Activity Bot mechanical assembly step 7 & 8 heads up
After mounting the encoders on the activity bot remount the wheel and check to be sure the IR transceivers are visible between the encoder spokes if not, loosen the encoder mounting screws and adjust the position of the encoder relative to the servo so that they are visible and then tighten the screws and remove the wheel. Do this for both encoders. Missing this crucial step will require a lot of disassemble to correct the problem when the encoder does not output pulses as expected in later steps.
Ask me how I know this hee hee hee
Can you take a photo of a misaligned encoder, please, and post it? I'm more than a little surprised that misalignment to the point of failure is even possible.
I'll see if I can re-test by loosening and resetting the encoder until it fails as it did before. I'll let you know...
dgately
It is all about the relative distance between the transceiver and the servo hub.
@Phil I do have several pictures, but pretty much all you see is what I described above.
You could guarantee this could never happen by modifying the wheel to elongate the encoder
spokes towards the hub.
Will the new wheels be available for purchase, would love to use them on my BoeBot?
Ray
I've attached the data from a "good" calibration and a "bad" one. I also attached close-ups of the encoder diodes as seen through the windows on the wheels with "good" positioning and with "bad" positioning. The image with the diode visible slightly lower in the wheel's window depicts the "bad" case...
There's very little difference in the positioning, but I've repeated the test twice with these results.
dgately
Thanks so much for bringing this up, and thanks to you and Phil and Dennis for looking deeper into what is going on. I honestly never encountered this with the numerous sample robots built and tested during development of the assembly instructions (I think my crew built about 20). I have alerted Andy to this thread, and I'm sure he will appreciate the calibration text output.
Ray, yes, we will sell a 1 encoder wheel + 1 o-ring tire set on our website soon, I'm working on setting that up. You can order the parts individually now by contacting our sales team directly.
