Propforth with VGA question — Parallax Forums
K6MLEK6MLE Posts: 106
edited 2013-10-14 11:05 in Propeller 1
Just got version 5.5 up on the Propeller Proto Board. In a previous application, I wired the Proto Board to use pins 12, 13 & 14 for VGA output to a small TFT color monitor. What I can't quite figure out is how/where to modify vga.f (in Extensions) to work with these pins. Assuming vga.f will give me the same color output I had in the previous SPIN application ... !?
Thanks for any help!
Michael
K6MLE
    edited 2013-10-10 20:55
    K6MLE wrote: »
    Can you provide more details? Those three pins look more like TV output to me. VGA usually drives an 8bit bus (2bits each for RGB and sync).
  • K6MLEK6MLE Posts: 106
    edited 2013-10-10 21:20
    I think you've reminded me of something ... other than trying to do technical stuff at too late an hour! :)
    It might be TV Text that I'm trying to bring up, rather than VGA!
    How is that done with PropForth?
    Thanks!
    Michael
    K6MLE
    edited 2013-10-10 21:23
    K6MLE wrote: »
    I'd have to check (may take a bit). So are you saying you had TV output before with an earlier version of Propforth?
    Update: From a quick glance, there doesn't seem to be a TV driver in the 5.5 package.
    edited 2013-10-11 10:54
    The previous application was created with SPIN, not PropForth. This will be my first attempt at anything with PropForth.
    edited 2013-10-12 11:46
    I've had a chance to check my previous configuration and what I am looking for at this time is a TV-text capability from PropForth. Has this already been accomplished?
    PropForth may have never supported an NTSC/PAL solution. You might check at their Google website.
    I cannot locate anything for TV or NTSC/PAL at the Google site... you might contact Prof Braino for a quick reply.
