Suggestion for mounting BOE-Bot servos — Parallax Forums
edited 2013-10-20 13:52 in General Discussion
Anyone who's ever assembled a bot on the BOE-Bot/ActivityBot chassis knows how aggravating it can be to install nuts on the screws that hold the wheel servos in place. And once you get one started, it's tempting to stop tightening when the nut starts to spin, just because it's so hard to get a wrench or pliers in there to hold it. As a consequence, many servos do not get tightened down as well as they could be. The latter could become an issue with the ActivityBot especially, since those same screws also hold the encoder bracket, which should be held tight to get the best results.
To address this issue, I've designed a self-threading backing plate to replace the nuts entirely:
It's laser-cut from 3/32" acetal copolymer with 0.096" holes (thanks, Matt!) into which 4-40 screws thread neatly and hold tightly. To install a servo, it's necessary only to position the backing plate over the back of the servo and start turning screws. No needle-nosed pliers or tiny fingers are needed. Here's a photo of the plate installed:
Attached is a DXF file so that Matt can try one out on Parallax's laser cutter.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-10-11 20:19
    That is definately cool. Good job Phil. Any chance of getting the file in something other than .dxf?
    edited 2013-10-11 20:31
    Any guess on how many times the screws could be used on it without the plastic stipping out?
    I have an aversion to self threading plastic holes. My S2 screws barely stay in place since I've opened it up so many times.
    What if instead of holes, you cut hexagons to hold the nuts in place (so they don't spin when tightened)?
    edited 2013-10-11 21:56
    Thanks, What format would you like?
    According to Matt G, even if the holes do strip, the Delrin is self-healing and can hold a screw again. The 3/32" material holds really tight, BTW. It would be hard to strip it. As a bonus, it acts almost like a Nylok nut, keeping the screw from coming loose.
    edited 2013-10-11 23:05
    MS Visio possible? If not it's no big deal. I have a AutoCAD file reader somewhere that I could use.
    edited 2013-10-11 23:57
    Sorry, I don't have MS Visio or even know what format it uses.
    edited 2013-10-12 07:29
    Thanks for the information Phil.
    I just assembled my ActivityBot. I didn't know about the little Delrin wrench and the NyLok nuts until now. That combination works great! So I'm withdrawing this thread's suggestion. It's unnecessary.
