8 pin prop? — Parallax Forums
8 pin prop?
JBWolfJBWolf Posts: 405
edited 2013-11-01 13:30 in General Discussion
Hello,
Just an idea... I would love to see a mini-prop.
I work on many projects where space is everything... currently working on a controller where maximum allowed width is 12mm!
For this the QFN or QFP chip is the only available solution, and I have to run traces under the chip and cross other unused pins to allow the traces to fit.
Here's a pic of how I am accomplishing this challenging width constraint.
I would love to see something like a micro-prop.
Maybe 4-8 useable pins, only would need 2-4 cogs... and make it as thin as possible such as 5mm.
    edited 2013-10-30 16:35
    The Prop in a QFN package is only 9mm square.
  • PoundSign2PoundSign2 Posts: 129
    edited 2013-10-30 17:26
    Hand soldering that is going to suck. Especially if you're like me and have shaky, large hands. I can't hand solder anything SMD unless it's about 1206 size. 0805 is quite hard for me to do. This is where the 8-pin DIP idea I think the OP is getting at would come in. Of course if you got a reflow oven none of the sizes really matter. Just solder paste, place parts, stick in oven and good to go.
    edited 2013-10-30 19:25
    IR toaster ovens are cheap; that's what I use. Depositing the solder paste from a syringe takes a little practice, but I regularly solder 0603s without issue. Don't get Kester solder, though. I use Zephpaste. Keep it in the fridge when you're not using it, and it'll last way beyond the 6-month stated shelf life.
    edited 2013-10-30 19:46
    When you apply yours do you let it reheat to room temp (the paste that is)? Awhile back I was really into making my own PCBs and what not, but I got sick of the ferric-acid stuff from RadioShack. Absolutely ruins everything it touches. Which, is not surprising to be honest. However recently (last week) I did pick up some Liquid Tin. So I am itching to try that out. I might try to use the ol' solder paste again but I had serious problems with it. The paste would not hold the components down properly and it wouldn't stay/stick where I wanted. It was horrible. That's why I asked about the room temperature thing. Also, stencils I hear are good, but I don't see why you need to make this custom thing for a custom PCB just to put the solder paste on when all you would need to do is just apply with syringe. Then again, my method failed so maybe a stencil is worth a shot, who knows?
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2013-10-30 19:57
    I use a sharpened round toothpick to dob solder paste on one shot PD boards.
    Ya, it takes a bit of practice and patience but goes quick enough.
    Duane J
    edited 2013-10-30 20:54
    PoundSign2 wrote: »
    PoundSign2
    My hands are huge but, perhaps, not so beefy, in fact, they can easily cover a full octave, from a regular piano keyboard, tip to tip, from thumb to pinky finger.
    Due to the fact I use to do electronics solder joints since I was twelve, its easier to me; My muscle memory was very well trained from the beggining.
    I use to rely on it (muscle memory), and ever try to relax the feedback mechanism, between the eyes and the hands.
    SMD sizes 1008 and 0805 were always doable, but 0603 required much more training, before I could master it.
    In the absence of epoxy adhesive to hold parts in place, I rely on some of Mrs. Yanomani's emergency sewing kit needles, after rounding their tips against fine grain sandpaper, to avoid excessive contact pressure against fragile/vitreous parts.
    I must admit, departing from size 0402, the time spent in place and solder tasks increases to unacceptable limits, so does rework/refurbish issues.
    If you are addicted to your eyes, why don't giving yourself some usefull gift:
    http://hackaday.com/2012/12/30/usb-microscope-used-for-soldering-very-small-things/
    Or try getting some Tiger Woods eyes equiped intern.:smile:
    Yanomani
    edited 2013-10-30 21:22
    It's funny you mention eyes, as I just had LASIK two weeks ago! Speak of it, I have yet to solder with my "new" eyes.
  • JBWolfJBWolf Posts: 405
    edited 2013-10-30 21:56
    oh by far the easiest way to solder QFN is with a little liquid flux... it makes the solder jump to even the finest traces without any bridges.
    I have an AOYUE 968 SMD station... very good cost for the effect, highly recommend one.
    Soldering is not a problem for me, I have many decades of experience... just need a smaller prop chip
    edited 2013-10-30 22:24
    You know, I don't want to sound rude, but saying Parallax should make a smaller Prop chip because the current model doesn't fit your specs is like telling your manager they need to rebuild their entire office closer to your house so you don't have to drive as far. It's taken Parallax 7 years and hundreds of thousands of dollars to get the Propeller 2 at its current state, the idea of making ANOTHER Propeller chip is a bit ridiculous to say the least. Especially considering the current one in development hasn't even hit the market yet.
    And no, a mini-Prop would not be "easier" to make by any significant margin just because it is less powerful. (feel free to correct me here if I'm wrong) There's still a LOT of work that would go into it for a market that honestly isn't very significant. Maybe in the future Parallax will start expanding their line of Propellers to such a degree, but I doubt that will happen any time soon.
    edited 2013-10-30 22:49
    The other issue, of course, is what do you get with eight pins? Two for power and ground, one for reset, two for a crystal, two for programming. That leaves one pin. Oh, drat! 'Forgot: we need two more for the EEPROM. That leeaves minus-one pin for general I/O.
    edited 2013-10-31 00:00
    The problem, IMO, with the QFN package is you can't run traces or vias under the chip. I think the QFP package makes smaller PCBs easier to route than trying to use the QFN.
    I can also hand solder the QFP. I'm too chicken to try soldering a QFN package.
    I posted a few attempts at making a small Prop board to fit inside a servo.
    I originally tried to route traces for a QFN chip but soon found it was easier to find paths with a QFP chip.
    edited 2013-10-31 01:27
    I want a 144 Pin DIP Propeller 2 please.
    edited 2013-10-31 02:48
    DIP?
    I much prefer SIP for those narrow boards.
    edited 2013-10-31 12:30
    Gadgetman wrote: »
    DIP?
    Yeah but a 40 Pin DIP is about the size of a Twix bar. Imagine the size of a 144 Pin DIP? Hersey's bar? lol
    edited 2013-10-31 12:57
    by 'useable pins' I was referring to non-critical output pins. So a slim package with around 5 addressable pins excluding XO/XI/VSS......
    Would it be possible to design a slim package requiring only one VDD/VSS by reducing the amount of cogs & output pins?
    This may seem counterproductive to some I assume... however, I believe most can agree that for simple projects such as a sensor, 8 cogs & 30+ addressable pins is overkill.
    a 'barebones' package would be of great use to those of us who need to make a large quantity of devices that only utilize 1 or 2 pins/cogs and must be as small as possible.
    Just thought there might be others with similar needs
    Microc: That was a terrible analogy. I'm not sure where the misquoted 'easier' rant came from, effort is never easy. I love progress and appreciate the amount of work invested by parallax, I too am looking forward to the prop2... but you'll just have to accept that sometimes people might ask for things that may make no sense to you at all. I dont think it's crazy to ask for a chip with reduced size at the sacrifice of capability.. a great example would be the micro-atx motherboard. So please, instead of the 'how dare you' attitude, think happy thoughts. :)
    edited 2013-10-31 13:01
    oh and a 144 pin prop would be pretty sweet too... especially for LED arrays
    edited 2013-10-31 13:04
    Hi JB;
    JBWolf wrote: »
    No!!!
    All VDD/VSS pins on the Prop must be properly connected together and decoupled.
    If not done the Prop can be damaged even if only 1 cog is running.
    Duane J
    edited 2013-10-31 13:21
    Duane are you referring to the existing prop chips?
    edited 2013-10-31 14:12
    Hi JB;
    JBWolf wrote: »
    Well I guess so as their the only ones available.
    Duane J
    edited 2013-10-31 15:29
    not sure if you have many projects where you only utilize 1 or 2 pins and cogs.... but would you be interested in a prop chip with only 2 cogs and 5 output pins but comes in an SIP package measuring 5mm x 5mm x 15mm?
    edited 2013-10-31 15:34
    Also maybe have a single built in graphene capacitor to do away with the external .1uf caps :D
    edited 2013-10-31 18:24
    Use the SAME die ! the 2 non DIP ones do The die is what constrains the package .
    Just dont wirebond the pads to the pins
    Yes it means some retooling but not a die change .
  • jmgjmg Posts: 15,199
    edited 2013-10-31 18:25
    JBWolf wrote: »
    Hello,
    The Prop 1 die determines the package size, and the QFN40 has larger than usual pitch because of this.
    A completely new die is very expensive, and cannot happen before P2 is done, but there are some example modules out there, which show what Parallax could do.
    eg the UMFT234XF from FTDI, lists at $5.95 1+, $5.23 100+ and is low profile and small.
    With the pcb-edge connections it can direct SMD mount in moderate volumes, or solder onto a pin-frame.
    A prop 1 version would have EEPROM, decoupling, Xtal all in smallest-available basis.
    Inclusion of USB link is going to impact size and price, so could push to two modules, one with USB, and a minimals-size one with just a working Prop
    I like the SiLabs Si504 as a small, any-frequency clock, comes down to 2.5 x 2mm so could be a fit option for 'any frequency' model.
  • PaulPaul Posts: 263
    You could use CpuBlade pins 24..1 as a 10-pin SIP once programmed (I assumed the EEPROM is on the bottom) This will give you P0 through P7 as GPIO.
