Rare Wheel Encoder Sensors Available: Strike Now! - Page 3 — Parallax Forums
13
    edited 2013-09-02 14:41
    Duane Degn wrote: »
    Okay, I'm about ready to drill some holes in a servo case and attempt to read a striped pattern on one of the gears (yet to be affixed).
    Is there a prefered orientation for these? should the two dots on the sensor be parallel with the encoder lines? Is there in info about how thin the encoder lines can be? I figure I'll try to keep the lines at least 1/8 inch wide.
    Has anyone used these with a Prop yet? I don't suppose and extra 4.7K resistor on the output line will interfere with the sensor's function?
    I've read ecro mention inkjet printed stripes don't get picked up by the sensor. Have any of you tried a Sharpie to darken the stripes?
    I had no problem with an inkjet striped wheel (I did use the highest quality setting) - see the video http://forums.parallax.com/showthread.php/149740-Rare-Wheel-Encoder-Sensors-Available-Strike-Now!?p=1203122&viewfull=1#post1203122
    I also used a 10k pullup rather than the 6.8k in erco's schematic. I didn't notice that the orientation made any difference but that probabl;y depends on how wide the stripes are...
    edited 2013-09-02 15:30
    Who's this "ecro" guy?
    Oops, sorry about that ocer.
    I like the dots parallel to stripes. Haven't done extensive testing, but it makes sense intuitively.
    I didn't notice that the orientation made any difference but that probably depends on how wide the stripes are...
    Yeah, I figure I'll go with parallel dots and stripes to begin with.
    Have you got access to a laser printer & coated paper? That's best IMO. I blanch at the thought of manually darkening via Sharpie. Maybe try coated paper in your inkjet printer first.
    The disks will be pretty small so it won't take very long to darken the stripes (if needed) with a Sharpie. I did this with my Roboni-I encoders.
    I think I had to use aluminum foil on white gear in order to get the IR to reflect. The white plastic was transparent to IR and didn't reflect it on its own.
    Once I added the foil, I blackened in some stripes. It was kind of odd not to have the IR reflect back at all from a nice white surface. (The stripes are on the other side of the gear. This was the only photo that was easy to find of it.)
    Good to know Ron. I'll try the inkjet stripes before darkening them with a Sharpie. I say you video earlier. Very cool.
    I'm not sure what it is, but there's just something cool about being able to read stripes on a wheel like you did in your video. I think part of the appeal is the sensor is reading the reading the stripes faster than one would think is possible. Those stripes are just sailing past in a blur and yet the encoders don't have a problem detecting them.
    Also good to know. I have lots of 10k resistors handy.
    Looking at the schematic erco posted in post #1, it looks like pin 3 pulls the output low.
    Do any of you know if pin 3 drives the line high? If it is an open drain output, then I shouldn't need an additional current limiting resistor on between the output and the Prop I/O pin. If it's not open drain, then I will need a current limiting resistor but then the pull-up resistor doesn't make sense.
    I'm going to assume it's an open drain output unless told otherwise.
    edited 2013-09-02 15:34
    Duane Degn wrote: »
    The 6.8k is between 5V and pin3 - so it is pulling it high.:smile:
    edited 2013-09-02 15:52
    Right, the resistor pulls it high, pin 3 pulls it low (when it's signalling a pulse). I suppose it's possible for pin 3 to be driven both high and low, but then why add a pull-up?
    I could find a datasheet to be sure, but I'm betting the schematic as posted is Prop pin safe.
    edited 2013-09-02 16:29
    Duane Degn wrote: »
    Sorry Duane, I read it wrong - thought you were saying that the resistor was a pulldown - I get your scenario/concern with the Prop now.
    edited 2013-09-03 13:59
    Duane Degn wrote: »
    . . . I'm betting the schematic as posted is Prop pin safe.
    If I connect the output to ground I measure 740uA which is more than a Prop pin can safely handle. But when I measure the current to through a Prop input pin, it's only 170uA. The cutoff limit for a Prop pin is 500uA. So I'm pretty sure (again) these sensors are Prop safe.
    Here's a picture of one of the sensors ready to be mounted inside a servo.
    I used 1/8 watt resistors and a 0603 smt 0.1uF cap on the bottom of the piece of board.
    433 x 468 - 82K
    edited 2013-09-03 22:05
    Duane: You're making me proud! Your quick use of these sensors and tidy little soldering job on that tiny little package is quite impressive. How DO you do it?
    Martin_H says he's also using one soon, and Ron Czap was the first guy in the pool! Mike Cook bought 50, and midrobots got 20, so I'm expecting big things from this forward deployment.
    Repeating, if we Forumistas ever decide to team up on a collaborative project, applying our respective strengths, the world is our oyster. There is NOTHING this team could not accomplish!
    edited 2013-09-04 09:09
    Shoot! I gotta make something? I'm still admiring the logo on the envelope mine came in! :smile:
    edited 2013-09-04 17:40
    For anyone who missed out on the hundred pack deals: (the ten-packs are still available): As promised, Tim at Junun Robotics re-stocked these. He's been out for a while, but now that he's been erco-sized, his price has dropped from $2.25 IIRC to the affordable new price of $1.50 .
    http://www.junun.org/MarkIII/Info.jsp?item=48
    And while we talkin' 'bout six-packs:
    480 x 481 - 411K
    edited 2013-09-04 20:03
    I've been having some trouble with my plan to add an encoder to a servo.
    I'm getting a lot of noise on the encoder line when the servo is turned on.
    I'm using two different techniques to monitor the encoders with the Propeller. One is to use the "ina" statement.
    PUB EncoderLoop'' count pin transitions.
      oldState := 2 ' impossible state so currentState won't match on the first loop
      repeat
        currentState := ina[ENCODER_PIN]
        if currentState <> oldState
          oldState := currentState
          encoderCount++
    This isn't as supseptible to noise as the technique using counters.
    ctra[30..26] := 010    ' set up posative edge detection from page 159 of the PEK.
      ctra[5..0] := ENCODER_PIN
      frqa~
      phsa~
      ctrb[30..26] := 110    ' set up negative edge detection from page 159 of the PEK.
      ctrb[5..0] := ENCODER_PIN
      frqb~
      phsb~
      ZeroCount
    ' skip to ZeroCount method
    PUB ZeroCount
    '' Must be called from cog where counters were setup.
      measureSpeedTimer := cnt
      encoderCount := 0
      previousCountIna := 0
      readEncoderCount := 0
      frqa~
      phsa~
      frqb~
      phsb~
      frqa := 1
      frqb := 1
    Here's the method to display the data.
    PUB DisplayCounts
      Debug.Position(0, DATA_LOC_Y)
      Debug.str(string("encoderCount = "))
      Debug.Dec(encoderCount)
      Debug.str(string(13, "phsa + phsb = "))
      Debug.Dec(phsa + phsb)
      Debug.ClearEnd
      Debug.str(string(13, "       phsa = "))
      Debug.Dec(phsa)
      Debug.ClearEnd
      Debug.str(string(13, "       phsb = "))
      Debug.Dec(phsb)
      Debug.ClearEnd
      Debug.str(string(13, "ledDisplayMode = "))
      Debug.str(ModeToStr)
      Debug.ClearEnd
    With the servo off, I can manually spin the gear and the two different techniques agree.
    Here's some sample output.
    fileName = QsEncoderDemo130904e
    Enter number to indicate which mode to use.
    4) LEDs display binary count of counter b.
    3) LEDs display binary count of counter a.
    2) LEDs display binary count of both counters
    1) LEDs display binary count of ina changes
    0) LED display encoder pin state (on or off)
    Enter "z" to zero encoder count.
    encoderCount = 1914
    phsa + phsb = 1914
           phsa = 957
           phsb = 957
    ledDisplayMode = BINARY_COUNT_INA_MODE
    localSpeedIna = 51
    localSpeedCtr = 51
    The above output was with me hand turning the gear. As you can see the two techniques used to read the encoder are in agreement.
    This next output is with the motor powered and turning relatively slow.
    encoderCount = 2135
    phsa + phsb = 8365
           phsa = 4182
           phsb = 4183
    localSpeedIna = 75
    localSpeedCtr = 1121
    With the motor on, the counters must be picking up some noise because they the start counting very quickly when the gear is moving slowly.
    I tried adding a Schmitt trigger to see if it would help. The Schmitt trigger made it so the "ina" technique also picked up the noise (not as much as the counters though).
    So far, my idea of having an encoder inside a servo isn't working out well (again).
    Any thoughts on how to reduce the noise from the servo motor?
    In case anyone is interested, I've attached the spin file to this post.
    Edit: See post #77 for most recent version of code.
    edited 2013-09-04 20:12
    Vcc=5V to P5587? It already has an internal Schmitt trigger, that's why I like it.
    Delta filter (3 caps) on the motor?
    edited 2013-09-04 21:36
    Vcc=5V to P5587?
    Yep.
    Nope. I should have thought of that. Thanks.
    There should be room to fit a few caps in with the motor. I'll give it a try.
    I don't think I mentioned the encoder seems to pick up less noise at high speeds. At max speed (using the little servo tester you gave me) the speed reads just about 400 transitions per second (which should be 100 rpm (two black stripes on the gear)). At full speed, the two reading techniques agree with each other.
    BTW, Sharpies don't absorb enough IR to work on brass. Even with a piece of tape over the Sharpie ink and another layer of ink on top of the tape, it still didn't absorb the IR. I'm using a couple of pieces of Gorilla tape for my stripes. I'll probably need to find a different solution when I put the gearbox back together. The Gorilla tape may be too thick to let everything spin like it's supposed to.
    edited 2013-09-04 22:40
    IIRC Gorilla tape is like glossy duct tape. Flat/matte black masking tape (art supply) may work better. Or, use any tape to mask off shiny brass areas and spray with Krylon ultra flat black, my fave.
    edited 2013-09-05 15:07
    Don't you think I know that!?! Grumble, grumble.
    So Mr. KnowItAll, it turns out it was the Gorilla tape. The Gorilla tape had a couple of bright spots which were causing quick blips which the counters picked up.
    I dug out my Parallax USB o'scope and this was what full speed showed.
    This trace doesn't explain everything I was seeing previously but it't pretty clear it picking up some bright spots on the tape. You can see two relatively equal large up blips per cycle. This is the bare brass. There's one low section each cycle about the same size as the two large up blips which is the non-shiny tape. The other piece of tape apparently has a couple of shiny spots causing false positives.
    I have some black masking tape I purchased from Parallax a while back. I'll try that to see if it works better. I used the Gorilla tape since there was a piece within arms reach while I was testing the encoder.
    So I ask once again. Don't you ever get tired of being right?
    I hope not, since you keep getting me out trouble with your rightness.
    556 x 545 - 96K
    edited 2013-09-05 16:49
    Just to be safe, maybe you should paint your barrel-shaped tread rollers flat black...
    Don't worry, everyone hates erco. At work, we have an expensive high speed camera which makes amazing super slow motion videos. Stops bullets in flight, balloons bursting, etc. Requires super bright lights and lot of instruction to operate. A PITA to set up IMO, I never use it. Yet most other people love to use it to attempt to troubleshoot toys & tracksets, cars crashing & doing weird things. Usually they fail either in observing, diagnosing, or remedying the problem correctly. I let them try for a while before I stroll up, look at the item (not the video), and offer a quick fix that works about 95% of the time.
    Thirty years of experience comes in handy sometimes. :)
    In a related story, I never use an oscilloscope. I have a fine Parallax USB scope I won here somehow, but I really haven't needed it.
    Yet. But I do work the Smile out of my many free HF multimeters!
    edited 2013-09-07 14:05
    It turns out the Gorilla tape was only causing a small part of the problem.
    Here's a picture of the encoder mounted inside the servo with the gear by its side.
    I found my black masking tape from Parallax and the oscilloscope showed nice clean high and low pulses coming from the encoders. I still had severe disagreements between the counts from the Spin loop (which were accurate) and the counts generated by the Propeller's counters (which could be very inaccurate).
    I wondered if there were some high speed blips the Spin loop wasn't catching that the counters were but the o'scope traces were nice and clean even at 50us per division (the highest res setting).
    I still don't know what the counters were counting but by switching the encoder power from the same power supply as used by the servo to the USB power shared with the QuickStart, the noise problem completely went away.
    Since I had the counters working correctly (as long as the power to the encoder was clean), I decided to add one more technique, of reading encoders using the Propeller, to the code.
    I added the following PASM code to monitor the encoder.
    DAT                     org
    pasmCode                rdlong  encoderCountCog, par
                            ' encoderCountCog now holds the pin used by the encoder
                            mov     encoderMask, #1
                            shl     encoderMask, encoderCountCog
                            mov     encoderCountCog, #0
                            wrlong  encoderCountCog, par
                            mov     oldScan, ina
                            and     oldScan, encoderMask
    readPin                 mov     newScan, ina
                            and     newScan, encoderMask
                            cmp     newScan, oldScan wz
                  if_nz     call    #addBlip
                            jmp     #readPin
    addBlip                 mov     oldScan, newScan
                            add     encoderCountCog, #1
    addBlip_ret             ret
    encoderMask             res 1
    encoderCountCog         res 1
    oldScan                 res 1
    newScan                 res 1
                            fit
    I'm pretty sure the PASM loop takes less than a microsecond so I'd think it would pick up some of the noise the counters are catching but the PASM agrees with the Spin loop even with a noisy power supply on the encoder.
    It seems very strange that the counters would pick up noise the PASM loop completely misses.
    edited 2013-09-07 16:59
    If there is some mysterious noise, maybe try a small cap across the sensor output to filter it. What's the Propeller's high/low switching threshold (IOW what voltage is sensed high vs which is low, as in 1.4V for the Stamp)?
    edited 2013-09-07 18:16
    I tried a 0.1uF cap on the output. It didn't help.
    I'm pretty sure the logic threshold for the Prop is 1.65V.
    I posted a question about this in the Prop forum. Tracy Allen had theory about what was happening.
    As I mentioned above, if I use the USB power from the QuickStart board to power the encoder instead of the servo's power supply the noise goes away. I haven't added the filtering caps to the motor yet. Now that I have a better idea of what's going on, I'll try the filter caps on the motor to see if they make a difference.
    edited 2013-10-12 09:44
    erco, so now that you've got me hooked on these encoders, should I buy additional units from you or buy directly from ebay?
    edited 2013-11-19 13:22
    Score! I informed Tim at Junun robotics about these sensors on Ebay and he restocked. He's now selling them for $1.50 each, lower than ever! http://www.junun.org/MarkIII/Info.jsp?item=48
    This was good karma and a win/win for everyone, as he was out of stock for several years.. See my previous post about Tim giving me his last few samples: http://forums.parallax.com/showthread.php/142284-Junun-Robotics?highlight=junun+robotics
    edited 2013-11-19 13:40
    But he didn't restock on the S6986
    You need to sell him a bunch to fund the school fund.
    (What am I talking about? Sell him a few at extremely high margins. Save the rest for us) :)
    edited 2013-11-19 15:10
    Good call, Pub. I need to corner the S6986 market then create incredible demand for it so I can sell them for extremely high margins and fill the twins' college fund.
    edited 2014-08-04 12:56
    Same seller has more of these sensors. Four for $13.50 or best offer. http://www.ebay.com/itm/4-pcs-Hamamatsu-P5587-Photo-IC-output-digital-Photoreflector-reflective-Sensors-/221504181827
    Was it Larry/lardom who was struggling recently to make DIY encoders?
    edited 2014-08-04 13:10
    Ouch!
    Those are great encoder sensors but that price seems kind of high.
    edited 2014-08-04 13:36
    Dang. I need to get mine out of the shipping tube!
    Been so busy getting the Quadrover, Quadcopter, Penguins, Toddlers, BOEbots, and blue Scribbler ready for the Boston EXPO. (S2 is still apart as I was prepping it for chrome paint).
    I will be demonstrating the most excellent S6986 Laser Sensor. You have some to sell? College unemployment fund.
    edited 2014-08-13 16:13
    Publison wrote: »
    So both you and Martin_H were workin' that sensor at the Boston Expo? Whuja do?
    edited 2014-08-13 16:22
    Publison wrote: »
    ....(S2 is still apart as I was prepping it for chrome paint).....
    Wait..Wut??
    edited 2014-08-13 16:28
    I just had a static display with my Activity Bot with the laser and sensor showing the >10' range.
    I gave Martin my NAPA reflective tape and he used it for his Claw Bot demo with great range and repeatably. He swears he's going to to another video. :)
    edited 2014-08-13 16:30
    Ttailspin wrote: »
    Wait..Wut??
    Thanks, Anna.
    I got that FROZEN reference.
    Prince Hans of the Southern Isles.
    edited 2014-08-13 16:37
    Ttailspin wrote: »
    Wait..Wut??
    Yup. Untill..........
    The special black primer spray can decided to break it's valve when I took the top off. Picture a guy running wildly through the basement with his hand and shirt over the can to make it outside where it continued to spew for 5 minutes. What a mess.
    I wanted to impress erco.. I'll put it back together a Photoshop it, he'll never know.
    http://www.alsacorp.com/products/killercans/kc/killerchrome.htm
