Proper Pins on a Prop BOE to connect to a XBee
I was trying the code with the tutorial "Wireless XBee Communication" at http://learn.parallax.com/node/362 on a Prop Board of Education and it worked fine when I hooked the receiver up to pins 6 and 7 as per the documentation. It also worked when I hooked it up directly to pin 14/15. However, when I tried to run the receiver code on pins 14/15 or 18/19 via the Servo connections it did not work. The schematic shows a 39K resistor on those pins. Does that reduce the amps/voltage too much? Is there something about the board or those pins that is an issue with the xbee serial connection to the Prop?
This worked
This didn't work
This worked
OBJ system : "Propeller Board of Education" ' PropBOE configuration tools pst : "Parallax Serial Terminal Plus" ' Terminal communication tools time : "Timing" ' Timing convenience methods xb : "XBee_Object_1" ' XBee communication methods PUB Go | c system.Clock(80_000_000) ' System clock -> 80 MHz pst.Start(115_200) ' Start Parallax Serial Terminal xb.start(7,6,0,9600) ' Propeller Comms - RX,TX, Mode, Baud xb.AT_Init ' Initialize for fast AT command use - 5 second delay to perform xb.AT_ConfigVal(string("ATMY"), 9) ' Set MY address to 9 xb.AT_ConfigVal(String("ATDL"), 8) ' Set Destination Low address to 8 repeat ' Main loop c := xb.rxCheck ' Check buffer if c <> -1 ' If it's not empty (-1) pst.Char(c) ' Then display the character
This didn't work
OBJ system : "Propeller Board of Education" ' PropBOE configuration tools pst : "Parallax Serial Terminal Plus" ' Terminal communication tools time : "Timing" ' Timing convenience methods xb : "XBee_Object_1" ' XBee communication methods PUB Go | c system.Clock(80_000_000) ' System clock -> 80 MHz pst.Start(115_200) ' Start Parallax Serial Terminal xb.start(19,18,0,9600) ' Propeller Comms - RX,TX, Mode, Baud xb.AT_Init ' Initialize for fast AT command use - 5 second delay to perform xb.AT_ConfigVal(string("ATMY"), 9) ' Set MY address to 9 xb.AT_ConfigVal(String("ATDL"), 8) ' Set Destination Low address to 8 repeat ' Main loop c := xb.rxCheck ' Check buffer if c <> -1 ' If it's not empty (-1) pst.Char(c) ' Then display the character
