buttons above the edit window.
3) When I submit the resulting post on the forum has all the line feeds stripped out and often any capitalization removed.
It's all really annoying and almost useless.
Strangely on another box with the same Debian and Chrome everything works. Only that is a 32 bit install not 64.
It has all the same problems described above in my Chrome.
(I really need to upgrade, soon)
About half the time the editor will not work from android samsung captivate glide (similar to Galaxy S).
Did you notice the two br tags I had to put in the to get new lines?
I have no buttons over my edit box.
I get this error in the JS console when I hit "Post Reply":
No wonder it does not load.
...took care of that for you.
Edit: I can edit too.
Thank you for kicking me along with that SRLM.
First time back since posting so will try editing this post......
Still have the problem :frown:
This means the only way at the moment to edit my posts is to submit a new reply. not ideal, any other thoughts?
OK, this is nuts. I have the same Chrome as you (On Debian) and everything works fine.
I assume you have not disabled JS.
Can you get into the Tools->Javascript Console?
I used to have errors there with an only slightly older Chrome.
Seems to me this is some kind of timing problem, scripts being called before they have loaded for example.
though the slider setting shows High which is the minimum setting recommended.
JavaScript is not Java. They are two totally different things, despite the confusing naming.
Never, never enable Java unless your bank or some other idiot needs it.
"{RED X} Failed to load resource"
Clearly if this script or that resource is not loaded in time then the page cannot be displayed correctly or it's JS code run.
I have seen this kind of "load order dependency" in my own WEB creations.
No idea what is happening here though:)
If you ever visit a web site that needs Java for sure you will see something that insists that you need a Java plugin.
If they are like the banking web sites in Scandinavia they will the be nagging you to install the latest version every week for some security reason or other.
Java is a totally different language and run time system, that most people get as a plug-in from Oracle.
JavaScript is built into every mainstream browser.
EDIT: Works fine in firefox so looks like an issue with chrome
So I have a workaround using firefox but prefer to use chrome as it works better with my password manager.
Now with v31.somthing they both work.
