simple IDE on mac
where do i start
unable to get this thing to work..
Attachment not found.
please help . thank you...
Have you installed the USB drivers yet? See http://learn.parallax.com/mac
I noticed in your screenshot that there's no serial port selected (upper right field in the editor).
yes... and the the two green lights are on under the power switch...
am working through the link you posted . thank you
just like you said. thank you….
BTW, the most common error the students in my class encounter is that the wrong serial port has been "selected" (i.e. defaulted to) and their programs won't load. It would be nice if SimpleIDE would scan the available serial ports for a connected Propeller like the Propeller Tool does, in order to alleviate this time-consuming issue. Steve, are you listening?
