Propforth with VGA question
K6MLE
Just got version 5.5 up on the Propeller Proto Board. In a previous application, I wired the Proto Board to use pins 12, 13 & 14 for VGA output to a small TFT color monitor. What I can't quite figure out is how/where to modify vga.f (in Extensions) to work with these pins. Assuming vga.f will give me the same color output I had in the previous SPIN application ... !?
Thanks for any help!
Michael
K6MLE
Michael
K6MLE
It might be TV Text that I'm trying to bring up, rather than VGA!
How is that done with PropForth?
Thanks!
Michael
K6MLE
Update: From a quick glance, there doesn't seem to be a TV driver in the 5.5 package.
I cannot locate anything for TV or NTSC/PAL at the Google site... you might contact Prof Braino for a quick reply.
