Dollar Solderless Breadboards - Page 5 — Parallax Forums
1235»
  • John KauffmanJohn Kauffman Posts: 653
    edited 2013-08-18 19:57
    What I've needed for years is solder-able prototype boards (PCB, not breadboard) with holes along top and left that will align with the pin header & power header of BOE (and Homework). I'm teaching and need to build/strip several WAM / BOEBOT circuits each hour. That is a real drag when talking about the jumpers and resistors for a 7 seg display. I'd like to solder the circuit for each activity on a set of boards with male headers pins on the bottom. Then I can just press the appropriate populated (soldered) board into BOE female headers so it sits above the breadboard. Swap-outs would be easy.
    Sounds easy so I bought several boards from the Shack and then Digi and others. But the BOE's two female headers (pins and power) are not exactly on the same 0.1 pitch grid. If I line up the holes for the power header then the pins header is not aligned with holes. One is about half a row off from the other. So putting male pins on the bottom of a generic board has not worked for me.
    I don't have the skills to design a board with proper location of holes for headers strips. It would be great if someone knew how to measure that and put into a design file. I would send to a PCB fabricator and get 30 pieces (plus more if anyone else wants). I wish I had interns.
    edited 2013-08-18 20:33
    Gadgetman wrote: »
    Has anyone seen a $1 DC power board that fits these boards?
    (The ones mentioned earlier are for double bussed boards. )
    Not exactly, but you can easily hack one of the $1.38 power boards with the info at http://forums.parallax.com/showthread.php/149375-Strange-USB-Connector?p=1201843&viewfull=1#post1201843
    edited 2013-08-18 20:59
    An interim solution would be to use standard headers on one side, and 90-degree headers on the other. With some creative soldering on double-sided PCBs, you're in business and can space the offset any amount you need.
    edited 2013-08-19 05:05
    Erco:
    Thanks for idea of using 90-degree pin strips which I could slide in-out to align with headers.
    Alternately on the creative path, I have soldered onto proto board some leads w/male tips and plugged those into BOE headers. Works for now, but I can see leads will be tearing out of the prototype board and whole hack is not as easy/quick to use as a dedicated physical format.
  • run washingrun washing Posts: 1
    edited 2013-08-20 00:55
    Can you attach a picture?
  • Buck RogersBuck Rogers Posts: 2,200
    edited 2013-10-03 21:02
    http://www.ebay.com/itm/BIJOUXCASA-SOLDERLESS-BREADBOARD-170-TIE-POINTS-FOR-ARDUINO-SHIELD-CL-0151-/121117932662?pt=LH_DefaultDomain_0&hash=item1c3330fc76 99 cents, free shipping!
    I ordered three to try. Same size and 17x10 grid as used on the BoE/HW boards, in random colors. For a buck, it might make sense on some projects to just build "permanently" on these and throw them in a project box. But maybe not for mission critical, outdoor/humid/corrosive environments.
    Next goal is to find a matching plastic project box for a buck. The ones I have found seem overpriced. Best I've found is two for $4.84 shipped. These are small, and those breadboards might just be a press fit widthwise (saving a mounting screw, even faster to use!) : http://www.ebay.com/itm/2pcs-DIY-B70x41x23mm-New-Black-Plastic-Project-Box-Electronic-Case-/160878034740?pt=LH_DefaultDomain_0&hash=item257513ff34#ht_2018wt_679
    Some enterprising robot builder will use these breadboards as a chassis for a microbot. Double-stick-tape two micro CR servos and a LiPo battery on the bottom, and the top is your playground.
    @Duane/Martin_H/Whit+/TommyT: Who will beat me to it?
    Hello!
    Cut to today. I have here a similar batch of five minis. The white one is the same as standing on my HWB, and as traveled with two tins of components from Maker Shed. And on the protoshield for the Ar**** and as on the shield for the thing.
    As it happens all of them arrived with jumpers when I bought a bag full of them at the recent Maker Faire here in NYC, when I asked if any of our hosts would be there.
    Oddly enough I did look at the Small Robotics page. And I'm impressed. No intentions of building it since no code was provided but okay.
    edited 2013-10-29 19:00
    Dang it, somebody stole my "breadboard as chassis" idea clear back in 1998, and even beat me to the clever name I was considering, "Breadbot". At least he used a Parallax processor, the venerable BS1!
    http://smallbotics.solarbotics.net/BreadBot.htm
    Hello!
    Oddly enough I'm planning a similar idea finally. Tamiya USA makes a so-called Universal Plate Set, https://www.sparkfun.com/products/10016 that's from the SPF catalog, but its the same vendor, and also https://www.sparkfun.com/products/321 Tank Treads, upon examination, they look almost the same as the ones for the BOE Bot.
    The powerplant for that whole business is one of the motor assemblies with gears that the same company makes and SPF also sells. But since Parallax advocates using these continuous rotation servos, that's what I'd be using instead. The really difficult part is the selection of either a BS1 or BS2 for the brains of the setup.
    Yes I know I'm rebooting an already old thread on the subject of these boards.
