Dunno, Davis
Moving along on square wheels. Not sure about this one. Different ain't always better. A sofa bed is neither a good sofa nor a good bed.
http://www.youtube.com/watch?v=6qxx7K17L_8
The ways it uses the articulation is impressive and worth trying to duplicate.
I wonder if the same can be done with a round wheel on a similar design? Hmmmmm....maybe that would be IMPOSSIBLE!!!
An improvement might be triangular wheels... that would eliminate one bump! ;-)
Yes, yes... 'tis early and I haven't had quite enough caffeine.
Amanda
Confound you, Rick. Achieving this and proving you wrong will now become the object of my fixation!
Actually I have used triangular wheels to good effect previously on Wastebot. Novel, yes. Better, no.
I would add "barely". Engineers and architects need to get out of their offices and look at the end result of their designs more often.
Now, if the wheel plates had one or two more abilities... For example:
- the plate contracts to be square and expands to be round
- the plate grips another unit when presented int eh proper way, and releases when commanded a specific way.
Either or both f these would give a whole bunch of neet-o things to play with.
Did y'all see the electrically pulsed magnetic grab and release that was on kickstarter a couple weeks back? Uses no power except for the engage / disengage pulse? Put that on the wheel plate and we can watch these self assemble.
WHo can suggest an iris or something that can morph the small square plates into large round wheels?
