Proper Pins on a Prop BOE to connect to a XBee
I was trying the code with the tutorial "Wireless XBee Communication" at http://learn.parallax.com/node/362 on a Prop Board of Education and it worked fine when I hooked the receiver up to pins 6 and 7 as per the documentation. It also worked when I hooked it up directly to pin 14/15. However, when I tried to run the receiver code on pins 14/15 or 18/19 via the Servo connections it did not work. The schematic shows a 39K resistor on those pins. Does that reduce the amps/voltage too much? Is there something about the board or those pins that is an issue with the xbee serial connection to the Prop?
This worked
This didn't work
This worked
OBJ
system : "Propeller Board of Education" ' PropBOE configuration tools
pst : "Parallax Serial Terminal Plus" ' Terminal communication tools
time : "Timing" ' Timing convenience methods
xb : "XBee_Object_1" ' XBee communication methods
PUB Go | c
system.Clock(80_000_000) ' System clock -> 80 MHz
pst.Start(115_200) ' Start Parallax Serial Terminal
xb.start(7,6,0,9600) ' Propeller Comms - RX,TX, Mode, Baud
xb.AT_Init ' Initialize for fast AT command use - 5 second delay to perform
xb.AT_ConfigVal(string("ATMY"), 9) ' Set MY address to 9
xb.AT_ConfigVal(String("ATDL"), 8) ' Set Destination Low address to 8
repeat ' Main loop
c := xb.rxCheck ' Check buffer
if c <> -1 ' If it's not empty (-1)
pst.Char(c) ' Then display the character
This didn't work
OBJ
PUB Go | c
xb.start(19,18,0,9600) ' Propeller Comms - RX,TX, Mode, Baud
repeat ' Main loop
