BS2 and Xbee Help...
Hi guys...
I'm newbie... i have a 1 BS2 (home work) + 1 Xbee (Serie 1) + 1 Xbee explorer regulared (not usb) ...
I connected BS2 with PC via serial, and it's no problem... but i want receive some message from xbee... and i don't receive...
xbee regulated connect pin... DIN <->PIN 14 ... DOUT-> PIN 15 --- 5.5 <-> VDD --- GND <->VSS .. (xbee light red on)..
i used DebugSIMPLE.bs2 (attached) ..
when i see Terminal in X-CTU software... i can't see nothing...
I did something wrong???
Regards...
sorry for my english... i speak spanish....
Regards...
Product Link... http://www.olimex.cl/product_info.php?products_id=586
Also.... when i press XCTU show me... this...
One thing that concerns me greatly about this product is that the page you linked states this product translates signals from 5V down to 3.3V, but the linked schematic doesn't show any circuitry that does this, nor does the board appear to have more than a regulator and the 4 LEDs and resistors. If you're putting 5V into a 3.3V XBee module it could be damaged. They are not 5V tolerant.
P.S. - If you're more familiar with Spanish you can reply in that and I will use Google Translate. :thumb:
You say that Xbee (modem) use 3.3V ... the BS2 connect to Xbee Adapter giving 5V ... and the Xbee Adapter converts 5V to 3.3V to Xbee... so i think that voltage is correct... Xbee adapter card is sold for that purpose
Finally.. if my module was damage.... anyway i wanna know how to connect xbee (S1) without a module explorer usb to BS2...
Thank you so much Mr.Savage for your answers...
That's simply not the case.
That board (olimex/sparkfun) supplies 3V for the XBee to operate from, but it does not make for any level conversion (5v-to-3V). You could make a voltage divider from the BS2 serial output pin (whichever you choose) using a 2.2K and a 3.3K resistor.
PE) Uh-Oh!
The picture at the olimex site (above) looks like the Sparkfun "XBee Explorer Regulated" and that does have level-shifting circuitry.
https://www.sparkfun.com/products/11373
BUT, the olimex site points to a Sparkfun page PDF schematic that is not the board shown (which has no "level shifting") - hence this confusion. That's their error.
Your chosen serial out pin should go to the XBee DIN pin (once it has been "level shifted"). The XBee DOUT pin can go directly goes to the BS2 chosen serial in pin.
