The Terminator
                    First test of the Terminator, my entry into the Coasterbot contest, a multi-sensor robot using a CD as a chassis. On-board laser targeting system locates small reflective stickers on cans and blasts them with rubber bands. BS2 controlled, the sensors include a Hamamatsu S6986, a PING rangefinder and the distinctive tick-tick-tick of my mechanical 4 PPR wheel encoder on the tricycle drive wheel, driven by a DC gearmotor. Standard servo steering and another 9g continuous rotation servo on the rubber band fire control system! More to come, speech & IR control, but I thought this first test was encouraging enough to share.
Put a laser reflective tag on a pressure switch on its butt and when 2 or more get together, they can play tag!
I'd buy a kit or try and build. I could see it being a hit with my 4-h kids or a robotics club!
Well played, Master Erco, well played!!
I'm sure you sent Phil his royalty check.
http://forums.parallax.com/showthread.php/139293-S2-Marauder-12-shot-Semi-automatic-...
Yes, I was heavily inspired by PhiPi's magnificent Marauder. As Pablo Picasso said, “Good Artists Borrow, Great Artists Steal”.
Phil's shooter is far slicker than mine, mine is sinfully simple. Details in a while. Swamped right now...so much time and so little to do!
"Wait...Strike that... Reverse it"... Willie Wonka
master of plywood. and relays.
I like your enthusiam, soldier! The sad part is that the Hamamatsu sensor (which makes it work so doggone well with a cheap laser pointer) is obsolete and nearly impossible to find. Junun was the last US source; their site says backordered, but they are out permanently. I've asked. They are available across the pond, though: http://www.active-robots.com/hamamatsu-proximity-detector.html . Otherwise, Junun has lots of good info at http://www.junun.org/MarkIII/Info.jsp?item=79 check all the links on that page. I love Philo.
I may have to try these other sensors, but they work with IR LEDs, not lasers. Won't be nearly as directional. http://www.junun.org/MarkIII/Info.jsp?item=46
That rubber band gun "escapement" is as simple as it gets. Slow to load, but deadly accurate. It's never missed a can in two dozen demos.
Hey, erco, a little MAP gas out a stainless steel tube could turn the tables on your Terminator!
I especially like how you simulated plastic by shaving down that hunk of plywood, and gave it a nice coat of silver paint to make it look like a real CD!
-MattG
Then you'll be friggin' blown away by how I shaved & painted a Propeller to look & act like a BS2E!
OMG I live in Louisiana and don't have a cellar because it would flood. I am so screwed.
http://www.youtube.com/watch?v=ASoCJTYgYB0&feature=player_detailpage&t=52
When you have time can you post a picture of your ‘Terminator’, looking down the ‘rubber band barrel’? I would like to see how you have the S6809 mounted in relation to the laser pointer.
With a lens, I'm guessing 20-30 feet.
Looks pretty simple to build and operate.
Once you get it figured out (who gets what; Laser Sensor, line encoder) send me a bill!
You convinced me to try a couple of those sensors.
Actively steering toward the right edge of the reflector.
I don't think I'm going to be able to withstand the temptation to follow in your footsteps once again.
I have lots of lasers and I have yet to add on to a robot (how embarrassing). Either a robot or a shark will soon have one of my lasers mounted on it.
Very, very cool project erco!
