Using Multiple Propellers?
I'm planning on designing a board that will have 2 props on it, pretty much right next to eachother, and I'm wondering if they can share a crystal. Are there any possible disadvantages to this?
If you look at my attached schematics in this thread, you will see how I accomplished using a single crystal on two props.
http://forums.parallax.com/showthread.php/124520-Anyone-that-wants-more-data-up-the-USB-serial-pipe-Dual-FTDI-Parallel-Props-(hanno!)
http://forums.parallax.com/attachment.php?attachmentid=72244&d=1281101659
I wouldn't recommend getting the clock from a single crystal like this, many would agree its unpredictable due to differences in boot time.
(if you mass produce enough of these, or reboot enough times, eventually, one of the props will accidentally not boot(so just reboot pcb if you can), its rare, but can happen)
The better way would be to hook the crystal up to a single prop, and use that prop to send out a 5mhz signal out of one of its pins, that goes to the XI of the second prop
Thread: http://forums.parallax.com/showthread.php/124487-EtPhoneHome-v1.0-A-Nokia-6150(like)-pcb-redone-with-two-propellers.-PCD8544-l?highlight=etphonehome
Schematic showing proper dual prop crystal config. (prop that has 5mhz crystal, outputs a 5mhz signal on p27 to the XI of secondary prop.)
(take note that the props need specific crystal settings in the CON section to differentiate between XI and crystal.
The main problem with sharing the clock between two Props is that the oscillator stops when the "Master-Prop" is in reset state.
So you can not let run the second Prop while the first is reseted. Depending on the application this may be a proplem or not.
This also happens if the first Prop provides a clock to the second over an I/O pin.
Andy
Tubular has the Und3rb3lly but I don't think he sells them. At least I couldn't get him to sell me one (but he gave me two).
Cluso99 also has small Propeller boards.
I've cut one of Jazzed TetraProp boards into small single or double Propeller boards. These are so handy I've thought about designing a MonoProp board with the same pin layout.
I used to use this PCB from SparkFun to make my own small Propeller boards. By cutting a couple of the smt pads on the back of the board, a SOIC EEPROM can be used with it.
I haven't used the SparkFun board for a while since there are so many good small Prop board options these days.
